second 12 volt battery - 2020 edition
Discussion in 'Gen 3 Prius Main Forum' started by geedub, Apr 27, 2020.
  1. ChapmanF
    18,959
    If we're talking about a purpose-built refrigerator that uses about one amp-hour every hour to keep the food cool, and the battery is forty-five amp hours, and division still works the way Mrs. Silver taught me, the OP might end up having no problem keeping the food cold even through a gap of several hours or less between having the car READY.
    It's certainly not off the scale of feasibility; it's the kind of thing you could set up, keep a meter around, observe for a while, and escalate to something more complicated if experience warrants.
    If I did it, I would have a jump pack in the glove box to avoid any frustration if something didn't go according to plan. But I have that anyway. I would also want the refrigerator to have an automatic preserve-the-battery cutoff if the voltage gets low ... and it does.
    Minima Domum and geedub like this.
  2. geedub
    geedub Member
    127
    82
    Flordia
    Thanks. I'm stilling thinking about the Dometic portable battery or maybe similar, but I haven't ruled out the 2nd 12 volt.
  3. geedub
    geedub Member
    127
    82
    Flordia
    In addition to the fridge I'll want to run a 115v fan rated at .6 amp (swamp cooler), a laptop, and I recharge my phone and bluetooth speakers. It doesn't seem like much...
  4. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    As Chapman said, all of those things will 'work' with the standard battery, it's just down to your individual requirements, how long each device is on, how often you have the car in 'ready mode' etc as to wether you'll need to upgrade the battery or add a second one.
    It should be pretty obvious if you start using the devices and get a flat battery before you're finished using the devices then you need a bigger battery.
    geedub likes this.
  5. ChapmanF
    18,959
    The pragmatic approach in a nutshell, right there. :)
    geedub likes this.
  6. geedub
    geedub Member
    127
    82
    Flordia
    What confuses me is the idea that the 12v would go flat with the car in ready. How could it?
  7. ChapmanF
    18,959
    Oh, in READY it won't.
    We've all been thinking about how long you might get away with leaving the car unattended and not READY, and still come back to safe cold food.
    geedub likes this.
  8. geedub
    geedub Member
    127
    82
    Flordia
    I'm hoping that if I did that, the Dometic battery management system would turn off the fridge prior to draining the battery, as it's advertised to do. From what I've read, the fridge is very well insulated, so hopefully it could hold food safely without running for an hour or so.
  9. ChapmanF
    18,959
    Right. And then the pragmatic conclusion would be that you need more battery if you want to be away that long. But I think you'll probably get comfortable run times.
    An important consideration is how to know if the fridge stopped, and what the inside temps got to, and for how long.
    Fancy solution is a datalogging thermometer. Seems like these new Dometics have some kind of feature where they can alert you on your phone (I guess provided they have power and cell coverage). I would almost be more interested in knowing that it has a small backup battery to just keep logging the temperature while off, and show me a graph when I got back.
    I had a colleague who used a low-tech solution: if he was going out of town for any length of time, he would leave a coin or something on top of an ice cube in the ice cube tray in the freezer. If he came home and the coin was in the ice cube, he would know stuff had thawed, even if power came back on after and looked ok when he got home.
    I guess it's not quite as complicated a problem with the Dometic, because if it turns off at some point while you're away, it's not going to turn back on and look all innocent before you return.
    Minima Domum likes this.
  10. Minima Domum
    Minima Domum Member
    84
    147
    Adelaide, Australia
    i-Tech
    The battery could technically go flat in 'ready mode', if you were drawing more power than the DC-DC charger can provide (around 80a I think?) for a period of time, but that's not gonna happen with the devices you've listed.
    I've done it before while driving in cars with big sound systems and small alternators
    geedub likes this.
  11. geedub
    geedub Member
    127
    82
    Flordia
    Battery porn![​IMG]
    LINK (I don't benefit from sales of super sexy portable power stations)
    I'm researching battery power stations that provide the benefits of an auxiliary 12 volt, a jump pack, inverter, etc.
    Here's one at the lower end of the price spectrum: LINK The biggest downside of this one compared to the Dometic is that you can't charge it while it's in operation.
  12. geedub
    geedub Member
    127
    82
    Flordia
    The sexy 1500W power station above is nice at $2000, I guess, but it's L-ion and I'm looking for LifePO4 (more stable, 2000 cycles). I found another beauty which IS LifePO4, and it can be had at one site for $1300 with free shipping. On the manufacturers page it's available for $1640. This one has a 1000W pure sine wave inverter. We're getting closer....
  13. geedub
    geedub Member
    127
    82
    Flordia
    Something scary happened today. My car shut itself off. This was about an hour after installing a 12 volt socket directly to the battery for the purpose of running my new Dometic fridge. When this happened I was running the fridge, which had been going for two days already. I had a 12 volt splitter plugged into the front console outlet, but nothing connected to it. I had a 300W inverter plugged into the center storage compartment, and it was running my laptop and a fan. The fan has 115 volt, .6A on the label and was set to the highest speed.
    I disconnected everything and restarted the car without any issues. Next I plugged the fridge back into the dedicated outlet and waited for it to come back up to temp. When it got back down to 39ยบ I reconnected the inverter and started the fan and laptop again. Since then the car has restarted and charged normally three times.
    Just before the car shut off I noticed the fan speed was fluctuating. It's pretty windy so I didn't notice it at first, but in retrospect it wasn't operating normally at the time. Now it's running steadily.
    Any thoughts?
  14. ASRDogman
    ASRDogman Senior Member
    8,045
    4,077
    I think you are playing with fire.
    And you are drawing too much power from a battery that wasn't designed for it.
    Thus, the 2nd battery......
    Keep that jump pack charged and handy...and set money aside for a new 12v battery,
    sooner than you think....:)
  15. geedub
    geedub Member
    127
    82
    Flordia
    Considering what happened I can see your point. On the other hand, it sure doesn't seem like I was drawing much power...
  16. ChapmanF
    18,959
    Shut off from READY? Or from ACC or ON?
  17. geedub
    geedub Member
    127
    82
    Flordia
    Ready. It's been operating normally for a few hours now with fan, laptop and fridge.
  18. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    There is an in-line fuse for the socket, right? And you are using sufficient gauge wire, right?
    Unless I've been taught wrong, I don't think that's how it works. When the car is in the READY position, you draw 12v from the high voltage battery through a DC to DC converter. The 12v battery is irrelevant and charging it is just another load for the high voltage battery. If you disconnected the 12v battery while the car was in ready mode, I think you'd still have 12v to everything else. A second battery would be important in ACC mode because then it is solely responsible for delivering 12v as the high voltage battery is not involved.
    Yes, what does "shut itself off" mean?
  19. ASRDogman
    8,045
    4,077
    The converter only outputs a certain amount of amps. Which is probably enough to run the computers
    and accessories, and charge the 12v battery. When you put other things on it, you are overloading it.
  20. geedub
    geedub Member
    127
    82
    Flordia
    Shut off as in black dashboard, all power stopped.
    I installed this: LINK
