OBD for Dummies
Discussion in 'Gen 3 Prius Audio and Electronics' started by Rocky Mountain Priusman, Mar 30, 2021.
Tags:
  1. Rocky Mountain Priusman
    Rocky Mountain Priusman Active Member
    224
    112
    Canmore, Alberta, Canada
    I hate to start another thread here about this subject but I've done a fair bit of reading and I am overwhelmed and not really sure what to try. It seems like most options dont work well for everyone and each option only does some things.
    I am looking to get an OBD reader and an app that works with my 2010 Prius. Ultimate goals are:
    1. Check codes and clear check engine lights
    2. Create a live readout (gague or dashboard) on one of my old phones (Android or iOS) that I can leave plugged in that shows coolant temperature and possibly other simple stats about the car
    Can anyone point me in the right direction? I looked at the ELM 327 OBD devices and Engine Link app and they have junk ratings on Amazon and the app is claimed by most of the reviews to no longer work.
    Are there some options that might be a bit more expensive but can be relied upon? I know about Techstream and the Min VCI but for now I am looking for something simple that I could leave plugged into the car that would sync to an old phone that I also leave in the car.
    Thanks in advance for your comments.
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I started with an XHorse Clone. I ended up buying a Drew Technologies Mongoose Pro (aka Techstream Lite). I actually have a VXDiag MultiDiag Vehicle Interface Module which can work with Techstream and the Prius if I pay for the extension (software HDD and license), but I just pay Toyota $65 and use the latest Techstream for two days or so when needed.
    Looks like you'd want something that connects to Torque, or maybe something like Carista. I've heard a lot about Dr
    Prius lately. I'm afraid I don't have experience with these more mobile app products having the arsenal that I already have....
    Best of luck with your choice!
    moto g(7) power ?
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    1. Usually when the light comes on, something needs to be fixed. :)
    2. The OBD port is powered even when the car is OFF. If you leave a scanner/reader plugged in when OFF it can run your battery down.
  4. Team_Geek
    Team_Geek Member
    62
    32
    MN
    I went through the same with my car a month ago.
    I purchased the Panlong obd scanner from Amazon
    There is a coupon code for 20% off at the Dr Prius app website - JD3JHWBE
    I use a mix of Hybrid Assistant, Torque, and Dr Hybrid/ Dr Prius apps on a used Galaxy S7 that I bought from a friend.
    Combined that with a wireless charging dock from Walmart and I’ve got a great supplemental dashboard for pretty cheap.
    This lets me view and clear codes, easily get into maintenance mode, and disable backup and seat belt beeps.
    Carista app and dongle have more options to tinker with but app is subscription based and what I’ve got so far is all one-time purchases.
    #4 Team_Geek, Mar 31, 2021
    AW82 likes this.
  5. Rocky Mountain Priusman
    224
    112
    Thanks - thats helpful. Never heard of that brand before but seems reasonably priced and like it should work. Your link to Amazon doesnt come through. Did you get the basic OBD w/ wifi, the one with bluetooth or the one that plugs in and has its own screen?
  6. Team_Geek
    Team_Geek Member
    62
    32
    MN
    Shoot! Sorry. I updated the link from my original post. Does it look better?
    If not go to Amazon and search for “Panlong Bluetooth OBD2 OBDII Car Diagnostic Scanner Check Engine Light for Android - Compatible with Torque Pro”
    It should be blue and is $10.99. It is Bluetooth only and is just the dongle.
  7. Rocky Mountain Priusman
    224
    112
    I had a look at this - looks like it costs around 450$? Thats a bit out of my budget, but I will keep it in mind should I need to do some more serious diagnosis. Right now I am not actually trying to address a particular problem. I'd just like to have a closer look at how the car is working, as well as have it on hand should I get a Check Engine Light in the future.
  8. Rocky Mountain Priusman
    224
    112
    I cant see it but I think thats because PriusChat.com censors external links automatically.
    Thanks for the update. I've ordered it and will report back. I think this will be a good solution for me and at a fairly low price.
    Is that your Mach-E in the photo? Do you like it? Looks like a really cool car.
  9. Rocky Mountain Priusman
    224
    112
    Okay I got the Panlong OBD (wifi version since that was compatible with Android and iOS and I wanted flexibility). I also purchased OBD Fusion app and it works quite well for me. It paired up without any problems. I have had it disconnect a few times in the middle of a drive so I will work on seeing whats going on there.
    I dont see hybrid specific metrics (inverter coolant temp, MG1 and MG2 info), but maybe its buried or you have to pay extra for that info?
