Night Mode Day Mode
Discussion in 'Prime Main Forum (2017-2022)' started by bevhoward, Dec 9, 2020.
Tags:
  1. bevhoward
    bevhoward Member
    64
    32
    Austin, Texas
    2020 Prius Prime
    A couple of weeks ago, the nav screen stopped going into "night mode" after dark, and I can't figure out how to get it set so it will.
    I have toggled the "day mode" button in display options, but even if I turn day mode off manually, the screen stays in day mode so the only option is to turn the nav screen off after dark.
    I've been through the manuals and found nothing that I have not already tried... I'm guessing that I might be missing something else.
    Anyone got any ideas? Thanks in advance,
    Beverly Howard
    2020 Prius Prime
    ImaRogers likes this.
  2. Bob Comer
    Bob Comer Active Member
    708
    457
    South Carolina low country
    Your dash lights are set to max, just hit the dim one notch.
  3. bevhoward
    bevhoward Member
    64
    32
    Austin, Texas
    2020 Prius Prime
    >> instrument cluster brightness <<
    Thanks, that was it... took me a while to find the button (which is under the AC vent near the door) Seems that if that brightness setting is set to maximum, it overrides night mode.
    HEY TOYOTA, add that information to the manual page that Bob posted.
    Thanks!
    Beverly Howard
