oil pressure sensor switch
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by A617, Jan 23, 2015.
  1. A617
    A617 Member
    213
    95
    OKC, OK
    Anyone know where is the oil pressure sensor switch located for the idiot low oil pressure warning?
  2. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    Try this.
    A617 likes this.
  3. A617
    A617 Member
    213
    95
    OKC, OK
    Thx!
  4. A617
    A617 Member
    213
    95
    OKC, OK
    Is that thread sealer purchasable at dealer (Toyota genuine adhesive 1344) or is locktite 242 (blue) usable, in high pressure and oil environment?
  5. frodoz737
    4,719
    2,517
    33
    Loctite 242 is equivalent, more readily available, likely cheaper and legal with Toyota.[​IMG]
    A617 likes this.
  6. motch6
    motch6 Member
    44
    34
    UTAH
    2020 Prius Prime
    Can anyone tell me, because you know I have no clue when it comes to things like this, can this part be changed WITHOUT having to do an oil change? Meaning, is it going to leak oil everywhere if I try to do it without draining the oil from the engine?
    I recently did a Crank Sensor and had no problems with oil leaking out while doing it.
  7. ASRDogman
    ASRDogman Senior Member
    7,818
    3,982
    Usually, a new oil pressure switch will have some blue or red locktight sealant on it.
    Some are a tapered thread, some use a copper/aluminum seal/gasket.
    You can always put some teflon tape on the threads which you can get from a department store or
    hardware store in the plumbing section.
    Make sure you thread it so when you screw it in, you are not going against the tape.
  8. Mendel Leisk
    41,898
    Per the other thread: you should have no problems; oil’s mostly down in the sump.
    motch6 likes this.
  9. DieselHammer
    DieselHammer Junior Member
    29
    Kansas
    Is there a commercial scanner that shows oil pressure?
  10. ChapmanF
    18,537
    There would have to be some oil pressure sensor somewhere before any scanner could show it, and there's no such animal in a Gen 3, just a simple pressure switch to tell you "way too low" or "not way too low".
    When a diagnosis calls for knowing the oil pressure, that usually amounts to unscrewing the pressure switch and screwing in a plumbing fitting of the right kind, and a hose, and a pressure gauge, then starting the engine and looking at that.
    DieselHammer and Brian1954 like this.
