BULGED BATTERY MODULES? NEVER SEEN THAT BEFORE
Discussion in 'Gen 2 Prius Technical Discussion' started by Dxta, Aug 2, 2017.
  1. Hometown Hybrids
    Hometown Hybrids Junior Member
    Houston
    Try using a long clamp that can span the length of the battery :) It is definitely possible to get them back together if only a few are expanded.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    You mean span the width of the battery. As far as bolting it back together Its not a length issue is a width issue?
    I think once the battery is distended its done? The case is stressed.
  3. khan209
    khan209 New Member
    california
    I think its too late to reply but you can get them back. I had the same issue i put the fan on in the cold and cool down them to get them back on the normal condition. they are flexible unless they are way swell
  4. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    Wow, talk about a hot mess!
  5. khan209
    khan209 New Member
    california
    Now i got
    P0A9E. Temperature sensor circuit too high
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,371
    3,222
    Madison, Wisconsin
    Go back and look at the sensor and wires.
    Make sure they are not damaged.
    Replace as needed.
  7. khan209
    khan209 New Member
    california
    Thank you Eric, I replaces whole wire harness for temp sensors and its good now. Take care
  8. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    I just about had a battery meltdown myself. Had a camera watching the pack and fortunately the expanding pack causes a cable to switch position and trigger motion alert where it drew a square around the motion and I noticed the pack swelling. I was charging at around 4amps which I have been doing fine with, but forgot today was a very warm day in the garage (95F). As I was there I noticed a second pack starting to expand so I was able to disconnect. I have since devised an anti-swell trigger that stops charging at any sign (1mm) expansion while under compression. Fortunately for me both packs return to normal size within 2hrs of cooling.
    Picture: [Pack starting to swell, caught early]
    blaisep, R-P and Dxta like this.
  9. katit
    katit New Member
    St Louis, MO
    Question. I cycle batteries charging at 2Amp. After discharging them to 6V
    Around 5000mAh I get swelling like above. Is it OK? I try to charge up to 7000mAh
    Temperatures of other batteries - 20C, batteires that start expanding around 25-30C
    Should I change something or it's normal? They compress back after cooling..
  10. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Yikes!!! Two amps for a single module? I've never disassembled a battery to charge individual modules. My charger charges then entire pack at a third of an amp.
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    No they don't "compress back after cooling". Bulging ONCE makes them garbage. You are putting them in a system where they see 120A currents repeatedly. Bulging means you have broken the internal module goop essentially. There is no knowing if it is all cosmetic (very unlikely) or you have now caused pinhole shorts to open up that when you're cruising down the interstate decide to blow through and start smoking into the cabin.
    2A is fine WITH COMPRESSION. Otherwise stick to under a half amp. Our modules on the other hand have a metal cylindrical shell. No compression required, they are already and always under the mechanical stability they need.
    donbright likes this.
  12. katit
    katit New Member
    St Louis, MO
    What does it mean "WITH COMPRESSION"? I am charging them assembled in a pack. Does it mean compression? I see them bulging but then they return to normal once cooled..
    #3 shows how it is expanding.
