2017 Prius side rear black panels film peeling off!
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by dmh1026, May 5, 2020.
  1. dmh1026
    dmh1026 Junior Member
    25
    Estero, FL
    Four Touring
    Has anyone else had this problem? The rear black panels behind the rear doors film is peeling off due to the sun I guess.
  2. Mendel Leisk
    41,824
    Yeah there's been a couple of threads. Maybe someone more 4th gen centric recalls specifics.
  3. krmcg
    2,592
    2,392
    Whittier, CA
    Some got the panels replaced bather dealer at no charge as a courtesy. Some purchased replacement panels and installed them themselves. It is worth asking your dealer for help, but I don't think that there is any actual recall from Toyota. There are threads with part numbers available on this site...
  4. dmh1026
    25
    Estero, FL
    Four Touring
    Thanks!
  5. jcs012
    jcs012 Junior Member
    California, USA
    Two Eco
    Oh God, this is the same thing happening to my Prius! Glad to know I'm not alone and that they can be replaced easily.
  6. aznbokchoy
    aznbokchoy New Member
    Hacienda Heights, CA
    Three Touring
    Can I just spray paint a clear coat after I sand all the peeling down?
  7. krmcg
    2,592
    2,392
    Whittier, CA
    Yes. But I think that you will have to spray a color first. sanding the blemished areas would remove the color and make it look mottled.
  8. Esolis
    Esolis New Member
    Wildomar CA
    Same two mine, both rear panels start peeling. I took the car to Toyota Riverside but they said these parts are only cover in the first 36000 miles; extended warranty doesn't cover stetic defects. Replacing both panels is around $400.00
  9. krmcg
    2,592
    2,392
    Whittier, CA
    Panels can be found on eBay for $50 to $75 dollars each. Easy to remove the old and install the replacements...
  10. bethanyhouse8
    bethanyhouse8 New Member
    lake county ca
    Both black panels peeling 1 inch from top down at the same time. I paid $850 plus to have car spray protection. I filed the warranty thinking it was covered for 5 yrs and the company said it wasn't covered. Makes my 2016 prius four look like a damaged car. Horrible. I don't know if Toyota will replace since it's a factory problem.
  11. bethanyhouse8
    lake county ca
    After being rejected by car protection and so upset I started noticing other prius four like mine when passing by they are peeling also. We need to complain to Totota. It's a issue and it's not our fault from the sun.
  12. Haji1987
    Haji1987 Junior Member
    24
    17
    Los Angeles
    Three Touring
    I just noticed mine chipping just like that on one side last week. 2017 prius 3 touring and I am at 38k miles. I went to the dealership today and got turned down because i was past 36k miles. Looks like this is a common problem. This is so annoying.
  13. Karen Lynn
    Karen Lynn Junior Member
    San Francisco
    Three Touring
    I'm having the exact same issue with my 2016 Prius. I have the extended warranty. I wonder if it will be covered?
  14. KaiKai
    KaiKai New Member
    Inland Empire, California
    I called to the Toyota Customer Support after being rejected at the dealership. Customer service told me they currently do not have solution for this, but will forward my case to upper management. I think if we all call and complaint this issue to Toyota, maybe they will finally do something about it.
  15. morningsun
    morningsun Junior Member
    My sister and I both bought a Prius Prime 2017 model during 2018 and both has this issue. She lives in Vegas and I live in LA. My has 37K miles and my sister has 25K miles. Doesn't seem like heat is the cause here. I also called Toyota Customer Support and they couldn't provide any help and can't even point me to a department where I can start some sort of campaign to have this recall. Totally agree, it makes a 3 year car look so dam old. We need to petition to have this taken care of.
  16. Mendel Leisk
    41,824
    You seriously thought they might help with that?
  17. Sophia G.
    Sophia G. New Member
    Dallas
    What is this panel called, so I can look for it? Thanks
  18. Sophia G.
    Dallas
    Just found this. Looks pretty simple to replace, now I just have to find the part.
    AJ11235 likes this.
  19. dmh1026
    25
    Estero, FL
    Four Touring
    Update: I ordered the replacements and it looks like a new one! Have to replace the silver wheel inserts next.
  20. dmh1026
    25
    Estero, FL
    Four Touring
