DIY Grid Reconditioning Charger
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Abarnabe, Sep 13, 2020.
  1. Abarnabe
    Abarnabe Member
    165
    98
    Netherlands
    You may find the instructions here Gen 3 HV cooling fan motor: wiring diagram? | PriusChat
    tangerino and alltherightpills like this.
  2. alltherightpills
    alltherightpills Junior Member
    26
    42
    St. Louis, MO
    Thanks, that's good info - now I know exactly where to apply my 12V for the fan.
    Is that 4 pin connector a standard part? Hoping to buy the female end to keep the wiring super simple.
  3. zeno
    zeno New Member
    romania
    Hello guys,
    Regarding prius g2 battery reconditioning... maybe you can make me understand:
    if you follow the Prolong instrunctions for descharging and if you use a grid charger, you should descharge the entire 28 modules battery to 134/101/84V, meaning 4.8V/3.6V/3V per module (0.8V/0.6V/0.5V per Cell).
    If you are discharging individual modules with kind of iMax, the disch voltage should be 6V per module, meaning 1V per Cell.
    Some posts says that you should never discharge a NiMh cell under 0.8V.
    Can you please advice which is correct?
    Many thanks
  4. Abarnabe
    Abarnabe Member
    165
    98
    Netherlands
    Discharging below 1 volt is possible, it's risky , but it's necessary for reconditioning, it should be done at very low current and only according to prolong directions, in order to minimize the risk of polarity inversion. If discharged below 1v at higher current, there is a risk of polarity inversion and the cell will die.
    #64 Abarnabe, Dec 4, 2021
  5. zeno
    zeno New Member
    romania
    Thx a lot!
  6. mjoo
    mjoo Senior Member
    1,154
    1,326
    Michigan
    A single NiMh cell can be discharged down to zero volts. At that low voltage it can break up the crystals (memory) that lower capacity.
    The problem with a Toyota hybrid is that you're discharging all 168 cells and as they age they all have different capacities. Discharging the high capacity cells to low voltages can over discharge the low capacity cells.
    Below is what happened when I ran the discharger at the 17 volt setting. Bank #5 (with 12 NiMh cells) fell below 2 volts. I was watching it on my phone and stopped the discharger when bank #5 dropped below two volts. After I stopped the discharger bank #5 bounced back to 12.9 (1.1V per cell). I would be concerned if the bank #5 voltage ended up being less than 12V.
    moto g power ?
    #66 mjoo, Dec 4, 2021
    bisco, Raytheeagle and JohnPrius3005 like this.
  7. Abarnabe
    Abarnabe Member
    165
    98
    Netherlands
    Before and after last reconditioning, this time the balancing voltage ended at 245v
    kc410 and JohnPrius3005 like this.
  8. Abarnabe
    Abarnabe Member
    165
    98
    Netherlands
    Latest developments:
    - 3D printed housing containing
    12 v 12A fan power supply, 250v 350ma grid charger and a meter.
    - 4 poles harness with fuse, 12v dc , 250v dc.
    When I charge I disconnect the original fan plug and I connect another one PN (6520- 0349) coming from the new grid charger.
    #68 Abarnabe, Sep 23, 2023
  9. Abarnabe
    Abarnabe Member
    165
    98
    Netherlands
    and the box
    beardlesswhelp likes this.
  10. Fury6z
    Fury6z New Member
    Paris
    Hey Abarnabe,
    I'm in France and want to build your grid charger – got any electrical schematics you'd suggest?
  11. Abarnabe
    Abarnabe Member
    165
    98
    Netherlands
    MAX2 likes this.
  12. Fury6z
    Fury6z New Member
    Paris
    Abarnabe likes this.
  13. Abarnabe
    Abarnabe Member
    165
    98
    Netherlands
    The choice was a long journey, I couldn't find anyone experimenting with led drivers as hv battery chargers before me, from google research I learned that the important requirement was constant current, which is exactly what led drivers are designed for. Finally I chose HLG-80H-C350 because it has an output of 257v and 350 mA which is much closer to the commercial conditiores like prolong with an output of 250 v. -350mA
    than the LPC-100-350 who has an output of 286v and I did' t want to risk to over charge the battery
    I believe there are even better options with dimmable voltage transformers to achieve a more precise output, but this was the simpliest solution
    #73 Abarnabe, Feb 14, 2025
    MAX2 likes this.
  14. Fury6z
    Fury6z New Member
    Paris
    Thank you for all this informations.
  15. A.J
    A.J Junior Member
    56
    Worldwide
    Putting in mind the above prolong automated discharger voltages and their manual bulb discharger table link you shared.
    My interpretation for Prius 04-15 Discharging circle for 220v AC incandescent bulb would be:
    First Discharge: 240vdc+ ~ 134vdc (using 400w bulb or less. e.g 60wx6)
    Second discharge: 134vdc ~ 101v (using 150w bulb or less. e.g 60wx2)
    Third discharge: 101vdc ~ 84vdc (using 50w bulb or less. e.g 40w)
    Kindly confirm if my analysis is ok.
    #75 A.J, Jul 19, 2025
  16. PriusII&C
    PriusII&C Active Member
    424
    142
    San Jose, California
    Somewhat confused with the data displayed on your discharger. At 169V and 0.285A, the effective resistance is 593 ohms. Assume you use 360W light bulbs, the effective resistance at 240V should be 240^2/360 = 160 ohms. So the resistance goes up significantly with lower voltage. I thought the resistance goes down as voltage drops.
    Did I miss something?
  17. Brian1954
    Brian1954 Senior Member
    2,081
    808
    South Central PA, USA
    Prolong has all the instructions on their website. Just follow the instructions.
  18. A.J
    A.J Junior Member
    56
    Worldwide
    That ain't my discharger, only used the image as illustration for my Bulb discharger. Charger owner is at Prolong Discharger problem | PriusChat
    Below is my upcoming setup
    #78 A.J, Jul 19, 2025
  19. A.J
    A.J Junior Member
    56
    Worldwide
    I read it, just want to re-confirm if i am on the right track.
  20. johnHRP
    johnHRP Active Member
    637
    183
    KA, DE
    Excel
    I am not sure Prolong or whatever we do with the battery can prolong our mind suffering and dying battery. It is a chemistry problem when the electrondes and the electrolyte reach the end life. Irreversible aging and just need money to replace it. It is waste of money, time, and moral dealing with dying battery and try to believe it can be reborn.
