Alarm problem
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Charly Lowry, Aug 16, 2019.
  1. Charly Lowry
    Charly Lowry New Member
    San Antonio
    2018 Prius Prime
    My car alarm keeps going off for no apparent reason.
    I have been through so many of the threads on this site addressing problem alarms. None of them seem to really apply to my situation.
    I have a 2018 Prius Prime Advanced
    I had it at the Toyota dealer service department last week. They checked the car battery, replaced the fob batteries, and did a once over of the entire car. They then reassured me that there was nothing they could find wrong.
    Additionally...
    Following additional instructions on other threads here: I've located and cleaned off the hood sensor. When that didn't help I tried cleaning every sensor I could find. I've tried bumping the car different ways to set off the alarm. I've tried leaving the doors unlocked and still had the alarm go off while the car was parked.
    The only thing I have found seems to be consistent is that it only goes off while parked in direct sunlight. I live in Texas and the weather during the day has hit triple digits the past few weeks. I can't find anything online about heat affecting car alarms but that is the only thing I haven't been able to correct for at this point.
    Does anyone have any other information? Could it be the heat? If so... is there anything I can do?
  2. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    I'll assume this is the standard stock Alarm and not a dealer installed one.
    How frequently does this happen?
    Could it be a flaky FOB?
    Maybe wrap them in foil and see if the problem still occurs or you can
    temporarily remove the batteries but I think the foil is easier.
    Probably not it but "leave no stone left unturned" applies.
  3. Charly Lowry
    San Antonio
    2018 Prius Prime
    It's the alarm that was in the car brand new. Not installed separately.
    It happens daily. Whenever I park in the sun in the afternoon.
    I've tried leaving my fob at home and taking my husband's fob. It still happens. I've changed the batteries in both fobs and it still happens.
    Are you suggesting I pull out the batteries every time I turn off the car? Willing to try anything.
    But it still seems that the only common denominator is parking in the sun when it's hot in the afternoon. Unfortunately, this is an unavoidable situation for me. Or I might just never park in the sun...
  4. bisco
    52,274
    double check the alarm. just because it came with the car, doesn't mean it isn't aftermarket
  5. Charly Lowry
    San Antonio
    2018 Prius Prime
    It's not aftermarket
    Also I've had the car for a year and it didn't start doing this until the last couple months
  6. bisco
    52,274
    i hope it's not rodents
  7. Charly Lowry
    San Antonio
    2018 Prius Prime
  8. Charly Lowry
    San Antonio
    2018 Prius Prime
    I thought of another possibility. I've noticed that it seems to happen at the same 2 places weekl . I thought it was due to parking in the sun primarily because I couldn't think of any other difference between those places I parked in and any other except the direct sun.
    Been doing more research to find a solution and found information about other people's fobs setting off alarms in neighboring cars. Has anyone else run into that? Is it possible to change those settings in a car alarm?
  9. bisco
    52,274
    have never heard of it.
    sometimes, rodents chew on the wiring, causing intermittent shorts
  10. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    If you have access to a camera, it may be worthwhile to set it up inside the car pointed at a thermometer. That way you can see if the alarm going off coincides with a certain time or certain temperature.
  11. LightningBolt
    LightningBolt New Member
    27
    Rhode Island
    2020 Prius Prime
    Its a long shot, but has something changed in the area where you park that involves RF energy? Is there a new radar installation nearby? Or a newly installed microwave dish or cell tower? Strong microwave energy can set off car alarms.
