  1. Mendel Leisk
    41,898
    You can take that nut, and the stud, off, in advance, and leave both off. The stud I found tough to extract, due to difficult access, and I think dissimilar metals (steel stud and aluminum head). I was worried the E8 socket would round off the stud head, took it real slow. Not sure but I think with that lower stud off (and the top/front stud) you’re able to pull the cooler forward and out without removing the two rear connection studs.
    In @Ragingfit’s 4th gen engine transplant videos he ends up freespanning, from exhaust connection to the EGR pipe connection at intake manifold. They’re pinned in Prius v mod’s forum.
    Steph1972 likes this.
  2. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
    Fantastic !! I will take time to go check this video , I ‘m planning to do this in the next two weeks, I want to change the engine and inverter coolant too , transmission fluid and spark plugs ... so I am taking every information that could be useful , and watching « nutz about bolts » videos.... thanks a lot for helping newcomers....
    ASRDogman likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    1700 psi isn't enough to cut metal :whistle:.
    At least at 5 gpm, which is what most water hoses supply;).
    And you are moving the water stream around, not keeping it in one place for long(y).
    Steph1972 and Mendel Leisk like this.
  4. ozmatt
    ozmatt Active Member
    637
    263
    Australia
    nine hundred and thirty three pages omg!
    TheeWood and Steph1972 like this.
  5. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
    Today I cleaned the EGR pipe , mostly to check if it’s clogged or just dirty. Good news , a bit dirty , put some oxy in it , brushed it and « voilà « !! My Prius is almost 100k miles , so maybe my driving style or the fact that my oil is always clean due to oil change at 6k miles is helping .... Still planning to clean up the EGR valve and cooler, just waiting for the sun :whistle:.... took me 30 minutes , worst part was to take the pictures ...
  6. Mendel Leisk
    41,898
    Sounds good. (y)
    Don’t forget: intake manifold too. Pay special attention to the small passages exiting the sidewalls of each intake port; those are the final leg of the Exhaust Gas Recirculation flow on way to combustion chambers.
    You might even start with the intake; it’s relatively easy. Again, watch the @NutzAboutBolts video, links and torque values:
    Bad Flywheel | PriusChat
  7. tony_2018
    tony_2018 Member
    227
    68
    Fuckin christ....anybody link me to the instructions on removing the radiator? 3rd gen non-V?
  8. ChapmanF
    18,537
    Just leave it in place and turn the coolant into wine. Problem solved.
    Burna J and sfprankster like this.
  9. tony_2018
    tony_2018 Member
    227
    68
    Lol, figured it out. Crazy design
  10. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Collecting sun with the solar roof panel to charge the lifopo4 battery, must feed subwoofer amp.
    D567172F-AEFF-4521-AF3A-202D453D8408.jpeg 441C7F4B-E9D7-4EAE-B910-941DBBED597B.jpeg
    joeynickels, hoffeck and Burna J like this.
  11. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
    Any updates ?
    Curious to know if it works well !!
  12. AzusaPrius
    AzusaPrius Senior Member
    2,232
    930
  13. ASRDogman
    ASRDogman Senior Member
    7,818
    3,982
    PriusWindowTint07.jpg PriusWindowTint04A.jpg PriusWindowTint02.jpg I tinted the door windows Friday. Sunday did the rear deck window, in a garage.
    This morning I did the 4 small windows. They were the easiest of course.
    I did didn't want to spend $250 to have them tinted. I paid $28 for precut tint off ebay.
    You definate want to do it in a garage, out of the wind! When I started one of the back windows,
    there wasn't any wind. When I finished, a breeze started. When I finished the other back window,
    a heavier breeze. As I was doing the drivers window, the wind picked up. By the time I
    started the passager front window it was blowing pretty hard. It was a little tricky to get the plastic
    off the tint and the tint on the window with the wind, but it actually went fairly easy.
    NOT a perfect job, but for $220 less, it's good enough!
    I used 42%.
    icyrius, jerrymildred and Grit like this.
  14. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Been thinking about those low cost diy tint myself. Yours turned very out nice.
  15. ASRDogman
    7,818
    3,982
    Thanks! You DO want to be OUT of the wind, and sun though.
    And clean the windows with a razor blade after washing them.
    I used Gila window tint solution left over from tinting my friends sliding glass doors.
    Don't forget to clean the glass UNDER the rubber slides, on the door panels. Use an old
    credit card or gift card to get down under there. I didn't do that on the first window, and it
    took a long time and work to get the tint to stay down. I did the other ones and it was a lot easier.
    Here is the video I watched to do the rear deck/hatch window with the defroster lines.
    It worked very well. But, only time will tell if it starts peeling up. I'm hoping not! :)
    DO NOT, I REPEAT, DO NOT LIFT THE TINT AFTER PUTING IT ON THE REAR DECK WINDOW!!!!
    I realized I was off just a little after I started to squeegie out some of the water. It wouldn't slide, so I peeled
    it back and adjusted it. BAD IDEA! I pulled up some of the defroster. :( It doesn't look like I peeled
    off all of it and I'm hoping there is enough to still have contact. Next time it fogs up I'll see if that line is bad.
    Just slide it around to adjust it BEFORE you start removing the water, to get it aligned on the window.
    And pull all the plastic trim off the back window. It was pretty easy to get to all the tint without having to
    fight the trim pieces.
    Here is a link to remove all the trim:
    Here's the link I watched to clean the defroster strips on the back window:
    This is where I bought the tint from:
    PreCut Window Film for Toyota Prius 4DR Hatch 2010-2015 Any Tint Shade VLT | eBay
    He shipped it FAST! And it was in a cardboard tube, solid!
  16. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
    Really nice , looks sharp !!(y)
  17. ASRDogman
    7,818
    3,982
    Thanks! The windshield strip is next. :)
    #18657 ASRDogman, Feb 22, 2021
  18. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    409
    2013 Prius Plug-in
    Added black suede to the headliner, and pillars after adding sound deadening matt and foam padding to the ceiling. Also sprayed expanding foam in the various cracks/holes in the roof. The nose from the roof rack, basket and LED light bar was way too loud! Next up is to add sound deadening to the floor under the seats and the doors.
  19. Mongiamc10
    Mongiamc10 Junior Member
    66
    22
    I have never posted in this thread, but within the last year or so I have done a few things:
    1. Tint
    2. Installed Tanabe springs, Prius Plus RSB, and Cusco front tower bar @HybridPit
    3. Picked up some Rays SuperEcos in 17s off of here and wrapped in Yokohoma Avid Ascend GT 215/45
    4. Installed Valentis rear tail lights myself
    5. Installed C-West front spoiler along with OEM Ground Effects sides and rear myself.
    Next up, I will probably install a new radio (looking at the Sony XAV-AX1000) and maybe go to Prius Plus springs or get some Revel coilovers.
  20. black_jmyntrn
    1,728
    409
    2013 Prius Plug-in
    Yep, I live right off Via Verde.
