Dash display not working after replacing 12 volt battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Miser, Mar 29, 2021.
  1. Miser
    Miser Junior Member
    Huntington Beach
    I have a 2005. I replaced the 12 volt battery and everything worked fine. After a few drives, the dash display turned off. I unplugged the 12 volt and let it reset and the dash display turned back on. Then today after a drive when I went to turn it back on, once again the dash display doesn't work. The car runs fine, I just can't see anything on the dash. Also I have to hold the power button down for sometime before it shuts off. Any idea on a fix for this issue?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
  3. Miser
    Miser Junior Member
    Huntington Beach
    Thank you, what does it mean I’m being moderated?
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,475
    1,553
    NJ-USA
    I believe that it means there are some limitations on what you can do in your posts- such as not being able to include links.
  5. dolj
    dolj Senior Member
    7,659
    3,878
    Wellington, New Zealand
    ... and it mainly means that a moderator will check each of your posts to make sure they are being made by a real person and not a robot spamming the forum. Sad, it has come to that but that's where we are. Your first 5 posts are moderated.
