Ticking noise front suspension
Discussion in 'Gen 4 Prius Main Forum' started by tucatz, Sep 21, 2019.
  1. tucatz
    tucatz Active Member
    499
    412
    Manzanita, Oregon
    Four Touring
    I’ve recently noticed a ticking noise that sounds like it’s coming front the front suspension. I hear it when slowing down from 10 to 1 mph. “Tick tick tick. Tick. Tick tick” I can only hear it with the drivers side window open and on quiet roads. It is faint, but definitely there. What is this?
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    There are a few threads on this. I've noticed a noise like that a few times and it's always been a stone trapped in the tread of the tyre. Other people have had other causes.
    Mambo Dave, tucatz and Data Daedalus like this.
  3. GRich
    GRich Junior Member
    28
    Mine has been in the shop three time now for that noise. I only hear it at low speed under 20. They are replacing the strut and sway bar now. Just waiting for parts
    tucatz likes this.
  4. tucatz
    499
    412
    Manzanita, Oregon
    Four Touring
    Good luck! Please update us on the outcome.
  5. Abarnabe
    Abarnabe Member
    88
    58
    Netherlands
    I had the same noise when coming to a stop, I inspected the caliper pins, one was completely seized, a clean up with a steel brush, some grease , and the annoing ticking was gone for good.
    Mambo Dave likes this.
  6. Josem3
    Josem3 Junior Member
    Fl
    2013 Prius v wagon
    Exactly, I bought my Prius three months ago and noticed that noise when I go slowly to stop sign. No a big deal.
  7. Mambo Dave
    Mambo Dave Active Member
    640
    305
    2019 Prius
    L Eco
    Was this from a front or rear wheel?
  8. jerrymildred
    jerrymildred Senior Member
    11,491
    14,099
    Tampa, FL
    There are a few threads on this topic. My wife's '17 Prius and my '17 Prime both make that ticking noise while slowing to a stop. Mine has 47k miles, hers has 24k. I had the dealer try to find the cause on my wife's car and they looked for most of the day. They finally drive a new Prius and it made the same noise. I'm guessing that, if they make the same noise new and at 47k miles, the noise isn't really a problem.
  9. Abarnabe
    Abarnabe Member
    88
    58
    Netherlands
    It was from the front left wheel
    Mambo Dave and tucatz like this.
  10. srbinoki
    srbinoki Junior Member
    29
    Boston, MA
    Four Touring
    This is caused by the universal joint in the driver side half shaft. There is a TSB for 2016 models that you can get some dealers to use to apply the fix to the 2017s. I assume they are hold over half shafts that bridged model years.
