Anyone have problems in a huge traffic jam?
Discussion in 'Gen 2 Prius Main Forum' started by FishHawk, Oct 17, 2006.
  1. FishHawk
    FishHawk New Member
    176
    I was involved in a large traffic jam going to Cape Cod. We were crawling. I was mostly on my battery and electric motor. I got a little nervous because the battery was getting very low. Has anyone had issues with the car stalling or the battery not being charged in such as situation? FishHawk
  2. Pious
    Pious New Member
    57
    I had that happen to me yesterday, and the ICE kicked in and charged the battery with no problem.
  3. Bill Lumbergh
    Bill Lumbergh USAF Aircraft Maintainer
    537
    NorCal
    As long as you're not leaving the car in neutral, the ICE will start and charge the battery whenever the ECU thinks it needs to.
  4. daronspicher
    daronspicher Active Member
    1,208
    It wasn't very impressive a time this summer when it was too hot to leave the AC off all the way. I had that on low and we got in a traffic snarl. 1.5 hours, 10 miles... After a point, the car was pretty well freaked out starting and stopping the engine. It's terrible for mpg when it's doing that, but no harm done.
  5. qbee42
    3,081
    Just leave it in D and drive it; the Prius will take care of itself. You can't discharge the battery unless you leave it in N.
  6. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    I've been doing this 5 days a week for the past 10 months. Not once has it been a problem. Battery is full, battery drains, ICE charges battery, battery is full. Lather, rinse, repeat.
    If you are really worried, when the traffic stops for a second, put on the brakes hard, and push the accelerator. The ICE will come on an charge the battery. Don't know if this is good or bad, but it works.
  7. aaf709
    3,862
    2022 Prius Prime
    The only time I have that bad a traffic jam is when I'm in LA. Every time the ICE kicks in and out as needed without problems.
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    This is a FEATURE of your Prius...instead of sitting and idling it uses the battery to keep critical systems alive during low speed or stopped traffic. It allows the battery to get quite low on the assumption that traffic will go away soon and you'll recharge when you start driving. If you don't start driving it'll start up, charge nominally for a tiny fuel burn, and go back to battery-only mode.
    Do NOT shut off the car when the battery gets low...this is worse for FE as it will force it to go through the warm-up cycle again and you'll actually end up with an even lower battery charge.
    Do NOT do the forced charge method above (brake, gas technique), also unnecessarily burns fuel and increases the temp of the electronics (inverter, battery, etc) making them less efficient.
    Do NOT put the car in neutral or you eliminated the option for the battery to be recharged by the ICE. There are really only 2 ways you can damage your prius battery....1)leaving the car in Neutral and allowing the battery to be discharged, or 2)running out of gas and continuing to drive until the battery is depleted (and even that won't do it unless you keep going and going with multiple restarts).
    DO smile at all those saps burning gas for no good reason and frown at those same saps for polluting our world while they sit there burning gas.
  9. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(efusco @ Oct 17 2006, 03:56 PM) [snapback]334227[/snapback]</div>
    Indeed! You are driving a "real" hybrid. This is what it does. Be happy that it works this way. If it doesn't use the battery in this fasion, there's little reason to drag the thing along with you. In the car I drive the most, the Internal Combustion Engine NEVER comes on - mostly because there isn't one.
  10. Ari
    Ari New Member
    165
    This whole thread sounds like my daily commute! (I'm sure I'm not the only one.) [​IMG]
    It's really cool to inch along using little or no fuel while everyone else is idling. So no, it's not a bug, it's a feature :rolleyes:
  11. Artemis
    Artemis New Member
    Don't worry, I sell those and I own one. I can tell you that the engine will always come on when the battery gets low. That is the design of the car. Whether you know it or not, the battery always gets low before the engine comes online.
  12. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    <div class='quotetop'>QUOTE(darelldd @ Oct 17 2006, 07:05 PM) [snapback]334229[/snapback]</div>
    Don't you mean it's *always* on? It goes fast and slow, but you don't want it to ever stop, though it will someday. You are referring to the original, organic engine, fueled by bananas, yes? There's still an 'intake', 'internal combustion', and an...um...'exhaust'. :)
  13. jdauteuil
    jdauteuil New Member
    I to sit in ridiculous MA traffic on a daily basis and sometimes notice the same thing happening... Just turn on the consumption screen and let the car do it's thing - like the other poster said!
  14. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(FishHawk @ Oct 17 2006, 05:30 PM) [snapback]334173[/snapback]</div>
    It does take some getting used to. In the summer here, I will be in stop and go, with A/C on, and I am still surprised when the gasoline engine cranks up when I am sitting still, but it's the normal behavior from what I can tell.
  15. john1701a
    john1701a Prius Guru
    12,833
    5,311
    58
    <div class='quotetop'>QUOTE(FishHawk @ Oct 17 2006, 04:30 PM) [snapback]334173[/snapback]</div>
    Congrats! Having worried like that, then finding out later that the system was working perfectly, makes you are true owner now. Without having felt that anxiety would have deprived you of the complete ownership experience.
    Now that you do know, the real fun begins. Heck, 6 years and 122,700 miles later, I'm still enjoying it.
  16. NCPriusGrl
    NCPriusGrl New Member
    North Carolina
    Never had a problem once the battery runs low. I drive from NC to Philly a few times a year and sometimes get stuck in 2+ hour traffic back-ups around DC and besides problems with a full bladder, my Prius takes care of me getting through it.
  17. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(NCPriusGrl @ Oct 18 2006, 09:24 AM) [snapback]334410[/snapback]</div>
    Yours or the cars? :lol:
  18. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(eagle33199 @ Oct 18 2006, 10:38 AM) [snapback]334418[/snapback]</div>
    It would only be the car's problem if it were an empty bladder. :D
  19. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    I read somewhere that when you have that feeling that you *really* have to go to the bathroom, the walls of your bladder are only a few cell layers thick...
  20. NCPriusGrl
    North Carolina
    ha ha, it would be a good "problem" if the cars bladder was full.
    Hint, don't be in the far left lane on I-95 in the middle of the day.
