2020 oil changes: every 10,000 miles?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by priusmatty, Feb 19, 2021.
  1. prime grip
    prime grip Member
    115
    56
    SO CAL
    Cool, at 10,000 miles they can be certified on mine also, but in the mean time @ 5000 miles it'll be on my own time. ( oil changes ). Each has there own.
    priusmatty likes this.
  2. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    I continue to do oil changes every 5k miles as I do a lot of the things the manual considers severe. I have always brought my own oil and oil filter (and drain plug crush washer) to a Pep Boys next to me and have them do the service. $20 for labor AND they do a free tire rotation as well. If I were to bring in my own stuff to the dealer, they charge $40 for the oil change LABOR plus $35 for the tire rotation. So looking at $75 plus tax.
    I would love to have it done at Toyota just for the peace of mind that the techs know what they're doing for my car specifically and also have all work properly documented. But paying an additional $55 for the same work is just a little hard to swallow.... Going in for my final 25k maintenance this Saturday then will probably just continue the oil changes at Pep Boys. It's not rocket science doing oil changes on these cars.
    #42 jteran5, Mar 21, 2021
    priusmatty, PaulDM and davecook89t like this.
  3. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    Every 5000 miles that would be 7 oil changes a year for me. I will keep it at the factory recommendation.
  4. prime grip
    prime grip Member
    115
    56
    SO CAL
    Hey jteran5. how much is your oil , filter and washer ? I'm at $32.00 w/ toyota filter from dealer & mobil 1 from walmart. Can't beat the price for self oil changes at 5000 miles compared to $79.00 at the dealer for sure. Nothing to lose.
  5. Mendel Leisk
    41,865
    I’m about $27.50 CDN for:
    toyota filter: $8.50
    4.2 litres Toyota 0w20 bulk (($4.50 per litre)
  6. prime grip
    prime grip Member
    115
    56
    SO CAL
    Great price !! I love it when we can beat the dealers outrages prices for sure. GOOD JOB
    priusmatty and Mendel Leisk like this.
  7. Mendel Leisk
    41,865
    Dealership sells me that oil too. Used to be even cheaper, they just kept copying previous invoice lol. Someone wised up finally, still a decent price though. I bring a gas container, get 8~9 litres at a time, do our sons vehicle too. :)
  8. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    My dealer is always sending me coupons for $10 synthetic oil changes with filter. I still change my own.
  9. ETC(SS)
    7,334
    I change mine every 5,000 miles, and as notoriously stingy as my beloved company is with their vehicle maintenance......so do they.
    Will the oil last 10,000 miles?
    Yep.
    no bout a doubt it....but I've noticed a trend where people who own vehicles that take OWNERSHIP of the ownership task have fewer troubles with their vehicles.
    Since I change my own oil the cost of each change is something like $20.
    That's with an OEM filter.
    This makes for easy math
    $400 extra dollars more or less for 200,000 miles.
    - somebody check my math, but that seems to me to be cheap at the price.
    One last thing.
    People who get into oil-wars often forget that OCI (oil change interval) is substantially different than OCI (oil check interval!)
    Everybody knows what the oil change interval is.....but almost nobody knows that one of the maintenance checks in the Warranty and Maintenance guide calls for the owner to check the oil LEVEL.
    If you at least do THAT you will probably be OK since most car owners only keep their car for about 120,000 miles, and even if you skip an oil change, that's probably not going to catch up with YOU, but rather the person who has to take care of the car on the back nine.
    YMMV
  10. jteran5
    413
    203
    2019 Prius
    XLE AWD-e
    My oil is a premium "boutique" oil. It's the most shear-resistant after comparing against Motul, Amsoil, and others and has a high TBN and moly in it. So it's pricey at $60 or so for the 4 LITER jug. Which is 4.2 quarts so I picked up an extra liter in case I was short (recommended is 4.5 QUARTS), also because I'm using a larger/taller filter and worried that 4.2 quarts might not be enough.
    I'll price out below per quart after all said and done as I bought extra oil to get a discount after $100 with vendor (prices are USD) :
    Oil - $51.71 for 4.5quarts ($11.49/qt)
    Filter - $9.56
    Crush washer - $3.50 from Toyota Dealer
    Total : $64.77 for supplies
    What I had pictured is a magnetic drain plug for peace if mind it will catch anything in there. It's a $35 plug but I won't have to change THAT again and just pay once.
    Again, this oil is pricey but very very good specs. Haven't seen anyone close that low of a NOACK
    Below is the plug I used and the specs of the oil 20210306_232626.jpeg Screenshot_20210307-010645_Brave.jpeg
    #50 jteran5, Mar 23, 2021
    davecook89t likes this.
  11. prime grip
    prime grip Member
    115
    56
    SO CAL
    Nice . I gotta get one of those Mag drain plugs on mine. Thanks for the info.
  12. PaulDM
    PaulDM Active Member
    616
    319
    UK
    2022 Prius
    Excel
    10k in every Prius I have owned. No issues over 300k miles
  13. Mistrall22
    Mistrall22 Junior Member
    Montreal
    I have put 300,000 km on my Prius 2010 and follow the 10k recommendation. Engine still run like a new one.
  14. Mistrall22
    Montreal
    priusmatty and Elt31987 like this.
  15. sparky12
    sparky12 Junior Member
    22
    Virginia
    2021 Prius
    XLE AWD-e
    Just got a 2021 XLE AWD-e, planning on doing the first oil change at 2500m. I have lifetime oil changes through the dealer but I doubt they'll do that one for free. But it's no matter if they do or not. I just don't want to crawl under the car and do it myself these days. I'm ok with 10,000 mile oil changes. Had a 2013 Prius v and still have a 16 Tacoma following the 10k interval. Neither one used any appreciable amount of oil between changes. The Prius had 180k miles and the Tacoma has 100k. The only Toyotas I had that used oil I had those high performance mesh air filters. I've gone back to regular air filters these days.
    Montgomery likes this.
  16. BellevilleMXZ
    BellevilleMXZ Member
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
    Just a thought as a (Chrysler) dealer Tech....manufactures are ONLY concerned with making the car last to the end of the warr. period....thats IT. They have a vested interest in selling you a new one after warr. is up, NOT making a car last 100k plus. Oil burning/engine issues following the long change interval is VERY common on ALL makes as miles go up. I certainly wont be going 10k on my new Prius. If you do mostly highway, can prob push it some, but I'll be sticking to 5k. While I don't have a ton of experience with hybrids as of yet, I would think if you do alot of slow/town driving, and with all the start/stop of the ICE , thats even harder on the oil.
  17. roguetadhg
    roguetadhg Junior Member
    2023 Prius
    Limited AWD-e
    I'm getting mine every 5k. But I use my car for commercial purposes where it may not be racking up the "miles" but does the "hours."
    If it was for personal use, I'd only do it 10k.
  18. brenthon
    brenthon Junior Member
    GA
    I do it every 6 months or 8,000kms.
  19. Mendel Leisk
    41,865
    That was the Toyota Canada recommendation, for third gen. Now with fourth gen they're saying the same as the States: yearly or 16K kms, whichever comes first. Third and fourth gen engines are not that different, essentially the same, so it seems mainly a policy change, NOT driven by the engineers.
  20. privilege
    privilege Active Member
    659
    169
    Birmingham
    printer go brrrrrrrrrr
    and errryone gets a cert !
