Anyone try these mirror signals?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by BellevilleMXZ, Jun 1, 2021.
  1. BellevilleMXZ
    BellevilleMXZ Member
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
  2. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Id be interested as well
  3. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    States emphatically that it comes with no instructions and says nothing about how to wire them up?
    Interested - but wouldn't want to be the "early adopter"...
    Elt31987 likes this.
  4. Mambo Dave
    Mambo Dave Active Member
    641
    306
    2019 Prius
    L Eco
    The problem I had with another brand of LED strips was that the wires going to the strips were the tiniest gauge. Now, for home use I guess that would be fine as that is all that is needed to move the current. For vehicle use, with road vibrations, those tiny wires were the failure points at or near the lights.
    Valiant V likes this.
  5. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    I found that to be true of a couple of LED lighting devices I've installed on our sailboat. (retrofitting the old incandescent pictures) The fine wires are tough to work with - not east to splice or even make a good connection when there are only a few strands to work with. Even stripping them requires more precision tools.
    Wraiththe and Mambo Dave like this.
  6. Mambo Dave
    641
    306
    2019 Prius
    L Eco
    All great points. The plan has to be to solder the wires to an existing larger wire or wire harness, then considering using the liquid electrical tape on both that area and at the point of light attachment. Even then, failures eventually occurred.
    So for these turn signal lights, as long as the installation doesn't mar the finish of the mirror at all - in that one could take them off when one stopped working, and not leave a mark while doing so - might be worth trying out for funsies.
  7. BellevilleMXZ
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
    I have put a few sets of these on different cars without issue. You will find most mirror wiring to be very small anyway, aseverything is very low current. I wish I knew if wiring was in mirror, as if it isn't I'm not interested in trying to run wiring. May try and pop cover off and have a look
  8. Sezy
    Sezy Active Member
    431
    229
    37
    Saint Charles, Missouri
    2020 Prius Prime
    Ordered off Amazon for $50, jumped up to $70 the next day. Claims to have a year warranty. Should be here in a week. Going to give it a try based off these steps Avest Side Mirror install | PriusChat . Having trouble finding the pin ends/molex connector/harness pins so I can route the wires through the empty pin slots in the door connectors.
  9. BellevilleMXZ
    72
    61
    Ontario,Canada
    2024 Prius
    Limited AWD-e
    Nice !! Let us know how it goes!
  10. brenthon
    brenthon Junior Member
    GA
    I'm interested also. Keep us posted.
  11. Sezy
    Sezy Active Member
    431
    229
    37
    2020 Prius Prime
    Got one side installed with wires but not connected to blinkers yet. Not liking the flat color or brown and plan on vinyl wrapping it gloss one day. Tested wire continuity while putting connections back together and make sure they light up. Added sound insulation to the door while it was off. Hoping my wiring under the dash looks like the diagrams and pictures I've seen in other installs. Worse case I run a wire to the rear blinkers. This is on a 2020 Prime Limited.
    20210615_220858.jpg 20210615_220907.jpg 20210616_225522.jpg 20210620_130258.jpg 20210620_132837.jpg 20210620_153153.jpg 20210620_161133.jpg 20210621_203743.jpg 20210621_203751.jpg 20210621_203801.jpg
    BellevilleMXZ and Mambo Dave like this.
  12. Sezy
    Sezy Active Member
    431
    229
    37
    2020 Prius Prime
    Kit did not come with wires so had to get 20ga wire, 2.54mm molex connectors & a crimper. Took some trial & error learning what a good crimp was & to make it neat enough to slide into the pin harness.
    Also ran puddle light wires incase these blinkers fail & I decide to go with Avest later on.
    Tapping into power was easier that expected on my 2020 Prime Limited. Only used the positive blinker wire & made my own ground as I ran low on taps.
    Got it all working & looks cool. I did notice some moisture inside the windows now when it rains so need to pull the door panels apart again & check over my seals. Mirror rattled a bit too until I pushed on it again & heard another snap. 20210625_204451.jpg 20210625_204541.jpg 20210625_204547.jpg 20210625_224115.jpg 20210627_164203.jpg 20210627_164233.jpg 20210627_193716.jpg
    Hopefully these pictures help anyone else attempting side blinkers.
  13. Sezy
    Sezy Active Member
    431
    229
    37
    2020 Prius Prime
  14. PtPri
    PtPri Junior Member
    91
    40
    Lisbon, Portugal
    Luxury
    That's sexy.
    Too much of a handful, or doable to a non-engineer DIY curious?
    Mambo Dave likes this.
  15. PtPri
    PtPri Junior Member
    91
    40
    Lisbon, Portugal
    Luxury
    Still on this theme, my gen4 has blinkers on the mirrors - stands to logic that it should have an electrical connection there already, thus making this much easier to do?
    Sezy likes this.
  16. Sezy
    Sezy Active Member
    431
    229
    37
    2020 Prius Prime
    Oh yeah should be plug & play or only splicing the 2 wires in the mirror.
    Mambo Dave and PtPri like this.
  17. Sezy
    Sezy Active Member
    431
    229
    37
    2020 Prius Prime
    Thanks. I'd say one would have to be familiar with crimping small wires & pins. I was worried what if the factory pins came out,so caution should be used if your non familiar with hooking up electric stuff or clumsy. Haha
    In theory one could bypass the clean method of hiding the wires & just run a cable to the door by poking through the wire cover then seal with silicone.
    PtPri likes this.
