Do rodents make nests in the battery cooling fan or venting?
Discussion in 'Gen 3 Prius Main Forum' started by Sal43, Jun 16, 2021.
  1. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    I recently cleaned out rodents nests from the blower motor and cabin air filter area, rear underfloor cargo compartment and airbox under the engine air filter. Should I buy a borescope to see if the batter fan or vent tube have rodents nests? Is there enough space for rats, squirrels, or chipmunks to get in there or is it unheard of? Would a cheap $15 borescope be able to get into there from the intake vent to be able to get a good look?
    48,998
    not that i can recall
  3. PriusCamper
    PriusCamper Senior Member
    10,931
    4,430
    Pacific Northwest, USA
    Clean your hybrid battery cooling fan for it's own sake... Rodents are know to make it easy for stuff to get sucked in there, but they probably can't get in there themselves. But you be the judge of how this particular Prius poster's pic happened:
    fotomoto and Mendel Leisk like this.
  4. ASRDogman
    ASRDogman Senior Member
    5,908
    3,167
    Do you drive everyday? Or does the vehicle sit a lot?
  5. Mendel Leisk
    38,255
    Yeah never mind the horoscope; open it up and clean.
    Samuel Williams Jr and Grit like this.
  6. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    I guess they don't call 'em squirrel cage fans for nothing. :D But I'd expect that if the fan was clogged you'd tend to hear it more often and stay on longer than usual. It kicks into high when the battery gets hot, and then it's audible from the driver's seat. It would be normal to hear the fan when going down a long hill -- lots of regen heats the battery up. But if you're hearing the fan come on more often than normal, it's worth cleaning very soon.
  7. ChapmanF
    15,111
  8. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    o_O
  9. Mendel Leisk
    38,255
    Doh!
    Grit likes this.
  10. Grit
    Grit Senior Member
    6,114
    4,040
    Wilkes Land
    im not a believer of horoscopes, read each one of them and they will apply to you, just not the month youre put in.
  11. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    Once every 2 weeks since February 2020 till June 2021 during the pandemic but more now.
  12. ChapmanF
    15,111
    I think $15 buys you a pretty cheap horoscope too.
    kmsbanr likes this.
  13. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
  14. bisco
    48,998
    why not just open it up and clean it as mendel suggested?
  15. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    If I had a plugin like you I'd do it every month, but it's way more complicated to to it on a regular Gen 3.
  16. Mendel Leisk
    38,255
    An hour or two. @NutzAboutBolts video shows the rear seat being pulled out, but that’s really not necessary: there’s one bolt needing removal, behind the seat cushion, just below fan inlet; just push apart seat bottom and back and reach through with a 12 mm socket on longish extension. Be careful not to drop the bolt.
  17. ChapmanF
    15,111
    That's a little like saying "whatever you do, don't think of a hippopotamus."
  18. Mendel Leisk
    38,255
    Haven’t dropped it. Yet…
