Transaxle oil change at 135k?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by rolan787, Mar 13, 2021.
  1. rolan787
    rolan787 Junior Member
    33
    Puerto Rico
    Hello, I have a 2012 Prius v with 135k miles that has never had a transaxle oil change. Was wondering if it would be ok to change it now or if it may cause problems down the road. I've never had a CVT before and I'm basing this on traditional automatic transmissions which sometimes start slipping and having problems if the oil is changed after too much time, this happened to me on a 2000 Jetta with a first change at 90k miles. Thoughts or experiences? For sure I know never changing the oil definitely will cause problems down the road...
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Better late than never.
    The Prius doesn't have a CVT in the manner you're probably thinking. It's an eCVT which operates completely differently. Put very simply, it uses two electric motors and a planetary gear set to distribute and proportion power to and from the wheels, engine, and battery. No clutches (except limited travel damper plates connecting the engine & transaxle), and no torque converters. It's a marvel of engineering.
    If I'm not mistaken, the v has the same transaxle as the regular Gen 3 Prius which is a P410. Here's a quick look at how it works. Professor Kelly isn't the most exciting teacher, but his content is tremendous.
  3. Kenny94945
    Kenny94945 Active Member
    858
    433
    Sausalito
    2016 Prius v wagon
    In my experience a drain and refill causes no harm.
    A power flush can cause problems.
    I would be inclined to do the oil change.
    Good luck with your project.
  4. rjparker
    10,503
    6,593
    Change it. You electric motors will thank you.
    jerrymildred likes this.
  5. Mendel Leisk
    41,898
    Nothing wrong with changing it now. 125k sooner would be even better.
  6. rolan787
    33
    Puerto Rico
    Thanks for the replies! I'll let you know how it goes!
  7. Mendel Leisk
    41,898
    Stick with Toyota ATF WS fluid. Purchase 4 quarts (plus the fill and drain bolt washers).
    Torque for both bolts is 29 ft lbs. Remove fill bolt first, just in case you encounter problems. A longer handled wrench or breaker bar is good. They’re both 10 mm socket head cap screw, and there are Allen-key style “sockets” available for ratchet wrenches. Don’t even entertain using an Allen-key and pipe extension.
    Correct level is easily achieved by filling till it flows back out, with the car raised and LEVEL.
    It’ll take about 3.5 qts to fill. A funnel with hose from above is dead simple: just go slow, 100 cc at a time, beyond 3 qts. Toyota recommends to NOT save left over, just recycle.
    Addendum: Attached Repair Manual excerpt has transaxle fluid instruction. It's for regular 3rd gen, but the same procedure for the v:
    #7 Mendel Leisk, Mar 14, 2021
  8. jerrymildred
    11,517
    14,157
    Tampa, FL
    Also, it's wise to note the steps in the instructions: loosen the fill bolt before the drain bolt just in case you have problems getting the fill bolt loose. No fun draining the fluid and then discovering you can't fill it because the fill plug is goobered up.
    TheLandYacht and meeder like this.
