Avest Side Mirror install
Discussion in 'Gen 4 Prius Accessories and Modifications' started by bobthejedi, Apr 18, 2018.
  1. bobthejedi
    bobthejedi Active Member
    127
    144
    SF Bay Area
    I recently completed my install of the Side Mirror turn signal on my 2016 Three with ATP that was mentioned in two different threads
    What Did You Do To Gen4 Prius Today
    Side mirror turn signal lights
    and wanted to consolidate my install into one place. Thank you again to sfv41901, randomwalk101, and Elektroingenieur for their assistance with checking my work and providing advice in the other threads
    Before I go further, this is fairly involved install and these instructions should apply to all Gen 4 Priuses, but I cannot guarantee it will be same, please check with a multimeter and check your work. This is just a guide! If you are in SoCal consider hitting up sfv41901 because it seems he can assist with this install! The instructions that came with lights are attached
    Parts Needed
    Side Signals (I purchased from ebay, but you can also purchase from Hybrid Pit as well.)
    10mm ratchet
    screwdriver
    electrical tape
    clothes hanger or something to fish cables through
    Plastic Pry Bars
    T-taps (red) (or solder or some other method to tap into existing cables)
    fuse tappers
    Multimeter to check voltage and continuity
    It took me about 8 hours added up to do this, but it was also my first time, so someone experienced probably can knock it down to 2-4 hours.
    Remove Door interior trim Panels, I followed this great youtube video
    Three screws and they are off, if you have some vinyl, you can wrap your door trim pieces as well for a nice look, I wrapped mine in black carbon fiber
    Mirror assembly removal is straightforward once door panels are off, three metal screws and one plastic plug closest to door edge. The existing cables go to connector that easy to disconnect.
    Once you have the mirror housing, I recommend taking the mirror off (watch the heater connection and orientation!) and getting the housing off is a little difficult. pop off the bottom trim piece and pop the new one in
    Follow the existing wiring of the mirror adjuster and fish cables accordingly through. Reattach Mirror to door
    new wiring bundles will have to go through rubber boot to body connector, I believe they are the same length for both sides and have one female/male connector on one end and pins on the other.
    Now for the fun part. You'll have to undo two bolts holding the rubber boot to the door. Then tackle the door to body connector, I recommend a thin flat head screw driver
    Undo the connector like so
    Remove interior connectors with thin tools and roll back rubber flat shovel looking side on itself and it will reveal another plastic piece, start threading cables through, you can start with smallest black/white cable and then use that fish the other through.
    Insert into connectors, first unlock the locker bar otherwise new cables won't go in...don't ask how long it took for me to find this out...
    Sort the remaining cables by length, there should be two bundles left of each wire type, the longer will be for the passenger side. Repeat for other side and route cables into car, now would be good time to check for continuity with multimeter!
    Route cables into car, from passenger side I went from door to glovebox to area below the shifter
    Connection to ECU
    You probably should disconnect battery at this point for safety reasons
    Remove all panels near left foot area.
    you should remove the two panels housing the hood release/refuel button and headlight dimming and HUD (if ATP) there is one screw holding it down, this will really open up area to work with main ECU
    This the diagram of how the turn signal works and how it translates from the manual to actual
    Make your connections for turn signal here with taps mine looked like this
    Tap for your ACC/constant/negative
    Puddle lights are more interesting, you'll have get the a pillar cover off, the clip is a little hard to get off and you can purchase replacements if you damage it, but I got mine off with the method below
    You'll then see this, fish the black white cables to here and tap
    I stashed the button controls here and chose to have DRL on and sequential on, but you can choose whatever you want!
    chickenhawk, hill, Rexq and 5 others like this.
  2. bobthejedi
    127
    144
    SF Bay Area
    Forgot the completed pic!
    hill, RCO, benagi and 3 others like this.
  3. randomwalk101
    randomwalk101 DYI'er
    532
    258
    texas
    Awesome DIY.
    Will tackle mine this saturaday.
