AC not cooling when stopped
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by TxMedic83, Jul 17, 2020.
  1. TxMedic83
    TxMedic83 Junior Member
    2014 Prius c
    My 2014 C has started having hot air when I’m stopped at a sign/light. When I get going it cools down, and I checked the refrigerant pressures and they’re in spec.
    Does the C use one fan for both the radiator / condenser or is there a second fan buried under the shroud somewhere?
    I can turn my radiator fan by hand, but haven’t seen it come on while investigating. If this is the only fan I can troubleshoot the motor pretty easy, and look at relays / fuses, but I really need to know if it’s the only fan.
    Thanks!
  2. Leadfoot J. McCoalroller
    8,066
    7,546
    Pennsylvania
    2018 Prius c
    Only one fan in the c.
  3. lech auto air conditionin
    830
    602
    261
    san francisco
    Will the AC turn on in your garage, with the hood up if the AC is blowing cold now you should see the fan running. and hear the AC compressor spinning.
  4. Sonic_TH
    Sonic_TH Active Member
    572
    96
    Puerto Rico
    2016 Prius c
    The same happened to my 2012 Prius C, maybe the servo that controls a door to control the flow of hot and cool air is stuck, i fixed the problem by disconnecting the 12V battery for a few minutes.
