New member from Central New York
Discussion in 'Newbie Forum' started by Maze62, Aug 7, 2020.
  1. Maze62
    Maze62 New Member
    Central New York
    Hi all,
    This has to be one of the best sites in existence! I've owned several Toyotas, have 2 Prius now (2006 and 2007) and like to do my own work. Thanks to all that share their knowledge and experience. I'll post this question elsewhere as well, suggestions for getting set up with the latest Techstream. It's all new to me so links, info, etc will help. Not really a computer guy. Thanks in advance. Anyone in CNY, give me a shout
    jerrymildred, Raytheeagle and bisco like this.
    52,263
    welcome!
    all the best getting it set up (y)
    Maze62 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    12,967
    5,275
    Pacific Northwest, USA
    Greetings!
    Whatcha gonna work on first?
    Whatcha worried about doing that you'll procrastinate on and avoid as long as possible?
  4. Maze62
    Maze62 New Member
    Central New York
    Already done a fair amount in the last few years on the 2006. Struts (front and rear), front wheel bearings, axles, trans fluid, hybrid fan cleaning, 12v battery replacement, plugs, pcv valve, knock sensor, pulled and cleaned throttle body and intake, K&N filter. Just replaced a front caliper ( should have read about it here! ). Have to finish the bleeding and warning lights yet, lol. Only procrastinating on buying a VXDIAG and some rocker panel rust repair. Moving into a new house soon and can't wait, huge heated and cooled garage! Need to save for a lift!!!!
    PriusCamper likes this.
  5. PriusCamper
    12,967
    5,275
    So you physically removed the intake manifold to clean it? Or did you just remove the air intake and clean the throttle body and manifold with it still in place? And if the former rather than the latter, how long did it take?
    Maze62 likes this.
  6. Maze62
    Maze62 New Member
    Central New York
    I removed them both, separated them and cleaned them both. Removing the manifold isn't time consuming. Cleaning time depends on whether you clean the manifold with sprays and a brush or a parts washer tub. Manifold gasket isn't costly. The job is worth the extra time to really get the crud out. Wiped the carbon out of the ports in the block and snugged it back up. Got it all done in a few hours, but I move a bit slowly (I tend to drop screws, bolts and such).
  7. PriusCamper
    12,967
    5,275
    Thanks so much for this! I've always felt a bit half-assed about stuffing rags down the intake and spraying stuff in hopes of cleaning it. This seems like the best way to do a way more professional high quality job...
  8. Purrius
    Purrius Member
    164
    48
    Northeastern US
    I'm often out and about in Syracuse and Rochester myself!
  9. Mendel Leisk
    41,809
    Content is great, albeit contentious at times. If you're not running ad-block, this site will motivate acquisition. Site is currently in "absentee landlord" mode, for some time now.
    If you're on an Turn off signatures in Tapatalk Safari (not sure about other phones/browsers: manually refreshing pages is necessity, in particular if you post, then edit the post more than once. Just refresh, constantly.
    There's one, tireless/heroic moderator; you can get in touch with him via the report button.
    If you're on a phone, when you need to see more info, turning it to landscape orientation often reveals stuff.
    The "PriusShop" link, still showing on the home page, is broken. For the best.
