How Do I Repair A Hybrid Automotive Prolong Discharger?
Discussion in 'Gen 2 Prius Main Forum' started by Phildo, Apr 21, 2020.
  1. Phildo
    Phildo Active Member
    138
    109
    Perth, Western Australia
    i-Tech
    - He didn't ship it back to Australia. He sent it to California (a freight forwarder) without telling me first, and I had to retrieve it from there. This is despite my Australian return-address being on the box that I sent the discharger in.
    - There is no dispute about George's honesty. However, I don't have a whole lot of faith in his repair/testing skills, or his interest in resolving something with minimal cost to the customer. Why is sending parts to me now an option, when it wasn't possible last year? "We will need to have that unit send back for repair."
    When the discharger originally failed the first time I contacted George.
    My original request was to fix it locally (ie for him to send me repair parts). He denied that request.
    Me: "Although I appreciate that it's a proprietary design, is there anywhere in Australia that is able to repair the discharger? Shipping is going to be expensive for both of us."
    Hybrid Automotive: "I am really sorry to hear that, yes it does look like the resistors inside the unit went bad. We will need to have that unit send back for repair."
    When it was "repaired" he sent it back to the wrong address.
    I ended up paying the return freight to me.
    And the discharger failed on the first use.
    So yeah, I'm a tad miffed with George (the actual words that spring to mind are not permitted here).
    He insisted on the most expensive way of doing something, and still didn't repair the discharger.
    This would have been obvious if it was tested before sending it out, but I'm assuming that testing didn't happen.
    So no, I haven't contacted George directly since his repair didn't work.
    I gave George a chance. The freight cost me around half of the original cost of the discharger.
    To take it up with George again will just repeat the same cycle, and I'm damn angry that he didn't fix it the first time I paid to send it back.
    My experience with that repair was that it was done the most costly way possible, and I did not want to repeat that.
    Rather than create any more bad sentiment with George I wrote a lengthy email to the owner of Hybrid Automotive, Jeff Sloan.
    Jeff saw a comment of mine on a Facebook group that I'd had problems with my Prius discharger and messaged me directly, asking for more information. Hence the email to him - it was lengthy, but reasonably constructive and conveyed the point of view of a frustrated customer.
    But after six weeks I haven't received a reply from Jeff (I've also asked him on Messenger if he's going to reply - which he's seen).
    I wanted a solution, and I figured that if there's a dissatisfied customer out there somewhere then Jeff would want to know about it, and hopefully address it.
    The email (copied in a post above here) not only covered the repeatedly faulty discharger, but also a bunch of other things - why aren't there serial numbers on the items, what options are there for future out-of-warranty repairs, instructions for later model Camrys, why can't I use my Camry discharger on a Prius battery and a few other things.
    This issue shouldn't involve George anymore - that's why I haven't contacted him again.
    It should be moved up the management hierarchy to someone with the authority to make a more senior decision (ie in this case, Jeff Sloan).
    When I originally started this thread my simple request was if anyone knew how to repair a Hybrid Automotive discharger.
    This thread was never meant to be about George.
    TL;DR: There aren't further emails to George because I took it up with the owner of Hybrid Automotive instead, and didn't receive a reply.
    All I wanted was to learn how to fix my Hybrid Automotive Prius discharger. If anyone has experience with this then please contact me.
    Meg&Bear likes this.
  2. qmanqman
    qmanqman Active Member
    439
    152
    CO
    Right on Phildo. I hear ya bro. Funk George LOL
    If resistors were bad couldn't you figure that out?
    #22 qmanqman, Jul 16, 2020
  3. PriusCamper
    PriusCamper Senior Member
    13,018
    5,290
    Pacific Northwest, USA
    It's a very simple device... Anyone with soldering board skills is going to be able to replace that resistor. If anything else is wrong that likely won't be that hard to deal w/either.
