Prius trunk LEAKS pictures compilation - common problem areas. prius 2004-2015
Discussion in 'Gen 2 Prius Main Forum' started by tri4all, Nov 30, 2020.
  1. tri4all
    tri4all Member
    99
    Pacific Northwest
    Happy wet season everyone!
    it seem like every year I have to go through several of the prius threads to look for the leaky areas, so here I have compiled everyone's efforts on this forum of sharing their leaky areas in the trunk of the prius. Here are the best pictures from you guys and some of my own.
    This pertains to prius 2004 through 2009, but I have also put pictures at the end of the only known area for the 2010 through 2015 prius.
    summary of areas with pictures below:
    1. the famous hairline cracks on the roof gutter and side upper side panels below roof gutter
    2. bolts/screws holding rear bumper. either worn out or reinstall without grommets.
    3. tail light screws and grommets
    4. tire mud flapper
    5. also check hinges of tail gate for harlines crack although not vey common.
    6. rear tail light gasket (this is primarily for the 2010-2015 prius)
    everything easily fixed by adding silicone to the problem area. make sure to wash well and light sanding afterwords the area for good silicone adhesion. in some areas weather strip or new grommets is needed.
    Do not forget to keep an eye on your silicone work every year as the silicone doesn't hold forever and I think the hairline cracks continue to expand with age like my wrinkles...
    edit: Do not forget to remove the drain plugs in the truck area to prevent water ponding from new future leaks that you may not catch on time. ironically, this plugs are very water tight and you can fill the entire trunk with water without leaking any. don't ask why is the bottom frame so watertight and not the roof....
    Enjoy the compilation. feel free to add more pictures on this thread.
    roof area. this is the major culprit to the leak and where the water first enters the frame... through hairline cracks near the roof gutter
    then it drips to inside the trunk through this two main openings:
    and it drips on one or both of this two areas: on of which is on top of the hybrid battery!
    bumper cover screws without rubber gasket or worn out
    seam below the right tail light just behind the bumper where there was little sealer and it had split.
    back gate
    finally tire splashing water into the rear battery vent. for those missing the mud flapper or not installed correctly and covers only the edge.
    2010-2015 prius tail light water leak into trunk. where it gets plugged from leaves and debris and backflows to the inside. the solution is to screen the opening to keep it from getting plugged at the bottom drainage.
    [​IMG] [​IMG]
    #1 tri4all, Nov 30, 2020
    52,286
    well done, thank you!(y)
    Sanchan, C Wagner and Data Daedalus like this.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    I like it.
  4. jimontheocean
    jimontheocean Member
    53
    46
    SC
  5. PriusCamper
    PriusCamper Senior Member
    12,985
    5,281
    Pacific Northwest, USA
    I'm in the PNW with so much rain and all your work is gonna be a huge help. Will be referring people to this post for all leaks from now on.
  6. tri4all
    tri4all Member
    99
    Pacific Northwest
    I am in Oregon myself where we get 51 inches of rain in the fall/winter and no one drop in the summer.....
    This flaw on the frame welding should have been caught early on and should have been recalled, as this flaw has caused THE MAJORITY of hybrid batteries to fail premature due to corrosion and failing modules. you won't notice the trunk is full of water (literally) until is too late or you change a spare tire or no longer can keep the windows from fogging due to the high humidity. at that point, the corrosion has expanded into the battery bus bars and connectors shooting out the red triangle in your dashboard.
    Also, I believe this hairline cracks expand over the years so you may have to keep an eye on it and keep it as your annual maintenance.
    #6 tri4all, Nov 30, 2020
  7. Bunce
    Bunce Active Member
    322
    185
    Oregon
    I've just discovered water is coming in from an old window seal not doing it's job anymore. I've already tackled the points at the back end of the car so had to go on the hunt for why we were getting so much condensation inside.
  8. PriusCamper
    12,985
    5,281
    Back in the day before climate change took over it use to be, as recently as 25 years ago, that rain fell fairly fairly regularly in Western Oregon in the Summer and the dry season last less than a month.
    As for the leaks and the need for a recall, this is a regional issue, just like the corrosion on the voltage sensing harness in battery pack. They only do recalls for wide-spread problems not regional ones.
    C Wagner likes this.
  9. tri4all
    tri4all Member
    99
    Pacific Northwest
    have you had a roof rack? I had a small leak myself just last week at the interface between the window seal and the roof rack brace. I had to remove the roof rack and I won't be installing it back on until the summer. I might buy a better rack specifically designed from prius. Also, avoid getting a roof rack TRACK installed on top of the prius, too many screws through your roof that will eventually leak. and the track always force to do the bend of the prius roof...
  10. tri4all
    tri4all Member
    99
    Pacific Northwest
    no just regional in the PNW, some of the pictures posted above where from florida, england, and other parts of the world. unless you live in Las Vegas or a desert area, you won't have this problem. by the way the PNW has always had a mediterranean weather, wet winters and dry summers, the only thing changed we have seen in more recent years is more fires in the summer but precipitation and temps are average, check the NOAA website.
  11. PriusCamper
    12,985
    5,281
    Lol, seems the people who think their car that is more than a decade old is entitled to a recall and free repairs are also same people that deny climate change?
    The PNW is a very large area of what originally was 70% old growth temperate forest that had a profound influence on moderating the weather. In general, the further north in the region you go the more rain, the more temperate rainforest like and the less mediterranean the climate becomes.
