second 12 volt battery - 2020 edition
Discussion in 'Gen 3 Prius Main Forum' started by geedub, Apr 27, 2020.
  1. ChapmanF
    18,959
    Been there since Gen 1. I think there might be warmer climes that don't get them. Gen 1 (and maybe Gen 2) split it into two electric elements, one of which was always there and the other just in cool markets. In Gen 3 there's just one element (capable of three levels of output, you can play in Techstream).
  2. ChapmanF
    18,959
    Right, it's better if they publish something like this, as Engel does:
    One could play with the 61kWh/annum and make it look like 0.54 Ah/h at 12.8 volts, but I question it; too low. We can roughly compare the CFX3 35 and Engel figures above for around 90℉ ambient and 39℉ inside, but to get that much lower number for the CFX 28, I would have to guess they picked less challenging temperatures.
    geedub likes this.
  3. geedub
    geedub Member
    127
    82
    Flordia
    Hypothetically speaking, let's say I was so swamp-addled that I was considering installing an inverter. Having read that 1000W was the maximum recommended for a Prius, is the excess capacity of an 1100 or 1500W unit an issue inherently or only if that extra power is drawn upon?
    I guess I won't be happy until I burn up in a fiery Pruis-camping incident...
    kazbach likes this.
  4. ChapmanF
    18,959
    It's hard to be sure what's driving you in that direction. Around a kilowatt is as much as you're going to get. You can hang excess capacity out there, but when it's "drawn upon", it will not be forthcoming. You won't get a fiery camping incident (assuming you're competent about wiring and fusing), you will just see the DC/DC converter output at first droop some (Bob Wilson posted results some years ago) or, if aggravated, code and turn off.
    If you put in an "1100 watt" rated unit because you found happened to find a better deal on one than a "1000 watt" one, well sure, that's understandable, as would be a "1500 watt" one if that's how it happened. But I'd advise if you're thinking to actually draw those levels of power in practice, maybe wait around and see what products Randy Bryan is going to offer through his recently-reconstituted company, for connection to the traction battery.
    As I understand it, it's usually the case that an inverter won't see its best efficiency at low fractional loads ... so if you're choosing between a 1000 watt and a 1500 watt inverter and it's mostly going to run your laptop, neither one is going to hurt anything, but the bigger one will be wasting more juice.
    geedub likes this.
  5. geedub
    geedub Member
    127
    82
    Flordia
    Cool. Thanks. Exactly what I was wondering.
  6. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "Cool. Thanks. Exactly what I was wondering."
    Yeah, he's kinda good that way... ;)
  7. geedub
    geedub Member
    127
    82
    Flordia
    Where do I send the check?
  8. geedub
    geedub Member
    127
    82
    Flordia
    Time for more fun with electricity!
    I installed an inverter as per Terrell's instructions. I got a 1200W because the price was good, and it has a remote switch and usb outlet. With the fans and laptop I'm drawing a bit over 200W and I occasionally charge a cordless drill battery, bug zapper or bluetooth speaker. I could have easily gotten by with a smaller unit but wanted to leave room to expand a little.
    Now I'm thinking about installing it semi-permanently in the storage box above the spare tire as I've seen others do. I'm a little concerned about heat from the inverter so I got two usb cooling fans with the intention of installing them in the storage box. With the fans plugged into the inverter they would switch on/off with the unit.
    I installed the remote switch in the tail light cover above the 12v.
    I don't suppose the storage box is very airtight but what about adding a vent grill for fresh air from the cabin? The lid on the small storage area opposite the 12v battery seems like it could work. The fans would exhaust out of the box.
    The whole plan looks perfect! Right?:D
  9. ChapmanF
    18,959
    Mine just sits on the spare tire, underneath the storage box, so it's completely out of the way. The spare tire angles forward a bit, so there's some clear height at the forward part. That space under there is better ventilated than the box itself; the cooling air for the traction battery passes under the box on its way to the exit vents hidden by the bumper cover. I didn't add any extra fans; there is one in the inverter itself that will start if it wants to. I have never had it complain about overheating. If it does, I can think about further measures then.
    For accessibility, I just used the end of a three-outlet extension cord, and ran the remote circuit up to the dash.
    kazbach, kenoarto and geedub like this.
  10. geedub
    geedub Member
    127
    82
    Flordia
    My inverter must be larger. I can fit it in the spare if I remove the jack assembly. That's fine. I like the idea of not using the storage bin.
    Is it kosher to ground the inverter to one of the bolts that hold the drive battery assembly to the deck? If I need to ground to the battery I'll need to get a longer cable.