  4. Meg&Bear
    Meg&Bear Junior Member
    I realize this thread is old and wish now in hindsight 20/20 that I had done a little more research regarding Hybrid Automotive and their Prolong System. I purchased the deluxe for my 2006 Toyota Highlander Hybrid in May 2021 and just installed the harness this past weekend which took me at least 20 hours for just disassembly and install of harness. All seemed ok but now my charger is not working and I had to reassemble my car and am on serious time constraints and fear I’ve caused my battery more harm than good :/ I emailed and received response from George whom I also briefly spoke with during installation and I agree with you completely that I felt slight condescension, annoyance, and apathy during my phone call with him and was distressed and disappointed that I’m now dealing with him again via email (as I want everything on record).
    I’ve had no issues with my battery despite the age and only 112K miles on my vehicle. I’ve followed all instructions and safety precautions provided by Prolong, which are limiting and lacking detail and a troubleshooting section on their website. I’m being told that most likely my fuse harness or charger fuse is to blame but given no further instruction on how to test these properly aside from fuse specs for harness. Which I am not about to disassemble my entire vehicle interior again only to verify what I already suspect to be true that something occurred to my charger upon first connection (after the testing) when I experienced a small pop backlight screen flash twice attempting to connect my harness. Another thread on this site has a prolong owner with a similar incident titled awful experience with Prolong or something similar. I’m unfortunately past the 30 day warranty for returns which is my fault for being unable to install and utilize the system until now but I wish I could return it because Hybrid Auto’s support is seriously lacking for their customers. Even if they had a troubleshooting section on their site that covered things like fuses and any other stuff, I’d be more likely to refer their products granted this issue gets sorted properly. I’m frustrated to say the least and can’t imagine having spent what you did on top of your purchase and without adequate results! I’m considering just chalking this up to a huge mistake and loss and looking at alternative systems that actually work and have adequate instructions and employees whom are actually helpful and not dismissive. I don’t have the time to waste with this back and forth and being unable to use my time I purposed for reconditioning also wasted and considered a loss. I’m sorry this happened to you and grateful that I found this so I don’t waste more money I don’t have right now shipping anything back to them for naught
  5. mattbuilt1
    mattbuilt1 New Member
    NH
    Did you ever replace your resistor? The MaxxVolts unit explicitly talks about how this is a part that regularly wears out, but I don't see it talked about on the Prolong unit. I assume Prolong will only provide the replacement in the 2-year warranty window and I don't see it for sale on their site. I am considering buying a discharger but want to know that this consumable part will be replaceable long term.
  6. PriusCamper
    13,018
    5,290
    Sure would love to have all needed information to repair these things. Just about everyone of us who's worked on packs has a busted one of these.
    Also an EE looked at one I had once and said the need to have to buy a different system based on battery pack voltage could be eliminated by adding a slider switch to connect the required jumpers on the board. Would so love to be able to solder that switch into place!
  7. mattbuilt1
    NH
    Is the "busted one" always the discharger or are you talking about both charger and discharger? Do you know if anyone has successfully replaced the discharger's resistor?
  8. PriusCamper
    13,018
    5,290
    Lol... I got a broken charger too... But yes the dischargers seem to fail more often. I'm eager to learn how to repair it. Haven't seen anyone show how yet. But anyone with elecrtical engineering skills could figure it out.
    First thing you'd want to do is test the resistor to confirm that's the source of the problem.
  9. mattbuilt1
    NH
    On a related note, do you know what the difference is between the Gen2 and Gen3 chargers? How about the harness?
    I wrote to Hybrid Automotive to ask what their suggested procedure is to replace the resistor bank in the dischargers. This was George's reply (after we settled on the proper terminology):
    "I understand now, you mean the resistor bank. If the unit gets used the way we instruct in our user guides, you most likely won't have that issue. The regular consumer line discharger is meant to be used a couple of times every 5 to 6 months. If you use it like that, it will last a few years, with confidence I can say 4-5 years before the resistor bank fails.
    The thing is that a lot of customers use the consumer line products to refurbish a lot of batteries, like in a shop environment, and the consumer line is not meant to be used like that in heavy-duty usage.
