Reverse Camera on Toyota Prius 2014 not working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by apt5020, Feb 15, 2015.
  1. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Help. For some odd reason my reverse camera isn't working. Any ideas what to check for? Where the fuse location, etc... Thanks
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Is the screen switching to the camera in reverse? Is the camera view blank?
    A little more info would be helpful.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    The good news, is you're still under your bumper to bumper warranty, so the worst case scenario is you drive in to your closest Toyota dealership and let them figure it out.
    jdcollins5 likes this.
  4. apt5020
    881
    1,294
    Prius City, CA
    Everything work fine except when I put it in R. Nothing show up on the screen. Was working until today. Weird, I had stereo, side mirrors, sills install all this time was fine until today.I was going to check the fuse but have no idea which one for camera. I have an appointment on Thursday with them
    #4 apt5020, Feb 15, 2015
  5. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Your Owner's Manual will give you a list of fuses.
  6. apt5020
    881
    1,294
    Prius City, CA
    Let me check. Weird thing when I put in reverse nothing change on display. Doesn't go blank or anything
  7. The Electric Me
    9,083
    5,801
    If you can figure it out before then great.
    But it might be a good idea just to let them fix it. Because if it happens to be a bigger problem, in other words...something is happening that is making the fuse blow...it may be to your advantage to have the problem documented with Toyota.
    That way, anything it might turn out to be, even if it grows in complication should be covered under your warranty.
  8. apt5020
    881
    1,294
    Prius City, CA
    Check all the fuse. They look good. If the fuse was dead. My radio would not display. This one confusing. The manual doesn't show anything regarding fuse for camera. Only thing that come close is the radio but that fuse is good. Let see what Toyota say on Thursday. Going to take day off for Chinese New Years
  9. apt5020
    881
    1,294
    Prius City, CA
    Fixed. Took the car into the dealer. They say because I did a lot of aftermarket mod they can't touch car. Took it to stereo place and they disconnect the AMP but that still did not work. Trace the backup camera and it was fully connected. Hook everything up and still doesn't work. I decide to pull the driver side panel out. Found out two wires was crossing each other. The pins was cross when my friend plug the connector back in. I made sure it was straight. Lucky it didn't break off. Put everything together and reverse now work. Really lucky day. Just a FYI for someone having reverse issue.
  10. John Ryou
    John Ryou Junior Member
    Richmond, VA
    “ I decide to pull the driver side panel out. Found out two wires was crossing each other. The pins was cross when my friend plug the connector back in. I made sure it was straight.”
    Which wires were crossed, I’m having the same problems after I attempted installing a head unit. I went back to the original, but now my reverse cam doesn’t work anymore. Please help
  11. John Ryou
    Richmond, VA
    I have a 2014 V
  12. buta17
    buta17 Junior Member
    wilminton
    2012 Aqua
    I
    exactly which connector was wrongly placed?
  13. gtavowww
    gtavowww New Member
    Valencia
    2018 Prius
    Did you solve this problem¿?, I installed a CC3 head unit and now the reverse camera is not working...
