How to know if the 2017 prius battery is ion lithium or nickel?
Discussion in 'Gen 4 Prius Technical Discussion' started by Fadi1, Sep 14, 2020.
  1. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    I'm planning to upgrade from 2008 to 2017 or 2018 prius (used), as you know the 2016 and above have two batteries type ion lithium and nicle
    Is there any standard that can follow to check whether this car came with original battery ion lithium or it were customized to be a lithium battery?
    Some tech here says you can confirm this from the VIN I checked VIN decode will never show you the original battery type.
    Any suggestions
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
  3. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
  4. alanclarkeau
    7,045
    7,593
    Not sure about there - but here, it's a sticker in the front of the Warranty and Service Manual.
  5. Tideland Prius
    16,589
    You get the model type from the driver’s door jamb.
  6. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    So whenever i see this on the lable so the battery is ion lithium? Or the zvw51 engine can come with nickle batteries?
    As I have one car with this, does it have lithium battery?
  7. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Say what?? There were (are) two battery chemistry options in the Gen 4 Prius depending on the trim level. Nothing was customized.
    In 2018, the trim one and two have NiMH. All others (two ECO, three, three touring, four, and four touring) have Li-ion. It's in the Toyota brochure. So, just use the VIN to be sure of the trim if it isn't already obvious and look up the trim level on the toyota owner's page.
  8. alanclarkeau
    7,045
    7,593
    There were other differences in the cars depending on the hybrid battery - the mapping of the ECUs is significantly different for obvious reasons to do with the battery management, and that could affect other aspects. Not sure if the ICE ECU mapping is different - it could well be.
    jerrymildred likes this.
  9. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    So based on this VIN what is the battery type for it
    And how I can get the screenshot you sent,
    JTDKARFU0H3033904
  10. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    How to know the trim from the VIN, I search for around an hour, I couldn't find it
  11. mjoo
    mjoo Senior Member
    1,162
    1,331
    Michigan
  12. Elektroingenieur
    2,515
    3,286
    Three Touring
    The image @jerrymildred kindly shared comes from the sales brochure for 2018 (PDF); the 2017 brochure (PDF) has a similar table.
    The first few characters of the VIN can be decoded to give the basic model code, which identifies the type of HV battery; see my previous posting, valid through model year 2019.
    In your example, a VIN starting with JTDKARFU has basic model code ZVW51, indicating a two-wheel-drive, fourth-generation Prius car with a Li-ion battery; like all fourth-generation Prius cars, it was built by Toyota in Japan and has a 2ZR-FXE gasoline engine. The “H” in position 10 indicates model year 2017; model year 2018 vehicles have a “J” in that position.
    On its own, the VIN just tells you the basic model code, not the trim (grade) level, for which you have to check Toyota’s database, as @mjoo kindly mentioned. If you don’t need the maintenance history, you don’t have to log in; see Toyota’s Vehicle Specification page. (Note that information about some U.S. vehicles isn’t available there.)
    alanclarkeau and jerrymildred like this.
  13. Tideland Prius
    16,589
    You read that label. If it says ZVW51 like the photo, it’s lithium ion. If it says 50, it’s NiMH.
    That’s the code. Very simple.
  14. Mendel Leisk
    41,771
    And all the AWD versions are nickel IIRC?
  15. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    You just burn it with this reply
    Thank you so much for your clarification
    Elektroingenieur likes this.
  16. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    One more thing, based on your experience and according to the history maintenance record, what do you think, is it good? And the accident recorded on it is it that bad, as I saw only back door replaced engine is fine and battery had no impact
    So what do you think?
  17. Fadi1
    Fadi1 Junior Member
    65
    Jordan
    2018 Prius
    Yes I know but I saw zvw512L and 1L, what is the difference? Is it related to level type?
  18. jerrymildred
    11,517
    14,157
    Tampa, FL
    Yes, you remember correctly. In fact, the AWDe models are the only ones now with NiMH.
  19. Tideland Prius
    16,589
    51L is your photo. The 52L in my photo is because I have the Prius Prime or Prius PHV (plug in hybrid).
    Fadi1 likes this.
  20. Prodigyplace
    12,620
    11,805
    Central Virginia
    US Trims are not sold in Jordan. ;)