    The Pro units are meant for heavier usage, those units can be used daily. But even those can not be used 24/7. I mean, you can, but the resistor bank inside the unit most likely will fail in 5-6 months.
    We don't have instructions on how to replace that resistor bank, but if you ever need them, we can maybe make a short video on how to open the unit so that you can access it and replace it. As for how to get them, we can send them to you, or you could send the unit back, and we can replace it for you. Depending on the reason why they failed, we might charge you a fee for them or not, and also if the unit is in warranty or not."
  10. Brian1954
    Brian1954 Senior Member
    2,389
    960
    South Central PA, USA
    The charger and discharger are the same for the Gen 2 and Gen 3. The wiring harness is different between the Gen 2 and Gen 3.
  11. MARK A SLOO sloo
    MARK A SLOO sloo Junior Member
    39
    Minneapolis
    My Prolong discharger stopped discharging today. It powers up but only .003 amp draw during discharge. Has anyone attempted to replace the discharge "resistor bank"? I was quoted $80 for the replacement part from HybridAutomotive, which seems really high for some resistors.
  12. Linn Carper
    Linn Carper Junior Member
    Hamilton, AL
    My Prolong Discharger stopped working last week. I've used it 4x (21 cycles) on 3 different Gen 3 Prius (can you tell I like the Prius ?) without any problem. I stored it in my house for approx 1.5 years. I recently bought another Prius and successfully charged that. Upon hooking up the Discharger, the voltage display shows Pack voltage, but the Amp display shows zero.
    Having read other comments about the Discharger problem here, I decided to investigate and share with you.
    I opened the box and checked the fuse. It was good. Inside the box you will find another white box that holds the Power Resistor Bank. The Bank has 9 Resistors (3rd Gen Prius model). They are 100W 12 ohm. 85mm long x 15mm x 21mm. One mounting flange on one side. For testing, I used my voltmeter set to Ohms. I found 8 resistors had 12.0 ohms approx (the correct ohms range). One resistor was dead (0 ohms). I did some further testing and got it working temporarily for 2 charge/discharge cycles before it stopped discharging again. I have ordered a bunch (20) of the exact same OE Power Resistors (approx $2.50 each on Amazon) and the chassis hardware kit (Amazon) to assemble them into an exact copy of the original. I will be making two Banks (2nd one is a backup). Making the Bank and installing it in the box is easy, if you have some elementary soldering skills. I'm not an electrician. I have limited experience. Most Resistors like these come from China. I will receive mine in 2.5 weeks. I'll report back once I have installed and tested the repaired Discharger.
    Regards,
    Linn
    Albert Barbuto, dolj and Brian1954 like this.
  13. pasadena_commut
    pasadena_commut Senior Member
    2,806
    838
    Southern California
    Could you post a picture of one of these? Also another picture showing how they are mounted. Hopefully to a heat sink, but in some designs they might hang out in the air and be cooled by a fan.
    I would have ordered them from Digikey or Newark. That way you can have some confidence that the manufacturer is really who it claims to be. $2.50 is really cheap for a power resistor. Suspiciously cheap if they are the ones I have in mind. Digikey had these in stock, and they are $9.10 each for 12 units
    https://www.digikey.com/en/products/detail/ohmite/HS100-12R-J/5307068
    they are a little less expensive at Newark, but they only have 14 in stock at the moment.
    I built a stupid little discharger for the Honda Civic Hybrid 1 at one point. It was just a couple of light bulb sockets in series with a MOSFET to turn it on and off. It has been a while, and I forget what the bulb combination was to get approximately the right resistance. 100W then 40W maybe? Anyway, incandescent bulbs were at the time widely available and very inexpensive. Of course this thing was extremely dangerous, with high voltage present at the screw terminal on the first socket. Not something that any company should ever sell! Still, they were very cost effective compared to power resistors.
  14. Linn Carper
    Hamilton, AL
    Like you did, I checked prices at Digikey....Also Mouser. $2.50 vs $19.50.
