ICS Indicator flashing
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by remmerss, May 19, 2021.
  1. remmerss
    remmerss New Member
    2018 Prius Prime
    Hello everyone, I am a proud new owner of the 2018 used Toyota Prius prime advance with 25k miles on it. It has a clean history and no scratches while driving it home today. I noticed what I learned was the ISC indicator, after doing some digging I found that it should not be flashing. I went to the form and found this <ICS Reset | PriusChat> but that was not helpful for my situation, even tho I tried the fixes.
    What I come to the form with is. Is this normal? Should I be concerned? Should I return the car? Is there a fix for this that is simple? If I do keep the car and get it fixed are there long-term issues that I face with having this arise so early on?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,800
    2017 Prius c
    No not "normal".
    You should get it checked out.
    Whom ever you bought it from should get if fixed.
  3. remmerss
    remmerss New Member
    2018 Prius Prime
    Is this a concern that I should be worried about for the longevity of the vehicle?
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,145
    Tampa, FL
    Sam's right. Not normal. If it's not just dirty, then something needs fixing. I'd take it back where I bought it if something goes wrong on the first day.
  5. Mendel Leisk
    40,975
    Just in case anyone else is struggling:
    ICS = Intelligent Clearance Sonar
  6. remmerss
    remmerss New Member
    2018 Prius Prime
  7. jerrymildred
    11,517
    14,145
    Tampa, FL
    Just lack of function and the annoyance. My wife's car has ICS. I turn it off when I'm driving it on a long trip. I find it annoying as well when it's working right.
  8. sam spade 2
    7,035
    2,800
    2017 Prius c
    You won't know that until you know what is causing the fault to show up.
    Since you just bought it, there is NO good reason not to insist that the seller fix it.
    Other related things might fail later.
