How hot for Engine to expel moisture?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by srivenkat, Oct 5, 2020.
  1. srivenkat
    srivenkat Active Member
    596
    93
    IL
    I have seen many articles where one of the issues with cars used for short trips (and PHEVs) is that the engine doesn't get hot enough to expel moisture. The issue is that I haven't been able to get the Prime engine coolant temperature as shown on SGII to more than 197F. Even on my long drive from NY to IL last month, it momentarily went to 201F for a second when I really stomped on the accelerator. But I see the temperature at which water turns to vapor is 212F. So, I am wondering if it's possible to get the engine hot enough to expel moisture, unless I am missing something.
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Those temps are normal. Those readings are NOT the exhaust temps which are MUCH higher and are thoroughly burning off water vapor which is a normal byproduct of combustion. It's just a matter of operating time for the entire exhaust system to reach full temp.
    Your car is fine.
    MTN and jerrymildred like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Either that or we're all in trouble! :eek: :D
    MTN and fotomoto like this.
  4. srivenkat
    596
    93
    IL
    Thanks. How long might it take for the entire exhaust system to reach the full temp?
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    A quick Google search yielded this: "repeated drives of less than 5 miles is considered short-distance driving." However in the Prius the engine might still go off and on during driving and you would want to accumulate 5 miles of engine operation I would think...
    jerrymildred likes this.
