What part is this?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mr. King Andrew, Nov 9, 2019.
  1. Mr. King Andrew
    Mr. King Andrew Junior Member
    17
    Borrowing a picture from this thread: photos taken of the bottom of my Prius | PriusChat
    I see at least 3 different heat shields here. The one way at the back, the big long one in the middle, and then the angled one between those two (the one I'm pointing to).
    That one is loose on my car, and I wanted to find the part # for it. It seems I can only find the other 2 heat shields on the Toyota parts website. Does anyone know how to find the part number of that heat shield?
    This is for a 2010 Prius 5 by the way.
    Erin and the pets likes this.
    52,351
    try an on line parts place, they should have break out drawings. maybe camelback toyota or the like
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,725
    1,762
    Bay Area
    I usually call the Toyota dealership parts department to identify parts that are confusing to find. But it’s better to go to the dealership parts department in person since it’s easier to pin point it on their computer without guessing over the phone. That’s what I did the last time I needed a part that was hard to identify. It is an exhaust heat shield, hopefully you find the right part for it.
  4. Mendel Leisk
    41,865
    Is it just one of the fastener holes tore out? Maybe an oversized washer (get galvanized if possible) would work. They're often referred to as "Fender Washers". They're readily available at hardware stores.
    Washers Selection Guide | Engineering360
    #4 Mendel Leisk, Nov 9, 2019
    Raytheeagle likes this.
  5. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I have the 2010 too and the same heat shield is broken exactly like yours. I also couldn't find the Toyota Part Number from their part diagrams.
    Did you fix yours? Do you have the P/N? How much did it cost you?
  6. amarino
    amarino Active Member
    142
    105
    99
    toyolover likes this.
  7. amarino
    142
    105
    99