    Back as recently as the 1940's even the southern most extreme of the Temperate rainforest in the coastal SF Bay area was getting way over 40 inches of rain, with as much as a 1/2 foot of dry season precipitation from the last remaining big trees grabbing fog drip... Then as old growth forest liquidation accelerated after WWII the California Mediterranean climate moved north and years where the dry season of less than a month became near non-existent.
    As for the fires, they're weather driven events. In 2018 the Campfire in California burned at a record rate of a hectare a second because the abnormal high winds replaced the usual 10" inches of precipitation in Paradise, CA area that they used to get in October & early November didn't give a drop.
    Then this year a massive early season freeze descended on the mid west that led to massive fire making winds descending down out of the cascades and in all three states we saw wildfires burn at a rate of 5 hectares per second. Over 100K acres burned in a single day in several places. This is because climate change in the past decade has boost average global wind speed by over 17%: The World's Winds Are Speeding Up - Scientific American
    These are unprecedented times and your climate change denialism has zero valid science to back it up. The data is overwhelmingly clear about what happens when humans make excuses for massive amounts of air pollution at a global scale. The whole planet begins to unravel and weather extremes scientists predicted were still 50 years away have shown up 50 years early. This whole planet is starting to catch on fire and you want Toyota to fix your leaky 13 year old car for free? Classic!!!
  12. tri4all
    tri4all Member
    99
    Pacific Northwest
    priuscamper I believe you misunderstood me:
    1. first of all, this thread was not intended for climate change discussion. I never denied climate change. all I said we've always had a mediterranean climate in this area with dry summers and wet winters with similar annual averages... much more to be said, but the extreme weather are more indicative of climate change such as fires, hurricanes, floods, etc. I invited you to look at the hard data through NOAA to confirm or invalidate my findings. I am happy to discuss it further in private.
    2. the leaky trunk in the prius affects many parts of the world, not just PNW. unless you live in a dessert, you will be ok.
    3. about a recall. perhaps you are right, this is not sufficient to call a recall since it is not a "safety issue". and perhaps Toyota didn't issue a notice because they would be liable for replacing the hybrid battery... but this leaky issue is certainly the main flaw that prius have had, besides the water pump.... other than that, prius are one of the most solid cars in the market and the pioneers of the new electric car wave.
  13. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Funny you mention that, I did just install one but the leak was prior to that. Once I replace the window seal I'll keep an eye out for leaks higher up. Thanks.
  14. PriusCamper
    12,985
    5,281
    For starters, I've never seen any pack that's failed due to a leaky roof seem because the water never gets into the packs. The packs are well designed in that regard. The only packs that fail from corrosion that I've seen are from long term exposure to regions that have cold humid air. And maybe a leaky roof seam makes that slightly worse, but not the main cause.
    As for the recall, that's silly. There's no safety issues that would make leaky roof seams dangerous and it's been 11 years since the last Gen2 Prius rolled off the assembly line.
  15. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Out of interest, what's your experience with battery packs? Like how many have you taken apart? (To clarify I'm not being judgemental at all, just trying to gauge the chances that you have come across one by knowing number of packs you've been into.)
    I'm in the PNW, my 2005 had a lot of water it the trunk when I bought it. When rebuilding the pack I had to replace all the hardware as it was so badly rusted. It's possible that the amount of rust can impede current so much that the ecu errors. It will definitely have some effect, I just don't know to what extent.
    C Wagner and PriusCamper like this.
  16. PriusCamper
    12,985
    5,281
    After 2 1/2 years I'm getting close to 20 Honda and Prius packs I've worked on... I've never seen rust in a pack though? Copper doesn't rust, nor due the nuts, but they definitely corrode and the only problem I've seen that's more common than a bad module is corrosion in the voltage sensor plug where it enters the hybrid battery ECU and eventually that corrosion fries / shorts out the ECU. In my experience all the other problems with corrosion beyond that plug is incidental and causes no harm to the functioning of the pack.
  17. Bunce
    Bunce Active Member
    322
    185
    Oregon
    Yep, you're right. Thinking back it wasn't rust but white corrosion of some sort.
    PriusCamper likes this.
  18. C Wagner
    C Wagner Member
    183
    60
    Boston
    Thanks, OP. I have this page bookmarked.
    My water story on a 2004 Gen II - signs of water/very very slight rust on driver side = wait and see. On the pass. side/battery compartment area though, there was about 1/4 inch of standing water, and surface rust suggesting this had been going on a while. I actually saw some water appearing to drip down from those seams along the rear wall below the rear hatch sill, on the battery compartment side. I caulked all the slit-like seams and also caulked the place where the right rear brake light assembly fits onto the body -- it looks like this water is supposed to go OVER the brake light when it cascades down the shute in the rear hatch enclosure area...
    After some more rain, I notice maybe even a bit more than 1/4 inch - but not on the rear side of the battery, and the seams look dry. Thanks to this thread and OP, I am going to turn to Pass. side mudflaps, those several bolts holding the bumper cover onto the wall above the battery. I checked and didn't see signs of water from the hinge cracks, or water in the spare tire area.
    Great car - great Site about it and great posters!
  19. dolj
    dolj Senior Member
    8,524
    4,326
    Wellington, New Zealand
    Don't forget to check where the roof meets the rear hatch at the end of the channel on both sides. This is the most common location. The cracks are hairline, but let in a lot of water considering you can almost not see the cracks.
  20. edthefox5
    10,096
    4,834
    Clearwater, Florida
    It’s shown.
