door soundproofing - is this too excessive?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by abubin, Oct 19, 2020.
  1. abubin
    abubin Member
    193
    92
    Malaysia
    I just did soundproofing for my car door.
    My friend said it is too much and make the door too heavy. There is another layer at the interior of the door.
    Is it too much?
    Grit likes this.
  2. Sfpep
    Sfpep New Member
    Finland
    2016 Prius+ MPV
    Well... i think you are the onlyone who can truly answer this. I think its not because soundproof is something out box that toyota forgot to do when manufactured.
  3. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    It's only too heavy if the passenger cannot keep the door from hitting something next to you when parked on a slope.
    On the other hand, heavy is exactly what you want for noise reduction. Increased mass and an uneven distribution both help.
    Practical advice: heavier insulation towards the front of the doors, because you can add more of it there with less penalty to the passenger trying to open and close it.
    Achieving lots of coverage with lightweight insulation takes up time and looks good but doesn't do much for sound.
  4. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Way too heavy. That much excess weight would kill my 67 mpg by the tank average mojo.
    SFO likes this.
  5. abubin
    abubin Member
    193
    92
    Malaysia
    LOL..I haven't even done the 3 layer on the floor yet.
    PriusCamper likes this.
  6. PriusCamper
    PriusCamper Senior Member
    13,054
    5,304
    Pacific Northwest, USA
    You need better friends! The door is too heavy? Give me a break... The sound of a Prius door closing is awful because it's so lightweight... Adding weight likely will make the door feel and sound more like a regular low MPG car's door.
    kenoarto likes this.
  7. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Dam 3 layers!!! Super comfy ride coming up in here!
  8. abubin
    abubin Member
    193
    92
    Malaysia
    Looks like there are 2 things to consider when doing soundproofing. Weight and material balance. More material, better soundproofing but more weight. Less material, less soundproofing but less weight.
    More comments please. I would like to know what others think of when trying to get good soundproofing.
  9. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    They have headphones that offers noise canceling, implement that technology into your car Avoiding buying materials and elbow grease all together.
  10. ASRDogman
    ASRDogman Senior Member
    7,818
    3,982
    Just how much material do you think you can put into the door????
    Is the material made of lead? If so, then it could cause extra wear on the door hinges.
    I barely hear my doors close. I don't need to close mine hard, just slight pressure and they latch.
    Decades ago I seem to remember reading somewhere that it is not suppose to be so quiet in the car
    that you can't hear emergency vehicles. Though I don't play my radio loud, it's loud enough to
    override road nose, and have still heard the sirens. And if you are paying attention, you'll be able
    to see them...
    If you have the need and urge to put in more sound deadening material, my Prius could use some. :whistle:(y)
  11. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    ^ Historically the right mass loads for good bass out of a speaker used portland cement as a material. Incredibly dense, but safer to handle than lead.
    Automotive applications tended to use asphalt because it's cheaper and easier to work, not as brittle. A 200lb layer of asphalt between the floor pan and the carpet, with more in the bottoms of the doors, will give you that library quiet ride but it's a heck of a lot of dirt to haul with respect to fuel economy.
    Don't forget noise sources- wheel bearings will gradually change from silent to unbearably loud over the miles. Many people don't realize this because the change is so gradual. But if you really care about noise while driving, don't let your wheel bearings run more than 80k miles.
  12. abubin
    abubin Member
    193
    92
    Malaysia
    For those who have done door soundproofing, please do show a picture. This would be great for me to take on as reference. From the few I saw posted on this forum was the use of Dynamat Extreme covering the whole front panel like what I have done. More references would be highly appreciated. Thanks.
  13. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    do not know. What's behind that 3M gold layer?
  14. abubin
    abubin Member
    193
    92
    Malaysia
    Another layer of 3M gold.
  15. Kenny94945
    Kenny94945 Active Member
    858
    433
    Sausalito
    2016 Prius v wagon
    Excessive? Maybe.
    Seems like the OP is trying to make the door shell a speaker cabinet.
    In that regard, maybe less material could have been used.
    In the "old days" we would place deadening material onto the inside of the outer door skin, if I am writing clearly.
    I'll end by writing.... rattles suck.
    Best of luck.
  16. PriusCamper
    13,054
    5,304
    What are your plans for undercoating and underbody cover modifications, as well as wheel well? There's lots of noise coming from those places.
  17. abubin
    abubin Member
    193
    92
    Malaysia
    I have already done wheel well.
    After done the doors, I will do the floor (underbody) for the whole car. Planned to do probably 2 layers of that 3m sound deadening and another sound absorbing. I am open to suggestions.
    I am also checking out this new 3 in 1 type to see if possible to use only 1 layer of this for the flooring:
