Strange Window Defect - Driver's Side
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Ozzzy, May 31, 2021.
  1. Ozzzy
    Ozzzy New Member
    CT
    Our 2017 Prius Prime Plug-in Advanced has a very strange driver's side window defect, that appears to be slowly growing. It is occurring between the window laminate layers... if you touch the window on either the inside or outside, you feel nothing. It changes in color between hazy white and hazy clear, depending on the temperature of the day. HAS ANY ONE ELSE SEEN THIS BEFORE OR KNOW WHAT'S GOING ON HERE??
    We spoke with Hoffman Toyota service about it, the last time we brought it in for maintenance, but they said they would charge us to around $400 just to take apart the door just to determine what it is. They seemed baffled by it. :-/
  2. krmcg
    2,592
    2,392
    Whittier, CA
    I like the look...
    Deleted member 219929 and MIkeDr like this.
  3. Mendel Leisk
    41,824
    There’s some special laminate or coating on the front/side windows of some high-end models, to help rain run off IIRC. My guess would be that’s the culprit.
    this thread could have legs, like the sunroof gasket deterioration, metallic white paint peeling, C pillar peeling, pleather steering wheel peeling, and touch screen reboot threads.
    Ozzzy likes this.
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,065
    547
    Tucson, AZ
    2021 Prius
    I did a quick Google image search for delaminating window glass and came across several similarities. It does look neat, though. Sort of like Mandelbrot images.
    Ozzzy and krmcg like this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    I've not seen it on a PRIUS - have seen it on older cars. BUT - I'd be talking to TOYOTA Corporate - as it seems like a manufacturing defect.
    Doug McC, Ozzzy and Mendel Leisk like this.
  6. Mendel Leisk
    41,824
    Yes, one that could crop up more. I think they’d like to see it; should be able to better than the baffled locals asking $400.
    Ozzzy likes this.
  7. BellevilleMXZ
    BellevilleMXZ Member
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
    Bad glass....seen before on other cars. If Toyota wont help, see if a glass place will put a used in....but price a new one first....might not be that bad $$$
  8. Ozzzy
    Ozzzy New Member
    CT
    Hi Guys,
    Just wanted to follow up on this thread with the good news that I indeed did contact Toyota Corporate, like you recommended.
    I opened a case and spoke to several corporate customer service agents that said that they were unable to help since there were no recalls of this type and the car was beyond the warranty period. But they did forward the case on to the dealership that sold us the car (and from which we had purchased an extended warranty). Once the dealership received the corporate request, we got a swift reply from them that they were happy to help resolve the issue for us at no charge because we were valued customers (funny how they didn't feel this way when we first brought the issue to their attention months prior and wanted to charge us $400 just to take the door apart). But it still took months of persistent follow up calls & emails, and patient waiting before the window was finally replaced for us at no charge at the dealership this week (and no, the extended warranty did not help us at all in this situation). But for me, best of all was the final acknowledgement by the Dealer Service Manager and Toyota Representative, that the window was indeed severely delaminated and caused by a rare manufacturing defect. So hopefully now they won't tell any other customer that calls with this same issue, "we've never seen anything like this before".
    So, thanks or the good advice! :)
    AzWxGuy, vvillovv, Doug McC and 4 others like this.
  9. San-Sei
    San-Sei New Member
    Longueuil, Квебек, Канада
    Hello, I have a same problems with both my front windows.... The dealership told me yesterday that is was my error, it not a warranty and it not a factory defect. Have you same papers from your dealer where they accepted your claim? Maybe it will helping me to show to my dealership that i'm not alone with this problem. Thanks
  10. San-Sei
    San-Sei New Member
  11. vvillovv
    vvillovv Senior Member
    4,324
    1,511
    NY
    @San-Sei I believe you will need to post a few more times before your pics will show up.
    I can't speak for @Ozzzy though if I were reading this thread and had the problem I'd follow the same path to resolution as he did and give Toyota a call to see if they will help you work through the available channels.
  12. ISFdude
    ISFdude Junior Member
    Queens New York
    I’ve seen this on so many Prius prime and premium trim models. And to be honest, there’s nothing premium about these windows. These laminated windows are very weak, crack very easily and all sorts of defects. The tempered glass is much better that comes on the base model Prius. You can install tempered glass and remove those laminated front window windows. Tempered glass is stronger In some cases, it’s best to also replace the window molding gasket so you get a nice tight seal as that’s the difference between the windows is also the window seal.
    UN4GTBL likes this.
  13. Ed S
    Ed S New Member
    Michigan
    2018 Prius Prime
    Have the same thing on both front windows of a 2018 Prius Prime Advance I just bought. Since they're at the same place on both windows and look almost identical I'm guessing that they're something intentional: either artistic or perhaps provide some window function e.g. defogging, heat, etc.
  14. Ed S
    Ed S New Member
    Michigan
    2018 Prius Prime
    w
    I changed my mind- after looking at both windows at a different time-it's a defect. I wonder why it appears on the bottom of both windows near the center, though, with both patterns semicircular with about a 2" radius.
  15. UN4GTBL
    UN4GTBL Junior Member
    Technology
    The front passenger window on our 2017 has this.
