Horrible engine noise in P, D, B, and R, but not N
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kpmartin, Jun 6, 2020.
  1. ChapmanF
    18,501
    Why, yes ... yes, it should. It, um, should be showing more air going in when the throttle opens more or the engine works harder, and less when it doesn't.
    There's a possibility that "Car Scanner on iOS" just doesn't know how to get your MAF reading, but that seems a remote possibility. MAF reading is a standard PID that any self-respecting car scanner should be able to read.
    That leaves the possibility that your ECM is getting a fixed unchanging reading from the MAF sensor. That would mean your ECM has no clue how much fuel to inject to make a combustible mixture, which will result in horrible noises (which you have) and codes about misfires (which you have) and about poor engine power (which you have, P3190, which has the MAF sensor as one of its suspect areas) and failure to start (P0A0F, likewise).
    A voltmeter on the MAF sensor output would answer some questions the audience following at home surely have.
    It's odd that you don't have (or haven't reported) any of the codes specifically reserved for a wacked-out MAF sensor (P0100, P0102, P0103). But those codes are looking for a sensor output that's either below 0.2 V or above 4.9 V, so clearly out of range.
    Yours just looks like it's humming along at a never-ever-changing, oh, 250 kg/hour, eyeballing your graph. Toyota gives their ranges in g/sec, so 250 kg/hour is around 69 g/sec, which is right in the expected range of MAF values. So no P010x codes.
    It sure isn't useful though. If your ECM had a way of knowing how much air was going in, your engine would run better.
    There's a cute note in the repair manual next to the expected range (1.0 to 270.0 g/sec). The note says "The value must be changed when the throttle valve is opened or closed."
  2. kpmartin
    kpmartin Junior Member
    LOL... whelp, one thing it could be is forgetting to plug the MAF back in after having taken the assembly apart for the third time today. Sigh.
  3. rjparker
    10,456
    6,560
    Here are three shots of my Prius maf and rpm using Car Scanner for IOS. Is it possible your scale units are set wrong in the app? (Edit: These were taken with "forced charging" in the driveway - zero speed - first two with changed throttle position)
    0DDA9258-DB7C-4E25-ADCE-AAF3ED127227.png 592540FD-C39D-48A6-B005-3E3269B2D0BC.png D2E936B3-1522-4FAD-9770-ECA0FA6F9835.png
    #23 rjparker, Jun 21, 2020
  4. ChapmanF
    18,501
    Hmm ... while the range given in the manual is from 1 g/sec minimum to 270 g/sec all-out, if rjparker's readings were all around 7 g/sec (presumably idling, or just revving the engine in the driveway), then a fixed 69 g/sec reading out of the sketchy one would look to the ECM like a moderate respectable load. Well, about ten times what it should be at idle. Which would make the ECM inject a lot more fuel than it ought to.
  5. kpmartin
    Well, plugging back in the MAF is helpful. So took the car for it's first real post-throttle body cleaning and it's smoother... it's moved from Warner Brothers cartoon jalopy to basic "this thing is running really rough"... much less overall harsh noise, but still obviously wrong.
    After that short drive, I pulled the codes: P0102 and P0113 (thanks to me having driven with the MAF unplugged last night) and P0300,P0301,P0303,P0304.
    Cleared codes and drove again today, still rough but not as horrible... pulled codes: P0304 (this bugger never seems to go away), and P0138 "Heated oxygen sensor (HO2S) 2, bank 1 - high voltage" which I don't recall ever seeing.
    Am I right that swapping coils around (or completely replacing the coils) is the only way to verify a bad coil? Is there no way to test ohms across the coil or anything like that?
    Any thoughts on P0138?
  6. kpmartin
    Here's the O2 sensors 1 and 2 for this morning's drive... notice that there's no data for O2S2 trim... should there be?
  7. kpmartin
    Possible progress: I swapped #4 coil with #2 (which freakishly seems to never give me codes, tho all the others have)... clear codes... start it up and a bit of a rough start and some blue smoke (so unburned oil/gas in #4 maybe?)... then off for a drive.
    Had the rough-but-not-quite-jalopy feel still (maybe slightly rougher) and got the following codes from my ~8 minutes drive:
    P0138 (again), and P0300, P0302, and P0304. I think this is good news... I seem to never get P0302, so that seems like it must be a bad coil. Maybe P0304 was because it was gloppy in there?
    Anyway, I think I might have another coil to try, so I'm going to give that a go.
  8. kpmartin
    And YES! Replaced the coil in #2 and it's running freakishly well. Took it for a much longer drive, including daring to go on the freeway; it ran very nicely. Not feeling any of the shudder or weakness under load right now. Check engine light remained off even though it was about a 20 minute drive. However, there is a pending P0420, which I've had basically for years and is the one that originally made me think I've got cat troubles.
    So, pending P0420, and prior to that I got P0138 a couple of times. Oh, and still not seeing any data for "O2S2 trim". Recommendations?
    Also, how amazing is this car that it was in such bad shape (see initial video) and when things have been corrected it's basically fine? Wow.
    #28 kpmartin, Jun 21, 2020
  9. ChapmanF
    18,501
    While I was home from college one summer, I got an unexpected call from a classmate from a different state. She was in her VW Bug with her brother and they were making a multi-state road trip and the Bug had just then started shaking like the fenders would fall off, and they looked in our college directory to see if they knew anybody in the state they were in, and found they were only half an hour from me. (Our college gave out directories with our home addresses and phone numbers, how freaky is that?)
    So they pulled into my driveway in full cartoon jalopy mode shaking and lurching and jumping and banging, and I was like "this car I'm driving I pretty much built, but I'm sure there's nothing I can do for yours, we'll go straight to the bug place". And I got in my car and we made a slow comical procession down to the specialty mechanic.
    And he put on some new points and plug wires and it was just fine. Which I could so have done by myself, but I had let myself be too alarmed by all the racket it was making to even use my head and think it might be simple stuff.
    #29 ChapmanF, Jun 21, 2020
    kpmartin likes this.
  10. oldtechaa
    oldtechaa Active Member
    336
    225
    NZ
    2013 Prius Alpha
    I love the process of elimination here. This is definitely how it should be done, and sounds like you really know what you're doing with diagnosis. Way better than I could ever do at diagnosis. (y)
    kpmartin and Diemaster like this.
  11. kpmartin
    Yeah, it seems to be holding up OK. :)
  12. kpmartin
    I'd still be interested to hear if anyone has any good ideas about either of the following remaining issues:
    • P0420s, and prior to that I got P0138 a couple of times
    • Not seeing any data over ODBII for "O2S2 trim"
  13. ChapmanF
    18,501
    I wonder if something is labeled funny or defined funny in that app.
    The car has a sensor 1 and a sensor 2, and they should both be giving sensor readings, and then there should also be a fuel trim %, which is another number computed by the ECU based on the sensor readings and the injection timings the ECU has been generating. In fact there should be a short term and a long term trim. But the trim isn't really something from a single sensor, if you see what I mean.
    I wouldn't be astonished if whoever it was collected the reverse-engineered Prius PIDs and populated that app with them maybe got one or two things mixed up.
    Have you plugged the same app in to somebody else's Prius and seen a different result?
