Wagging the tail
Discussion in 'Gen 3 Prius Accessories and Modifications' started by douglasjre, Apr 23, 2020.
  1. douglasjre
    douglasjre Senior Member
    2,177
    717
    Null, NL
    One of our Priuses has 245,000 mi. At 105 mph the back end wags very slightly like there's a worn sway arm bushing. The ball joints don't make any noise up front and the wagging of the tail is coming from the back. It's very slight and most people wouldn't notice it and it doesn't really become apparent until triple digit speeds. Anybody want to place a bet on which component is the culprit? And yes the tires are fully inflated 44 PSI 50 profile...
  2. Daigi_
    Daigi_ Active Member
    198
    427
    Hacienda Heights
    Maybe the sway bar you don't have.
    GM1915 ?
  3. frodoz737
    frodoz737 Top Wrench
    4,694
    2,495
    33
    Humm...a 2010 Prius with 245,000 miles on the clock going 105 mph is a little loose? My guess...the driver.
    Sorry, couldn't resist that one. ;)
    kenoarto likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,150
    Tampa, FL
    For a second there, I thought we were back on the COG forum. :LOL:
    I'm just guessing, but would expect the answer to be a combination of factors. One being the lack of sway bar mentioned already, but also weight distribution (about 60-40) along with aerodynamics and other factors I don't know anything about.
    douglasjre likes this.
  5. ETC(SS)
    7,139
    100-mph speeding tickets soar in California
    Hmmm....
    Gonna have to start trying to slow down not that the states are starting to miss all of that revenue.....
    I haven't noticed any tail wagging on my G3 at speed, and so I'm thinking that they don't actually need a sway bar while on the interstate and driving in a relatively straight line.
    Priuses are fairly unsophisticated in the back end because a trailing arm beam axle in the rear is as simple as is gets for a vehicle that doesn't have TONKA stamped on it.
    Still....there's other stuff back there that can be worn and set up an oscillation that would grow more pronounced at speed.
    TIRES....coil springs, shocks, hubs, etc...
    Tires and rims are statistically the most likely source.
    Just cause they're at 44 PSI,doesn't mean they're in good shape.
    Also the Prius comes stock with itty-bitty tires on itty-bitty wheels.
    That's what gives them their characteristic 'dolphin on skates' looks and handling characteristics.
    50-series tires suggest the possibility of aftermarket rims and tires and perhaps other non-OEM mods which opens the door wide to some other possibilities......
  6. ChapmanF
    18,146
    I think that I am seeing the floor through the sway-bar bolt holes in the photo above. So it would be fair to say that Prius rear axle doesn't have a sway bar, as of the moment the photo was taken. :)
    Just because people sometimes like to replace the factory one with a beefier one, doesn't mean there isn't one from the factory....
  7. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    The pictured twist beam also has drum brakes, which means it isn't a Gen 3 assembly. I think it was posted just as an example.
    And, the Gen 3 did not have a separate anti-roll bar from the factory. "Separate" because twist beam axles behave like giant anti-roll bars by design; the TRD and Cusco bars increase the roll stiffness by adding an external bar.
  8. ETC(SS)
    7,139
    I did post a G2 rear assy by mistake....not sure if there are many things that are different in the G3 other than the brakes.
    I'm still thinking that the sway bar isn't needed on the interstate because any place that you are able to clamp along at 100mph+.....is going to be relatively flat and straight........hardly uncommon in the southernmost Yankee state in the USA.
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    You need side splitters, I have them on mine snail prius and they work wonders at high speeds and cross winds.
  10. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    There are places in the US without actual speed limits.
    hkp and douglasjre like this.
  11. ETC(SS)
    7,139
    ...and interstate freeways are actually designed to safely handle very low volumes of traffic fairly high speeds.
    I seem to remember 90mph but do not pretend to have a cite.
    PSLs in TX are as high as 85, and there are actually locations where people drive Priuses that have no posted speed limits.
    .....the United States isn't the only planet on earth where people drive Priuses......and they actually SELL Priuses in locations where 100mph or higher speed limits are not unheard of.......
  12. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    In case it is an aerodynamic effect, you could try rolling down one or two windows on one side of the car (asymmetrically so not one on each side) to see if that affects the frequency or amplitude of the wagging.
  13. ChapmanF
    18,146
    You know, you caught me there. I remembered the sway bar in Gen 1 and 2, and I hadn't looked closely enough at my Gen 3 to notice it differed in that respect (even though I've been driving it for 4 years).
    Seems like the Gen 1 and 2 'beam' parts were a simpler C-shaped channel (facing aft) with the extra sway bar inside, but the Gen 3 part just has a larger and beefier shape for the beam itself.
  14. douglasjre
    2,177
    717
    Null, NL
    Priuscamper: did you know calling a member both dumb and stupid is considered abusive and violates Priuschat terms of service?
    I appreciate everyone's suggestions. I can't recall the configuration of the back end of the gen 3. I'll be under it tomorrow. Wheel bearings were quiet and the tires are under 6m old. The way is very slight. Others wouldn't notice it but it's more than the other 3rd gens I've driven. Gonna see tomorrow. Thanks for the suggestions!
    Johnny Cakes likes this.
  15. douglasjre
    2,177
    717
    Null, NL
    Just thought of something....another driver recently went up a curb damaging a front rim and tire. The rim and front tires were replaced as a set but the wheel alignment wasn't checked. If it's toed in a bit it would have the same feeling of oversteer right? Anybody here certified in chassis and suspension? I have A1 and diesel but not chassis.....
  16. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I've had my G3 over 100 (more than once), and it's been solid. Never had an alignment in the 6+ years now, but never had an incident that called it into question.
  17. PriusCamper
    PriusCamper Senior Member
    12,727
    5,146
    Pacific Northwest, USA
    Not where this life endangering person lives!!!
  18. hkp
    hkp Junior Member
    San Antonio
    Beat feet nerd, this is why you spent most of your life with you undies wedged up your butt.
  19. Johnny Cakes
    Johnny Cakes Senior Member
    1,045
    780
    Virginia, USA
    Apparently you didn't take moderator removing your original message as a clue......
  20. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Moderator should remove this post for illegal activity. Even when driver pretends not to see speed limit signs, there are always speed limits. None are ever 105 mph.
