Can you use techstream to get voltage information as the car is running?
Discussion in 'Gen 2 Prius Technical Discussion' started by Banksy, Dec 16, 2020.
Tags:
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    I need to test the modules in my HV battery under load.
    However as soon as I start the vehicle techstream loses communication and when I try to reestablish communication to techstream as the car is on it won't connect.
    Am I doing something wrong?
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Yes you can use Techstream for accessing that data.
    You must have so mm e technical issue.
    jerrymildred likes this.
  3. Banksy
    415
    133
    Mm e?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    With or without the typo, Eric's right. You must have some technical issue. My guess would be a cheep dongle between the laptop and car. Or maybe it's a bad driver for the dongle. It's technical and will need some trial and error to sniff it out.
  5. Banksy
    415
    133
    Will any OBD2 to USB cable work or does it need to be a specific one?
    This was a cheap cable I got off ebay in a kit that had the software and cable together
  6. jerrymildred
    11,517
    14,171
    Tampa, FL
    I can't say for sure about that. But I have read that there are big variations in functionality between the cheap ones and the good ones. Mine is also a cheaper one and, so far, it has done all I asked of it. But I am considering an upgrade one of these days.
  7. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    #7 alftoy, Dec 17, 2020
    edthefox5 likes this.