    Anyways it does want I want, which is show basic stats about the car. The main one I wanted was engine coolant temp so i can keep an eye on that on long road trips.
    Also it shows no codes, and says the codes havn't been cleared since 60,000 miles (100,000 kms) ago. Which I take as being good news!
    Thanks everyone. This was a lot more simple than I thought. I just needed to pick an OBD reader out of the many that are out there.
  10. GabrielD
    GabrielD Member
    179
    72
    Romania
    2014 Prius+ MPV
    You should find the best app for what you need.
    Hybrid Assistant: App
    I was advised to take the OBDLINIK LX and it works like a charm, but you can check on the page for your reader...
  11. Team_Geek
    Team_Geek Member
    62
    32
    MN
    Nice going! I’d second Hybrid Assistant app. Tons of info built into it and it’s free. If you tap each individual panel within the app you get more detailed info. It is my go-to app when driving the car.
    Mach-E is my current dream car, sadly it is not in my garage yet. But my wife saw one in person and liked it so at least I’ve got that going for me...
    GabrielD likes this.
  12. Rocky Mountain Priusman
    224
    112
    I just got Dr. Prius as well. Did the battery life expectancy test. Got 79.5%. Not bad for a 11 year old car with 100,000 miles!
    This would have been a great thing to have on hand when testing a used car for purchase. I felt like likely the battery was good though just judging by MPG history on the trip computer.
  13. ChapmanF
    18,562
    The Techstream software will happily (try to) work with any of those dongles, as long as the .DLL files that go with them are installed. The expensive one from Drew is the one Toyota officially vouches for, but for many tasks, much cheaper ones would work.
    It's a special case with jzchen, who recently self-reflashed one of the car's ECUs. That's a pretty rare thing to DIY, and I would want the official supported dongle if I were going to do it, just to reduce any chance of bricking the car. (Generally, when I want a reflash, I go to the dealer and say "I would like you to flash this update please", and they say "ok" and charge me about ¼ the price of a Drew dongle, and I haven't done that 4 times yet, so I'm still money ahead, and if anything goes wrong in the reflash, they get to fix it.)
    But for most diagnostic tasks, there's not much downside to trying the cheaper dongles. The worst thing that will usually happen is that the particular Techstream diagnostic routine you want to use won't work, not that anything bad happens to the car.
    I've usually grouped dongles into two giant categories: ELM327-based or workalikes, which most kinds of OBD phone apps and the like expect, anything that the phone or computer can talk to using the language of the ELM Electronics 327 chip, and then J2534 dongles, which are the kind Techstream expects, and usually more money.
    But it turns out things aren't quite that clear-cut. The J2534 standard isn't a hardware standard, it's a standard for functions in a Windows .DLL library that a program like Techstream can load, and how that library talks to the actual dongle can be any way it wants. If somebody builds a dongle out of clarinet reeds and Scotch tape and writes a J2534 DLL that works with it, then Techstream will see that as a J2534 dongle.
    That leads to something I didn't know (and haven't confirmed myself, but someone else here has posted it): the really common clone-of-XHorse-Mini-VCI that everybody talks about here is apparently ELM327-based inside. And the DLL that comes with it is essentially a J2534-to-ELM327 communication layer. And the person who reported that, also reported even using other ELM327-based dongles, with Techstream, using the DLL that came with the Mini VCI.
    That all falls waay out in the territory of "stuff I would never have learned because I'd have had way too much sense to try it", but I guess somebody has, and reportedly it worked.
    That still doesn't mean every Techstream function will work, Different dongles still have hardware differences in which actual electrical wiggles they are able to put on which pins.
    Techstream comes with a screen where it will try to figure out which wiggles your dongle is capable of:
    There's also a free download from DrewTech to do the same in more detail:
    They're the outfit that makes the pricey Toyota-supported dongle, but that utility is free and will test whatever dongle you've got.
    #13 ChapmanF, Apr 2, 2021
    wukong sun, Newbie2 and jerrymildred like this.
  14. Rocky Mountain Priusman
    224
    112
    Very interesting, ChapmanF - now that I have the OBD basics down (Panlong wifi OBDII plus iOS apps) I can start looking into that.
  15. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    memory and Danny S like this.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Just a side note. PC does not censor external links. Ad blockers do, though.
    Yes, I think I paid $10 for the Toyota PIDs for OBD Fusion and they include the Prius and Prius Prime data. If you use Engine Link, it can import the PIDs that are available for free for Torque Pro, but that's a little more involved and I don't know how they work on the Gen 4 but they were fine on my PiP as I recall.
