2005 battery replacement from newpriusbattery.com
Discussion in 'Gen 2 Prius Main Forum' started by LINGARAJU GOTTUMUKKALA, Aug 5, 2020.
  1. LINGARAJU GOTTUMUKKALA
    LINGARAJU GOTTUMUKKALA Junior Member
    37
    so finally those cylindrical battery cells are shipped to me and i will have them next Monday to be installed, i was reading through their manual and they have many warnings to use high volt isolating gloves with isolating tools as well to remove bolts and i have seen many YouTube videos where most of them were handling with bare hands, i understand that once orange plug is removed it cuts voltage in half and after disconnecting 12v battery the whole power to car is shut off, i want to do this myself as i dont have any money to get it replaced at a shop right now, so i remove 12v first, then remove orange plug and after that do i still need to use those mentioned tools as i am concerned about removing those connecting bolts between cells and i guess if i remove all the bolts on one side then i am just working with 7.5 to 7.6v as the series connection is broken among cells but i am concerned about this and also concerned about putting it back with those new cylindrical cells as they will probably have charge in them, so are just 2kv isolating gloves sufficient for the job or do i need those tools as well as i dont want to waste money on tools that i will probably using only once, thank you very much for any answers.
  2. Isaac Zachary
    Isaac Zachary Senior Member
    2,545
    1,285
    I ordered some cheaper electrical insulating gloves on Amazon and plan on wrapping my tools in electrical tape. I also watch lots of videos and prepare myself mentally for the risks. I plan on not reaching over an open battery, for an example, but having a way to go around it.
    All that is probably overkill to most people. But I prefer to err on the safe side.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Many people don't use any protection at all. But the warnings are because it is dangerous if you (a) don't know what you're doing or (b) make a mistake. I have had lots of high voltage things explode next to me, and it is not fun. If you want to be safe, use gloves and goggles along with insulated tools.
  4. PriusCamper
    PriusCamper Senior Member
    12,736
    5,152
    Pacific Northwest, USA
    The high voltage risk is real, at least until you have a crystal clear understanding of when there is no high voltage risk... Always better to start off as safe as possible... This post of yours is a good example of you figuring it out. As you get more comfortable with arming and disarming the high voltage nature of the pack, you'll better understand why more experienced people don't use the gloves. But be patient and keep being as cautious as possible until you're certain you can be safe without the gloves.
  5. LINGARAJU GOTTUMUKKALA
    37
    I guess I have not worded my question clearly, first safety in removing 12v battery and then the orange plug of HV battery, but before I get hv battery out of car I have to remove those cables from HV battery to front of car and is there any chance it could short out here if by mistake the tool touches between them and will that do any damage to the front hv electrical components and I have seen lot of YouTube videos where they were touching those bolts with bare hands and those terminals are still getting half voltage as orange plug is removed, inside the cover of battery there seems to be black plug among other connecting nuts of adjacent cells and removing the orange plug should remove the series connection the cells are connected and so will the voltage be half or no voltage near the outside terminals after orange plug is removed, my other concern is when putting those new cells will there be any risk while attaching those nuts and plates that connect adjacent cells as those new cells will probably have full charge in them, I have brought class 0 2kv isolating gloves in Amazon and would be those be sufficient for the job, thank you.
  6. Isaac Zachary
    2,545
    1,285
    The HV cables shouldn't be getting any voltage, unless there's a problem (or you really didn't disconnect the 12V, you really didn't pull the safety plug, and you accidentally turned on the car all at the same time.) If they still get "half the voltage" with the plug removed then there would be a major problem. I would still treat the plug with respect, just because there's a very, very small chance they could carry battery power even with the 12V disconnected and the safety plug removed. And a chance is a chance no matter how small. But it is very very unlikely.
    I'm the kind of guy that takes a Multimeter with me and will check those to make sure they don't have any power to them.
  7. Isaac Zachary
    2,545
    1,285
    Think about it. You have three places where power is disconnected. The two main contactors (I believe Prii have two main contactors and one charge contactor) and the service plug. Interrupting the circuit in just one of those places makes 0V at the cable on the outside of the battery. To get full voltage you'd need both contactors closed and the service plug installed. To get half the voltage there would have to be a short from the middle of the battery to the case, which would be a major problem.
    Yes, treat the battery always with care. There is always a very small chance a closed up battery could shock you. But the main danger is once you open up the battery.
    #7 Isaac Zachary, Aug 6, 2020
  8. LINGARAJU GOTTUMUKKALA
    37
    I saw a guy replacing a single cell in the pack and he described that there is black connector looking thing on top ofnof and plates that connect adjacent cells at or near the middle of the pack on the side of ECU and it has 2 orange wires coming out of it and he didn't describe where those cables go but said removing an outside plug coming from it breaks the series connection but technically the cells in front of that and behind black thingy are still connected by nuts and plates so I understood that there is still good amount of voltage coming out of pack that could hurt you, I am just trying to understand the connections inside the case and only have bits and pieces of understanding. Can you explain the whole circuit in layman terms of possible.
    Isaac Zachary likes this.
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    All the modules, even with the safety disconnect disconnected, still have energy.
    If you take out the safety plug, then go lick the bus-bars, you're gonna have a bad time...
  10. Isaac Zachary
    2,545
    1,285
    ¿Because of residual voltage left in the capacitors? Good point.
