Featured Review of hydrogen
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by bwilson4web, Nov 15, 2020.
  1. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    It's a little like the Ethanol lobby...if you propose methanol in the USA you will get your teeth kicked in.
    USA sees extreme importance to picking losers and winners for Gov't mandates and investment.
    Trollbait and Rmay635703 like this.
  2. bwilson4web
    16,187
    Start with the right timescale, milliseconds. For example Hornsdale in Australia. Grid scale batteries respond within the AC cycle time. Given the distribution of power outages or abnormal loads, grid scale batteries solve a lot of problems and work on the daily load cycle. Anything longer than about eight hours is not really something I worry about.
  3. Trollbait
    12,501
    A valid criticism, but your first post just discounted the message because of the messenger.
    Hydrogen has that fast fill advantage, but that comes at the cost of overall efficiency as a good portion of electricity is needed to make that happen. For some uses, that may be acceptable, but then we have other options for fuel.
    So you were drawing a conclusion for wide use based on your personal experience.
    Bob's post didn't discount hydrogen for energy storage.
    There are flaws in using natural gas for this example. The seasonal cycle here is due to direct heating use, not electricity. Direct use of hydrogen for that would require a serious amount of pipeline and equipment replacement. Installing heat pumps, geothermal where possible, everywhere would likely be cheaper, and consume less GWh overall.
    There is a seasonal cycle to electric use in the US, with peaks in the summer and winter. While solar energy will drop off in the fall and winter, that is when wind energy will pick up for most of the country.
    Wind generation seasonal patterns vary across the United States - Today in Energy - U.S. Energy Information Administration (EIA)
    The need for grid storage is more pressing on the daily level in the US than on the seasonal, and batteries are proven to be effective for that. And again, we aren't limited to hydrogen as a storage medium.
    This isn't about picking winners, but propping up losers.:p
    We need green hydrogen.
    Fuel cells could be a better way of turning a fuel into electricity.
    The two do not have to be combined together. It may even be better if they weren't in the beginning, as green hydrogen going to transport means fossil hydrogen still being used in its traditional roles. Then hydrogen plus fuel cell could be the best combo for a given application, but it doesn't look to be the case for hydrogen FCEVs.
    Take the Mirai. The new one is an improvement, but still lacks a compelling reason to buy one over an ICE car. The only one is zero emissions while sticking to a refueling station model. A good reason for those that can't charge at home, but it also entails making compromises elsewhere of the car.
    Space is one. Toyota went with a bigger chassis to improve cabin space, and the solution for getting a fifth seat is the same GM used in the gen2 Volt. Then the trunk is still smaller than a Corolla's; under 10 cubic feet, IIRC. A SUV would mitigate the space loss, but it is still going to be more than in an ICE or BEV. While the price of the car can come down with larger production, the performance or niceness of the Mirai isn't enough to justify the the higher price to potential buyers now. The price of hydrogen isn't going to beat gasoline. Green hydrogen could get cheaper, but much of the price is to cover the electricity to get it into the car's tank.
    Then the fuel cell itself has questions on reliability. They degrade with use. Like plug in batteries, the amount varies, and it may not be an issue for the user. A 10% average power output loss was seen at 75k miles though. While that and other aspects can improve, the space issue won't without a break through in storage. Fuel cell plus another fuel probably has a better chance.
    So there just isn't anything about the Mirai itself that gets people to buy it over another Toyota. The zero emissions are something, but the population says they care about fuel efficiency while buying some of the least efficient cars out there. Meanwhile, plug in car sales are increasing. Some with the loss of government incentives.
    Do we continue propping up hydrogen car sales? VW and Diamler have determined they aren't worth it, and the German government has a hydrogen plan. They see commercial trucks using hydrogen as possible. Maybe that would be a better use of resources, or working on other carbon neutral fuels for engines and fuel cells.
    iplug likes this.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    No, I was projecting doing it the only logical way to do it.
  5. Lee Jay
    5,850
    4,036
    Well, you should worry about it. Without seasonal storage solved, we can't keep the lights on, heat our houses, run our businesses, run our industries or fuel our vehicles, at least economically.
  6. Trollbait
    12,501
    And how many cars would you fill up at work at one time?
  7. Lee Jay
    5,850
    4,036
    One.
    That's kind of the whole point of the concept.
    You only use this hydrogen for road trips. The rest is done on plug-in energy when near home. On road trips, you store hydrogen all the time at the fueling location, and fill up in a few minutes when a car on a road trip happens by.
    As I've said hundreds of times, pure hydrogen cars are just as dumb as pure battery cars. When in your home town running errands and going to work, you should be all plug-in.
    To put it another way, I've had my Prime for around 1,400 days. Of those, I've been on road trips about 50 of them. I'm almost pure EV for 1,350 days (it would be 100% if I had 40 miles of range), and I've only used gas primarily for about 50 days. Same would go with a PHEV H2 car, and virtually all of those fill-ups would have been out in the sticks between major cities.
  8. Trollbait
    12,501
    The SAE protocol was designed to fast fill multiple cars at rates seen by gas stations. Even if hydrogen is used just far long trips, the highway stations will still be busy.
