Replaced pads and rotors, and now I've got "the codes"
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Beardley, May 24, 2020.
  1. Beardley
    Beardley New Member
    New York
    Given the current Covid situation, I decided to take on a brake service on my wife's Prime. 2017, about 50k miles, and harsh upstate winters left her rotors in terrible shape. I didn't realize there were additional procedures because of the other safety systems, so now I've got the ABS codes. . . I saw a number of entries about jumping the ODB II port, but didn't see any for the the 4th gen. Just wanted to confirm its the same 2 pins (4 and 13). Any advise would be greatly apreciated!
    John
  2. Elektroingenieur
    2,515
    3,287
    Three Touring
    I’ve never had a reason to try it, but it’s not clear to me that connecting terminals CG (4) and TC (13) of the DLC3 (OBD II) connector has any brake-related function on fourth-generation Prius or Prius Prime cars.
    The Repair Manual (more info) mentions that method for diagnosing the airbag system, but not for the electronically controlled brake system, for which there are no “When not Using the Techstream” diagnostic instructions like those in the manuals for earlier models. The brake-related diagnostic trouble codes (DTCs) are also no longer listed with two-digit blink codes.
    You may need a Toyota Techstream diagnostic system, or equivalent, for diagnosis, and definitely for complete bleeding of the brake system. If you just need to bleed the brake lines, however, there is a procedure that supposedly doesn’t require Techstream in the Repair Manual under Brake: Brake System (Other): Brake Fluid: Bleeding. This might not clear DTCs that have already been stored, however.
  3. Mendel Leisk
    41,897
    Apart from the lights/codes, how are the brakes performing?
    My drill:
    1. Disconnect 12 volt neg cable first.
    2. When done pump brake pedal multiple times.
    3. Reconnect neg cable. (There might be some "oddities" after, unusual revving during start up, two or three occurrences thus.
    If the brakes seem fine, it might just require a dealership visit and a reset via Techstream, but I don't really know.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Have you tried disconnecting the 12 volt battery since the lights came on?
  5. Beardley
    Beardley New Member
    New York
    I did a brief disconnect of the battery, but the codes persisted. (30 secondsish) I'll try longer and see if I get any positive results. I didn't disconnect the brake lines, so it shouldn't require any bleeding. Just did the typical compression of the caliper piston. I haven't taken it down the road yet, but my driveway tests say, it stops. Pretty easily, and all 4 appear to be engaging as I can see marking on the fresh rotors.
  6. Mendel Leisk
    41,897
    Failing to do the above, then starting the car, can cause codes. The car detects excessive brake travel.
  7. Beardley
    Beardley New Member
    New York
    Yup. thats where I'm at. I presume at this point, my only recourse is a trip to Toyota?
  8. ChapmanF
    18,537
    It's not a matter of "the" ABS codes, it's about which of the hundred or so possibilities are the ones you've got. If Gen 4 no longer has the blink-em-out-on-dash-lights option, it'll take a code reader to find that out.
    But brakes are common equipment in cars, so common code readers should be able to display those codes.
  9. Mendel Leisk
    41,897
    Dr Prius and a Bluetooth adapter is one of the cheapest options to read codes, maybe $10 for app and $20 for adapter. It claims to read codes, haven't tried it yet.
  10. Beardley
    Beardley New Member
    New York
    I guess I'll be the test mule. I ordered the OBD II adapter, and it should be here Wednesday. Good thing my wife is working from home. . .
  11. Beardley
    Beardley New Member
    New York
    Reporting back, I was able to clear the codes via Dr.Prius. Strangely it wasn't able to read any error codes, but when I clicked "clear engine codes" in the app, it cleared everything on screen. Took her for a spin, bedded in the pads and everything is back to nominal. Thanks for the advise!
  12. Mendel Leisk
    41,897
    ScanGuageII is another item that might have read the codes, just fyi. I've had one of those for about a decade, all hardware, no phone involved. I do recall reading codes with it before. Vaguely... :oops:
    They're a little pricey, and I had problems having one constantly hooked up, it was apparently causing (wait for it) brake errors, warning lights, and work-to-rule brake behaviour. At suggestion of dealership I removed it, and problem did not reoccur, so I guess they nailed it. I do use it sporadically, if I want to test something.
  13. OptimalPrime
    OptimalPrime Member
    161
    95
    Keene/Nashua
    I recently saw my old ScanGaugeII kicking around in a box in storage. It was pretty hot technology when it came out.
    Nowadays, I use a scanner I paid $188 for on Amazon a few months ago, though of course after the return period, I saw it on sale for $138. It successfully got my 2017 Prime to pair up with a factory-fresh blank Toyota key fob to the after a little fiddling with different menu choices and the timing of sticking the old and new new fobs on the start button during the procedure. So, it mostly paid for itself just from doing that, seeing as the dealer and locksmiths all wanted about $130 to add a new fob to the car's list of valid fobs. I was the guy whose fob self-released from the physical key that was all that was left on my key ring when my car was a few weeks old, and I'd been living dangerously with only one fob for almost 5 years! Back to having two working fobs now.
