1. Jay D Thomas
    Jay D Thomas New Member
    Farwell, Michigan
    OBDII shows all blocks at 16.4 or 16.5. 12 volt battery seems fine. HV fan running at speed 6, all the time. Where do I look next?
  2. PriusCamper
    PriusCamper Senior Member
    13,104
    5,311
    Pacific Northwest, USA
    Once you clear the error code, for the most part the fan should have no reason to operate until the warning lights go on again...
    Also there are subcodes to that primary code that can point you into more focus.
    Which app are you using? Dr. Prius app is good for subcodes and real time monitoring.
    It's relatively safe to clear the error code and keep driving as long as battery temperature doesn't heat up.
  3. Jay D Thomas
    Farwell, Michigan
    How do you know the battery temperature?
  4. PriusCamper
    13,104
    5,311
  5. Jay D Thomas
    Farwell, Michigan
    Thanks! I have an OBDII and I have installed Torque Pro on my phone.
    I turned off all the codes, checked the all the blocks and their voltages are all in the good range.
    I was checking it as I test drove. The HV Charge started at 30 kW then when to 20 kW and after a bit it jumped to 40 kW and then to 60 kW. At 60 kW the triangle and death lit up. Can anyone tell me what is going on?
    #5 Jay D Thomas, Jan 3, 2021
  6. PriusCamper
    13,104
    5,311
    Torque isn't specifically designed for hybrid cars and is problematic to many. It also doesn't read P0A80 subcodes that will allow you to do a diagnosis. Try Dr. Prius app instead and grab a screenshot of the battery monitoring screen, as well as let us know what your subcodes are and we'll help you out.