  9. Lee Jay
    5,850
    4,036
    Not any time soon - just like the Supercharger stations. In all those 50 days of traveling, passing by multiple supercharger stations, I saw a grand total of one Tesla charging.
    In the long term, it's not hard to do the same thing - just expand storage as you expand production, and let the gas cool to the ambient temperature inside the steel tanks. They are stationary - they don't have to be light.
  10. Trollbait
    12,501
    That simply isn't going to work for stations that will see hundreds to thousands of cars per day, and these would be big tanks even for stations that see a few cars a day. Then starting at ambient temperatures, the hydrogen could get hot enough to damage the tank during filling.
    The selling point of hydrogen is filling up as fast as gasoline is possible. If people end up waiting to fill up, they'll reconsider a BEV for their next car.
  11. bwilson4web
    16,187
    I'm more interested in power from a 'per cycle' to 'hours' duration:
    • < 1 second to 0.0168 ms - unit cycle intervals, continuous UPS buffer works
    • 1 - 10 seconds - equipment goes through power cycle with huge inrush, cheap standby UPS
    • 10 seconds to minutes - serious loss of productivity, emergency generators
    • above hours - sustainable alternatives
    The probability and frequency of any particular power outage decreases by a log function but plays h*ll with equipment and the patience of my late wife. The quality of our life is directly a function of these power outages which are in the time range of the Hornsdale Power Reserve.
    It looks like the problem you want to address are power storage in the days, weeks, and month range. That scale is a problem I would address with modular, small, distributed, molten salt, nuclear reactors. Ideally using non-explosive, nuclear fuels, no enriched uranium or plutonium isotopes feed stock, with actinide processing on-site. No high-pressure, directly heated water loops that have explosive characteristics.
    Hydrogen suffers from a low density and wicked storage challenges. Hydrogen rich compounds are less bad. But battery chemistry and packaging have and continue to achieve exponential, technological improvements and that is the direction of my interest.
    As for personal requirements:
    • Prius power backup, 1.1 kW using contractor cord distribution, 2005-2016.
    • Natural gas powered, 16 kW Generac with automatic fail-over, 2016 to current.
    These I have personal experience with and fully met and today meet my requirements.
    #51 bwilson4web, Feb 8, 2021
  12. Lee Jay
    5,850
    4,036
    Yeah, that'll go over well on airplanes.
    The point you don't understand is that our energy systems (electricity, heat and transportation) are connected, and thus any solution to sustainability will necessarily involve all three.
    Running airplanes on oil is unsustainable.
    Nuclear fission is unsustainable.
    Storing 1,000,000GWh of natural gas for heat is unsustainable.
    The seasonal variations of wind and solar combined with hydro and biofuels requires more storage and batteries could ever provide and curtailment alone is not economical.
    So solve ALL those issues. Do ALL the math. Good luck. Took me almost two years and thousands of simulations.
  13. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Curtailment is and is becoming even more economical. Storage needs will be much less as noted above and much of this will be covered with overproduction of renewables:
    The result with regards to this study is clear: it makes even more sense to simply overbuild cheap wind and solar power plants than to try to fill in the gaps between supply and demand using fossil fuel power plants. Even leaving environmental matters out of it, it’s simply cheaper to overbuild low-cost solar and wind power plants.
    The Best Electricity Plan: Overbuild Solar & Wind Power Plants
    hill likes this.
  14. Lee Jay
    5,850
    4,036
    The tanks are not that big, and it doesn't really matter anyway because they are stationary. Ours was a small tube trailer (20 feet long and 6 tubes, IIRC). They make them 10 times that large and even ordinary gas stations have three gas tanks larger than those (my local Costco has 3 tanks each 2.5x bigger than a semi tank trailor).
    This just isn't an issue.
  15. Lee Jay
    5,850
    4,036
    That approach, called curtailment, is not economical used alone. It's part of the optimal solution, but not a huge part.
  16. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Except the part that it is a huge part.
  17. Trollbait
    12,501
    Stations here bury their fuel tanks under the parking lot, even though they'll have to replace them every 5 or so years, because real estate is such a premium. Same in California and other areas with higher population densities.
  18. bwilson4web
    16,187
    Funny enough, the first airworthy (at least ground tested) nuclear power reactors were direct heat transfer using graphite moderated, honeycomb cores. In theory, a nuclear reactor powered craft could use a 'stinger' holding the reactor. The intense neutron and radiation 'cloud' would make a tail approach impractical as the attacking missile would have to tolerate unshielded fission reactor radiation.
  19. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    My middle name is Hydrogen...worked with it my whole career
    I spell it with a "J"
    austingreen likes this.
  20. Rmay635703
    Rmay635703 Senior Member
    2,667
    1,687
    Somewhere in Wisconsin
    2013 Chevy Volt
    Not to mention hydrogen has a brutal temperature inflection point that causes the pump handle to freeze into the car if the action is too steady and temperatures aren’t heavily regulated.
    good way to waste 15-20 minutes on a brutally warm Southern California day, god only knows what would happen in a midwestern winter