  11. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    No because of the actual energy stored in the battery module themselves. And the bus bars are exposed. Between each module is 14.4v. That will give you a buzz, but won't hurt. But if you're using a torque wrench with a 12in handle, and short between modules far apart, it could be 100v+.
  12. Isaac Zachary
    2,545
    1,285
    Oh. I read too fast and didn't see "bus bars." He was asking about the main cable coming out of the battery even before disassembly of the battery itself.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes for those main connectors, you do have cap charge in the inverter. Step 21 in our manual specifically says if you are a ninja and got to the point of removing the battery plate within 10 minutes of disconnecting the safety plug, then sit back and relax for the 10 minutes so that residual charge goes away. I am sure most people don't even read it, or just say "I don't need to do that".
  14. douglasjre
    douglasjre Senior Member
    2,179
    718
    Null, NL
    Where did you order your batteries from? Where did you get the balance charger from?
  15. Isaac Zachary
    2,545
    1,285
    Disclamer. I'm also new at this and haven't even seen the inside of a Prius battery in person. The drawings I made are not to scale and may be way off as far as orientation goes, not to mention colors and such. But this is what I understand. Maybe someone else with more experience can chip in and correct me please.
    So let's see. A cell has around 1.8V. There are 6 cells in a module, or about 8.4V:
    Two modules in series is a "block." That's what the car reads to see if part of the battery is failing.
    Then you have 28 modules, or 14 blocks, bolted together in series producing around 235V, with the service plug installed of course. Not only that, but any place where one battery is connected to the other is a point that could short out if connected to any other connection, depending on how many modules or blocks you short one to the next. It could be 33V, 50V, 84, 168 or so on.
    But not only along the battery could we have this problem of shorting out. There are high power cables that run back to the contactors and BMS stuff at the end of the battery. Now as long as the contactors aren't closed (either because the 12V is connected and the car is turned on or because they are stuck down) there shouldn't be any voltage past them into the place the main HV cables plug into the battery itself from the outside, except for 10 minutes or so after turing off the car due to capacitance, as @2k1Toaster brought out.
    However, where ever the cables come in will have high voltages. (Pic from another PriusChat member.):
    But the service plug (terribly drawn) should separate those components a bit. There still is a chance of shorting out on the cables connected to the contactors, service plug, battery, bus bars, etc. But the voltage is less now. Plus one half is now no longer in an electric circuit with the other half making some of things no longer shortable without making two shorts.
    But you also should note that there are other wires going from each block back to the "BMS". Of course they are insulated, but any damage to them or if "unplugged" from whatever they are plugged into could open up a chance of a short or place to be electrocuted as well.
    Once you unbolt and remove all the modules and keep the terminals separated (not touching), you won't have any more high voltages until you put it back together.
    kenoarto likes this.
  16. LINGARAJU GOTTUMUKKALA
    37
    I don't have a balance charger and I brought the new battery from newpriusbatteries.com
  17. PriusCamper
    12,736
    5,152
    Hybrid Automotive installation instructions recommends you use a multi-tester to double check where those cables attach to ensure there's no voltage left in them after removing the orange safety plug. Once you see 0.0v from those two points it's safe to remove them. And while there's almost no way the pack can produce high voltage with the safety plug out, this double checking practice makes sense in terms of redundancy.
  18. LINGARAJU GOTTUMUKKALA
    37
    Thank you @Isaac Zachary @2k1Toaster @PriusCamper , got my courage up and in about 10 hours removed and tored all the cells and going to check them with multimeter, this car has not been powered on in about 10 days and will all cells still show 7.5vnor something similar apart from the dead ones, and since those new cylindrical cells appear to be 2 cells packed into 1 like 2 cells forming a block in the OEM battery and they might be fully charged so how do wire them safely, thank you.
  19. LINGARAJU GOTTUMUKKALA
    37
    So after testing all the cells only 3 showed 6.38v while all other showed 7.55 to 7.66 and testing A those 3 showed .050 while all others showed .063 to .067, so I am not sure if I ordered those new battery in a hurry but I also guess that I replaced those 3 cells I will end up doing them again, any thoughts appreciated.
  20. LINGARAJU GOTTUMUKKALA
    37
    IMG_20200810_192556.jpg IMG_20200810_192540.jpg IMG_20200810_192424.jpg IMG_20200810_193410.jpg @2k1Toaster got the new cylindrical battery pack and trying to install but confused, first there is a + and - sign on each module printed on a side and does it mean the opposite end is positive and I am asking this because my 01 module has - sign but the cable that can reach it's terminal is orange and short and I guess it's positive and the long wire is also orange but covered in black tape and that black tape has some sort of thing aluminum foil inside that bolted next to ECU in the bottom, I am not sure if this car was serviced before but there is as date 02/10 on the frame, so I installed 01 module which has - sign on one top side and i turned it around (assuming other end is positive) so - sign is close to ECU (my ECU is on the right side when standing at the end where there are all the cables and empty compression without any wires is on another end and this ends up with bus bar connection in - symbol side on top side where as it is supposed to be on the bottom and vice versa on another side, will be posting pictures, what should I do now, by the way how do I know which terminal is - or + for the wires that go out front other than the length of cables as I am not sure if it was modified or not ( I brought 2005 CPO Prius Gen 2 in 2010, thank you.
