Red Bullet Solenoid
Discussion in 'Gen 3 Prius Main Forum' started by AzusaPrius, Oct 5, 2020.
  1. AzusaPrius
    AzusaPrius Senior Member
    2,225
    930
    Finally got my hands on this little red gem of an upgrade.
    I will upload pictures and video soon.
    Max Taiwan and Jim Swart like this.
  2. Threej
    Threej Member
    99
    99
    Portland, OR
    Its been a month... any results/observations to report?
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Put one on my G2 works really good. Check it out in the G2 forum Technical Section.
    Threej likes this.
  4. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Am I reading this correctly from the box? "IMPROVED SIGNIFICANTLY AND SFFICIENTLY" o_O
    I hope their engineering and quality contol are better than their English. :ROFLMAO:
    Grit likes this.
  5. edthefox5
    10,096
    4,834
    Clearwater, Florida
    lol i saw that. Its made in china. like everything else. Big improvement on my G2. Will be even bigger improvement on a more powerful G3 I would bet.
  6. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    I haven't had a Gen-2 in a few years, so haven't been keeping up with what's going on over there. What does this do? Improve power, efficiency, both?
  7. edthefox5
    10,096
    4,834
    Clearwater, Florida
    yes I see an increase in power and really much faster engine response in the mid band like 40-50 miles an hour and if you need to pass a car the engine is right there. probably much bigger benefit in a more powerful G3.
    Really easy to install.
    It has made the car alot more fun to drive not so doggy.
    It increases the oil flow to rotate the intake cam to advance timing quicker then stock. That's a tricky proposition on a regular engine and not have it ping but apparently the atkission motor really responds well to that.
    The g2 needs all the help it can get lol.
    Aaron Vitolins likes this.
  8. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Any ill effects on MPG?
  9. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Well yes when Im speeding around lol...
    But I did a CC test over 5 miles on a rolling small hill highway and got 58 mpgs.
    #9 edthefox5, Nov 2, 2020
  10. AzusaPrius
    2,225
    930
    Sorry been busy driving around testing obviously the Red Bullet but also a Lithium hybrid battery from Dr Prius.
    The Red Bullet has made the car quicker for sure and its really fun to have a quicker prius than the rest.
    Now that the lithium battery is in it is even quicker.
    Hands down a must have for any prius owner.
    Who cares about typos and the actual color of the product as long as it makes the engine respond better is all that matters.
  11. edthefox5
    10,096
    4,834
    Clearwater, Florida
    It works good in my little G2 slug. It must be a whole lot of fun in a G3.
    The atkison cycle motor really responds to extra timing advance and no pinging! Its an interesting little motor.
  12. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Sorry if that came across as bashing/bad mouthing -- I didn't mean it that way. It was more like pointing out the obvious blunder of a guy walking up on stage with a trail of toilet paper stuck to his shoe.
  13. edthefox5
    10,096
    4,834
    Clearwater, Florida
    No I saw that too when it came in......does not make you feel all warm and fuzzy at first but eh China.....
    But the solenoid itself looks very well made.
  14. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    Do you have data or measurements that led to this conclusion? If so I'd like to see those, for both of these modifications.
    StarCaller likes this.
  15. AzusaPrius
    2,225
    930
    I can tell the difference in response when I drive it.
    You are either with it or without it.
    Eco mode would feel sluggish before.
    Now it feels like normal or power mode.
    You can not Dyno the prius I believe.
  16. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
  17. AzusaPrius
    2,225
    930
    Awesome, now that person needs to buy a Red Bullet and do another dyno.
    Aaron Vitolins, Threej and Jim Swart like this.
  18. Vman455
    539
    556
    The Middle
    Why would you need a dyno? Just put the stock solenoid in, find a quiet stretch of road and someone willing to ride along and work a stopwatch and do a few acceleration runs to 40 or 50 or 60 mph in each direction. Swap solenoids and do it over again. If the car is "quicker for sure", it should show up pretty clearly and consistently in measured acceleration times.
    Redline96, Threej and edthefox5 like this.
  19. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    You don't even need a friend. The Torque app will do it for you.
    edthefox5 and Vman455 like this.
  20. ChapmanF
    18,501
    I imagine it could even log other variables like pedal input and battery SoC at the same time, no? How many variables can it datalog, and at what polling rate?
