best place for an engine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Adriana Ponce, Mar 29, 2021.
  1. Adriana Ponce
    Adriana Ponce New Member
    Bell Garden Ca
    We own a 2011 prius and just found out we're going to have to get a new engine. What is the best online shop you guys would reccomend?
  2. Krall
    Krall Member
    125
    37
    NY
    Same here. I was thinking a salvage yard with a warranty, but that's around $2700 uninstalled and usually engines with over 125k
  3. Mendel Leisk
    41,925
    Can you share more details?
    How many miles on it?
    Any specific issues you’ve noticed, say excessive oil consumption, shaking at start up, coolant loss, things like that? Are you dealing with independent shop or dealership?
    Are they giving any more specific info, or just “you need a new engine”?
    Have there been any warning lights and if so has anyone read and divulged trouble codes?
  4. bisco
    52,399
  5. Prodigyplace
    12,682
    11,833
    Central Virginia
    I am waiting for @Mendel Leisk to argue it is in the rear like any good old Volkswagen.
    jerrymildred, bisco and Mendel Leisk like this.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Not everything can be solved "online".
    Are you sure you want to invest that much in a 10 year old car ?
    If the HV battery is original, that probably will go next.
    And with a cost similar to a new engine.
    This may not be a good plan.
    P.S. A second opinion on needing a new engine might be a good idea.