    The cheaper ones I ordered are identical to what I found inside the Hybrid Automotive Discharger. Maybe the more expensive Resistors will last longer, but I'm only reconditioning my own 3 cars. Any Resistor Bank will degrade over time and heat cycles. When my new pack wears out, I will simply replace it with a new one, just like a car battery. With two packs, and the occasional use I do, they should last 4 years I'm guessing. lc
  15. Linn Carper
    Hamilton, AL
    Sorry, I don't have a picture of the Bank as installed.
    There is no heat sink. It is air cooled only and suspended by screws inside a small box with 2 open sides. The air from the 2 fans blows straight thru for one side of the outer box to the other side to vent.
  16. pasadena_commut
    2,806
    838
    Southern California
    Looks like those are wired in series to produce a 108 Ohm load. The battery is around 200V so roughly 2A and 400W. Not so easy to do that with a single resistor (other than an incandescent bulb, and the resistance on those will vary with the current and its temperature).
    Vishay makes some really neat water cooled resistors, and those probably last forever as long as the water flow is adequate, but I bet they cost a fortune and modifying the device to use them would be a pain.
    One thought, rather than buying these resistors from Amazon, maybe just buy some straight from China on AliExpress? Just looked and there were a bunch going for $0.99 each, some with bulk discounts on top of that, free shipping, marked "100W 12RJ" or "100W 12R" (J means +-5%, apparently). Not sure if the size is right. Of course AliExpress can be a crap shoot in terms of what actually shows up.
  17. Linn Carper
    Hamilton, AL
  18. Linn Carper
    Hamilton, AL
    I agree with your description. Also, My Gen 3 Battery pack is 234v fully charged by the Prolong Charger.
    I looked at AliExpress too. To get the free shipping, the best I could find to buy 9 Resistors was $1.99 X 9 Resistors = $17.91 + $1.62 import charges. That's $2.17 per Resistor shipped. Not bad. Better than Amazon. One difference, the Resistors are 60mm long instead of 85mm (like the original Prolong Resistors). I suspect that the smaller ones will work fine in the Prolong Discharger box. I ordered some 60mm (Green colored) Resistors from Amazon because with were discounted at $2.00. I could only get 6. They should arrive around the same time as my 85mm ones. I'll try them both and report back.
    I've also ordered some small Heat Sinks that would fit on the Resistor flange w/o changing the way the Pack is put together. I will experiment with reducing the temps with the Prolong Resistor setup.
    Since the cost of these 9 Resistor packs is relatively cheap, I can afford to destroy a few, lol. lc
  19. Linn Carper
    Hamilton, AL
    BTW,
    I'm in the middle of replacing the Head Gasket on my new to me 2010 Prius. Self-taught by YouTube. No problems. IMG_7549.jpg IMG_7550.jpg
  20. Linn Carper
    Hamilton, AL
    Update on my Prolong Discharger repair:
    I received my resistors from China. In an earlier post, I mentioned the Green colored resistors were a smaller size. This is incorrect. The Green and Gold Resistors are identical except for the color.
    I assembled one 9-Resistor Bank to replace the defective one in my Prolong Discharger. I have enough Resistors to make 2 more banks as back-ups.
    I used M3 Brass Hex Motherboard Stand-offs to build the Bank (as in the original). Hex Stand-off hardware is available as a kit on Amazon. (see pic)
    I used common house wire (14-gauge copper) to solder the resistors in series.
    The Discharger has been running for one hour with no problems. If that changes, I'll report back here.
    PS: I sent my Cylinder head to a machine shop along with a spare.
    $75 per head to mill, check valves for leaks, and wash.
    Prior to sending to shop, I checked both heads for warpage with a professional straight edge. No issues there.
    The milling is just for extra insurance of a good, long-lasting head gasket repair.
    Regards.
    Linn
    IMG_7569.jpg IMG_7570.jpg IMG_7571.jpg IMG_7572.jpg IMG_7573.jpg IMG_7574.jpg IMG_7568.jpg