  4. BLITZ XW50
    BLITZ XW50 Member
    91
    81
    Chicago, IL
    Great detail (y) .. Definitely interested in getting these perfect for the DIY'ers
  5. randomwalk101
    532
    258
    texas
    @bobthejedi
    You were talking about removing the glass & heater wires... like this?
  6. bobthejedi
    127
    144
    SF Bay Area
    Yep! Looks pretty much the same!
    randomwalk101 likes this.
  7. randomwalk101
    532
    258
    texas
    Bob
    So you hook the puddle light to dorm wire so if you turn on the dorm light the puddle light is on?
  8. randomwalk101
    532
    258
    texas
    Okay. Finished installing the lighted signal mirrors. Let say my next car, I’ll make sure I buy the model that has the signal so I won’t have to go through this again.
    Now just need to figure out the right wire to tap in for the puddle light. I grounded the puddle light meg (black wire) down at the bottom of the chassis instead of running it up the A pillar. I found that red & purple wire bobthejedi was talking about but I hooked up a multimeter to that red wire and it’s always hot. Will this cause my puddle to be on always???
  9. randomwalk101
    532
    258
    texas
    I got it. The purple wire is not ground. It’s 0-12v. When it’s 12v it cancels out the other constant 12v which turns off the light.
  10. randomwalk101
    532
    258
    texas
    Doggonit!!! Figured out the puddle light and hooked it up. Worked great and was about to wrap up and looked on the passenger side and the puddle AND the DRL light is lit (car is off, unlocked). Arghh!!! I regrounded the two black puddle light wires and unhooked the white puddle light white wires and everything is back to normal.
    Something is wrong somewhere but I’m just too damn tired. Just Going to live without the puddle light.
  11. bobthejedi
    127
    144
    SF Bay Area
    That's weird, but congrats on the rest of the install. The black puddle lights should go to the purple negative wire. I actually like having the puddle lights now that they are hooked up right, I originally was going to give up as well, but I think its worth it.
  12. randomwalk101
    532
    258
    texas
    Yup. That’s what I did. White to constant and black to purple (which is actually 0-12v). When light is off, that purple light is 12v. Really weird.
  13. bobthejedi
    127
    144
    SF Bay Area
  14. d4vr0s
    d4vr0s Junior Member
    Knoxville
  15. bobthejedi
    127
    144
    SF Bay Area
    That appears to be the first gen one, I got this one that has more light segments
    Turn Signal Lights Sequential LED DRL White Black for Camry XV70 2018 Prius XW50 4580351391140 | eBay
    However, if you're interested in folding mirror option, I believe @sfv41901 with Hybrid Pit has the avest kit and some folding mirror options for sale, you might as well do that if you're opening up the doors. I did mine before he had that option otherwise I would bought from him!
    What Did You Do To Gen4 Prius Today | Page 6 | PriusChat
  16. d4vr0s
    Knoxville
    Thanks for the updated link!
  17. MagnusAG99
    MagnusAG99 Senior Member
    671
    514
    Norway
    love those lights lol, just installed them on my 3rd gen, gotta say the wire feeding is the worst part lol.
    I tapped the foot lights for the puddle lights, only negative with that is that when i walk up to the car it doesnt turn on the puddle lights... i have to click the unlock button for them to turn on, but what i do like with them is that they turn off when i put the car in gear, but as soon as i put it in park they turn on and stay on until i lock the car.
    One little thing i will change with mine is redirecting the DRL wire so it isnt DRl, but so it turns on when the interior lights come, just so the whole width of the car illuminates when i walk up to it.
  18. randomwalk101
    532
    258
    texas
    Bob
    I think this mod is perfect with that running signal mirror :)
    Sommer86, Sezy, d4vr0s and 2 others like this.
  19. MagnusAG99
    671
    514
    Norway
    im really starting to wonder why toyota isnt this creative making their cars... Prius wouldve looked so good with this.
  20. bobthejedi
    127
    144
    SF Bay Area
Loading...
