New tire suggestions
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by tchan2700, Jun 27, 2020.
  1. tchan2700
    tchan2700 Junior Member
    30
    I currently have the OEM Bridgestone Ecopia EP422 and I think they are very loud. America's tire suggested the Michelin Defenders and said they were were quieter. Does anyone have any experience with the Defenders? I know the MPG are not as good as the Ecopias but I'll choose less noise over a few MGP any day.
  2. Mendel Leisk
    41,640
    One thing, tires tend to get noisier as they age. How many miles on your current tires?
  3. tchan2700
    30
    I've got 40k on them . I felt they were noisy when new also.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    Really pleased with these:
    https://www.tirerack.com/tires/tires.jsp?message=singleSize&tireMake=Yokohama&tireModel=AVID+Ascend+GT&cameFrom=selectOE&partnum=965HR5ASCGT
    I got them in May last year. The original Toyo Nanos only had 24,803 miles and were down to 5/32" of tread. Would have been OK for a while, but we were heading for the Colorado Rockies and it was going to be about a 6,000 mile trip and I wanted to be ready in case we got any snow up there. (We did, but not heavy.)
    I have put almost 20k miles on the GTs since then. Tread is down to 9/32" from the initial 12/32". Wet performance is exceptional. Noise is not an issue, but I have no idea how they compare to the Defenders. They are no louder than the Nanos and might be a little quieter. Hard to tell.
    m8547 likes this.
  5. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    The Michelin X-Tour is sold at warehouse clubs like Costco and Sams and is the same as the defender, just a little cheaper. I have the X-Tour tires and find them wear well and be quieter than the original tires but never had Ecopias to compare. Unfortunately, I find road noise to be high my the gen 3 Prius no matter what. Just not enough sound deadening material. Sounds like the same for the gen 4.
  6. Dale1947
    Dale1947 Junior Member
    Las Vegas, NV
    2020 Prius Prime
    On my 2020 Prius Prime Limited, I immediately removed the Toyo's and put Michelin Defenders on.... gas mileage is fine, noise is much less, ride is great.... but initially noticed the front end very susceptible to cross winds, car jumping around the lane, needing constant correction, so had the dealer check and adjust alignment (slightly), and brought pressures down to 36/35 (instead of closer to 38), and car is much better behaved now.... really love the tires.... and the car - so far.... also have a 2017 Chevy Volt with Michelin Primacy.... another great tire, but not available in the Prius 15" tire size......
    Tips likes this.
  7. tchan2700
    30
    Thanks everyone, I decided on the Michelin Defenders and I'm very happy so far.
    jerrymildred likes this.
