Dealership recommending HV battery fan service for Prime
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Tony Zenmaster, Apr 8, 2020.
  1. Tony Zenmaster
    Tony Zenmaster Junior Member
    Garden Grove, California
    Hi everyone,
    I was recently at Elmore Toyota in Westminster, bringing in my 2017 Prime for a routine maintenance & oil change service. Before my car was taken in for maintenance, the service advisor looks at my car's records and says they recommend a hv battery fan & some other coolant flush service. I respectfully declined before they took my car in. After about an hour, the tech finished my car. The service advisor says the tech saw my hv cooling fans were dirty and that i need inverter coolant exchange.
    How can I check myself if my Prime really does need this? I honestly feel like the service advisor is trying to squeeze more revenue since the dealership and service department was like a ghost town when i went during this Covid-19 stuff. I don't know how the tech can know if the hv fan is dirty since he needs to take apart the whole back seat I believe which i'm pretty sure he didn't do. I have items in the back seat area and they were pretty much in the same place when I took my car back. Any advice or instructions on how I can check these service recommendations myself will be greatly appreciated.
    Stay safe everyone.
  2. Mendel Leisk
    41,894
    What's the miles on it?
  3. Tony Zenmaster
    60K
  4. Mendel Leisk
    41,894
    You should be able to check your hybrid battery fan yourself. Not sure of the details, other Prime owners will hopefully have tips.
    A dealership recommending to change coolant on a 2017 with 60k miles should be avoided. And reported to Toyota.
    Check your Warranty and Maintenance Booklet for what maintenance is due, and when.
    Montgomery and dig4dirt like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Piece of cake! Pull out the cargo mat. Take out the lid on the little cable storage bin by the hatch latch. Remove a few plastid fasteners and lift the deck out. It takes about three minutes if the cargo area isn't loaded with stuff like mine. The fans will be staring you in the face.
  6. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    If you want to continue with the same dealership, just decline all services they suggest.
    Look your manual to see what is technically needed/necessary.
    jerrymildred likes this.
  7. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    While some of us here disagree on proper service and maintenance for vehicles...the SA was just trying to pad your bill because he makes a cut/commision doing so. I guarantee the Mechanic/Tech said NOTHING about your fan needing cleaning. They just read the W/O and do the job assigned. Period. They are already to busy to go fishing for more work.
  8. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    What's the trick to removing those 4 plastic fasteners? One of mine is missing all together. They look like buttons. Need a special tool? Thanks. Ted
  9. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    Just a slot head screw driver will do. Even a butter knive (an old one the wife won't miss)
  10. jerrymildred
    11,517
    14,157
    Tampa, FL
    Small screwdriver. Two, one on each side is easier. Easiest is a paint can opener.
    Just use whichever tool to pop the center part up an then the whole thing comes out. Just like the panels under the car or the ones under the hood.
    vvillovv and Mendel Leisk like this.
  11. jerrymildred
    11,517
    14,157
    Tampa, FL
    And I forgot to mention that I totally stole this idea from @Mendel Leisk. :LOL:
    Doug McC likes this.
  12. Mendel Leisk
    41,894
    Yeah where's my royalty check :whistle:
    Doug McC, vvillovv and Raytheeagle like this.
  13. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'd be suspicious of this service center.
    Funny how these extra services, beyond routine maintenance always seem to manifest sometime after the end of the Toyotacare period.
    I think in situations like this, your gut feeling isn't too bad to follow.
    I think I'd just be looking for a different service center for future maintenance.
  14. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I bet it's in the mail:p.
  15. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Thanks...
  16. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    No cooling fans there just 1 big battery pack, how did you get to the cooling fans to check them out? Thanks
  17. jerrymildred
    11,517
    14,157
    Tampa, FL
    Did you take off the panels at the right and left sides? It'll also help to take out the cable storage bin that's between the bumper and the battery. It will need a 10mm socket.
    Right side
    Left side.
    MTN and garglo like this.
  18. vvillovv
    vvillovv Senior Member
    4,329
    1,514
    NY
    @tedjohnson you also need to remove the plastic compartment just inside the hatch to see the fan and ducting. The plastic compartment where the EVSE-charger cable and the tire lug tools were stored from the factory. The fan is under that plastic piece. Just pull it up gently after removing the other pieces mentioned above.
    And when removing the cargo area floor just on top of the traction pack make sure to pull it straight back towards the bumper an inch or two before trying to lift it out of the cargo area.
  19. droplet
    droplet Junior Member
    Orange county, CA
    2019 Prius Prime
    Found a 2020 TSB for HV Battery Cooling System Maintenance at NHTSA (attached below).
    For the Prime just check/clean the fan filters next to the rear passenger seat.
    pasta4breakfast likes this.
  20. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    your filter should help you determine whether your fan can be getting dirty. The filter should be extremely easy to check. Although if you are receiving the vehicle second-hand, that is a different situation, since someone could have cleaned out the filter and not the fan.