    My particular scanner, a Launch Creader Elite 205, comes with 2 lifetime free "system diagnostics" packages and 5 lifetime free "reset features" beyond all the usual OBDII stuff, where it can reset any ODBII code, read and graph tons of parameters in real time, capture freeze frames, email you reports, etc. The included diagnostics are for ABS, and SRS (airbags). You get to choose 5 out of 15 or 20 reset topics. I took IMMO (fob to car matching), TPMS, ABS bleeding, SAS (steering angle sensor/calibration) and I think Electronic Parking Brake (Prime doesn't have one, but other cars in my family do). Or maybe I took something else as the last one.
    Don't waste choices on things like Oil Reset that you can already do via the car menus. You can buy more diagnostics packages and reset features for something like $20/yr each. Ouch. But this was a good compromise at the time, a safe intro to advanced scanners, compared to a $500 scanner, $1000 scanner, or $1500 scanner. I think my next one will be $500ish. The Xtool D8 is on sale now for $559, so maybe it will break below $500 around Black Friday. Or maybe I'll grab the cheaper D7 instead. With ones like those, you're no longer at the mercy of mechanics or dealers for diagnosis of even deeply hidden things in all sorts of computer modules in the car, that never surface to a level where they'd throw an ODBII code.
    As luck would have it, one of the diagnostic suites you have no choice but to take, is all about ABS and the brakes. While my Prime came up clean on it, it was really useful on my old Gen2: The parking-brake position switch had fallen off but still worked when I pressed it manually, plus a handful of non-OBDII brake/ABS codes were found to have been set (likely in the distant past) despite zero actual driving problems, including things like "Yaw sensor value out of range", "Roll sensor data missing" to paraphrase. I reset them all, and they never returned.
  14. DC_2004_Prius
    DC_2004_Prius Member
    75
    28
    DC Area
    Hello - reviving this old thread w/similar issue. Removed calipers/pads lubed slide pins etc on a gen 4 2017 prius in my family that doesn't get driven enough and there as some minor brake rubbing. (this isn't a prime but has same/similar brakes as 4th gen and this thread is similar to my problem).
    Anyway - didn't disconnect 12V (mistake!) but remembered to take the key away out of range so brake actuator/pressure pump wouldn't kick in - but on the 4th wheel (front) forgot and approached car and it began to buzz/pressurize with caliper off the pads - immediately ran away but had to do a little bit of piston compression with a big c clamp (piston didn't come all the way out just a half inch or so of extension) - no issues. put it all back together - then made my second mistake forgot to pump brakes before starting up - and then got the christmas tree of lights/malfunctions. "Braking Power Low Stop in a safe place see owner's manual,antilock brake system malfunction visit your dealer, lane departure alert malfunction visit your dealer, pre-collision system malfunction visit your dealer, braking power low visit your dealer," etc.
    drove it a little in the neighborhood and it's clear there is no regen braking - only pads - which all work fine btw. went back and double checked no wheel/speed/abs sensors were knocked loose or disconnected. brake fluid level looks normal, etc. I guess there's a chance some major component failed conincidentally when I started it back up/etc. - but I'm pretty sure it's just the temporary lowering of pressure and not pumping pedal before restart - so system "thinks" there was a big loss of braking/fluid pressure.
    long and short my brakes are fine and all working but no regen braking is happening - but the brake system errors that were produced due to the minor piston push out and forgetting to pressurize the system with pedal pumps on re-start - will not go away. and i'm clearly in some kind of "limp mode".
    i pulled negative battery cable (battery up front) left off for hours.
    cleared codes in dr. prius and torque pro app - no dice. "malfunction" major errors persist. limp mode persists.
    thanks - sorry for the wordy post.
    can i go out and do some short/low speed "drive cycles " to get the system to scan/learn that all is in fact well and overwrite those error codes?
    i saw the "jumper between first row 4th and send row 5th pins on obd2 port" posts and videos but all seem to be for gen 3 or earlier prius. I don't want to try that without confirmation that it will clear codes on this 4th gen 2017 prius.
    Is there anything I can do to clear these errors/go back in time and have the system start up and assess normally - and find that in fact brake system/pressure is fine?. Any other monitoring software that is quick cheap and will work with my bluetooth obd2 dongle? Can Advance Auto or any other store do a quick "clear codes" that will clear these?
    I don't have techstream - and though it might be useful to have for a multi prius family - I don't have time and don't want to do this atm but fear this is what I'll have to do to get this car back to normal.
    Is there anyone in the DC/NOVA area that has techstream and would lend/rent it to me to get in real quick and reset these errors?
    Thanks for any advice/hints on a procedure/jumper/way to get into and reset those system errors. thanks!