    Also, is it okay to connect the positive cable to the upward facing bolt on the battery?
    #110 geedub, Jun 5, 2020
  11. ChapmanF
    18,959
    True, I didn't buy a 1200W for an application where I knew 1000 would be pushing it.
    You can ground to whatever good ground point is near your location. The wiring diagram shows where all the designed ground points are. Those use specially formed screws to function best as electrical grounds. If there isn't one nearby, an ordinary bolt that mechanically mounts something can be ok, depending on the paint situation. You might check that the conductivity is good.
    Not that I would recommend. If you examine the positive battery clamp carefully, you'll see there is a fusible link in it, and the end of that link where you want to attach is the end down over the side of the battery where the cable attaches to it. That puts you one fuse drop less far from the DC/DC converter at the front of the car, which is where your power is coming from (you are not planning to run a 1200W inverter without your car in READY, I trust), and better protects from the battery's fault current capacity in case of damage to your wiring.
    Speaking of damage to your wiring, be sure to protect it from pinching or abrasion anywhere it goes under the storage box edges, over the edge of the spare tire rim, etc.
    If you look in this image, the fat wire coming up from behind (encased in black loom), joining to the right (common) side of the MAXI fuse block, is what's coming from the main cable side of the battery clamp. The takeoff from the 80A fuse is going to the inverter, the other 20A one is feeding the other stuff. (Photo was taken before adding the air compressor, fed by another 30A fuse in the MAXI block.)
    geedub likes this.
  12. geedub
    geedub Member
    127
    82
    Flordia
  13. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    I grounded the inverter to a tie-down bolt. But I hooked the negative terminal of the inverter to the negative post of the 12V battery. I want the most unrestricted power to be able to flow as possible, without wondering whether the bolt on the body is enough.
    Yes, you can (and in my mind) should connect the positive terminal of the inverter to the positive terminal of the battery, for the same reason as above. BUT, add a 100A fuse to protect the battery. If you connect to the bolt of the grey plastic you are skipping the 140A fuse that's built into the positive battery connection, so you're hooked directly to the DC/DC inverter, which is not a good idea, unless you have a fuse between your 1200W inverter and the DC/DC inverter. I like to think of the 12V battery as a "sump" which can keep current happy.
    In the end, the power is coming from the DC/DC inverter; you should be fine, until that one time you push things a little too far...
  14. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Because I push my inverter pretty much to the max (20 min for the rice cooker, 5 min for the microwave, and when connected to things in our house, hours), I bring the inverter out from the storage box, to give it all the air circulation it can get. The fans in the inverter usually ramp up when I'm using it.
    Very neat remote switch!
    kenoarto likes this.
  15. Terrell
    Terrell Old-Timer
    326
    169
    Wisconsin
    Very neat looking holes! How do you cut them?
  16. ChapmanF
    18,959
    When you do that, you are adding the battery negative post and terminal, its cable, and the bolt on the body where that cable attaches, into the length of the path between you and the DC/DC converter up front, which is where your power is coming from.
    Again, doing so puts your connection farther from the power.
    You may not have spotted that there already is a high-current fuse link both at the battery and at the converter end.
    Right in between those two fuse links is the happiest place to add your tap: (a) you are protected against excessive fault currents from both ends; (b) you are not adding the fuse drop of the 140 A fuse into the power path from the converter to your inverter input.
    geedub likes this.
  17. geedub
    geedub Member
    127
    82
    Flordia
    I followed your video exactly so I have the 100A fuse. I also grounded to the same screw you used.
    Did you know that Genuinedealz keeps the specs from your video on file? I only had to call and say that I was wiring an inverter for my Prius and they knew what was needed. Only thing is that they don't have welding cable.
  18. geedub
    geedub Member
    127
    82
    Flordia
    I use a spade/paddle bit at very slow rpm while holding the drill firmly and applying light pressure to the plastic. I didn't get all the way through with the bit before it dug in too much, and finished with a utility knife. The plastic is soft so after making the two holes I connected them with the razor.
  19. geedub
    geedub Member
    127
    82
    Flordia
    This is what I love about the internet; I can find great information without having to learn things...
  20. geedub
    geedub Member
    127
    82
    Flordia
    Chapman, do you agree with adding a fuse to the positive cable of the inverter?
    I'm planning on buying a multi-meter to test the resistance between the bolt I would like to run the negative inverter cable to, and the negative post on the battery. If my partial interweb-based learning is correct, this will identify whether it's a good ground point.
