2015 Prius PHV imported Japan - Change Display Language
Discussion in 'Gen 3 Prius Audio and Electronics' started by KiwiTim, Jul 6, 2021.
  1. KiwiTim
    KiwiTim New Member
    New Zealand
    2015 Prius Plug-in
    I have just purchased a 2015 Prius PHV (Japanese Import). The multimedia/navigation system appears to be a DENSO 'Excellent navi NHZD-W62G'. Apparently, it is possible to change the system language from Japanese to English using an SD Card. I would also like to load NZ maps onto it. Has anybody here done this using the 'Excellent navi NHZD-W62G'?
    49,446
    congrats and welcome!
    not sure it can be done, but @dolj might know.
    all the best!(y)
  3. dolj
    dolj Senior Member
    7,648
    3,859
    Wellington, New Zealand
    I have no experience with the Prius PHV model.
    But this right here is one of the reasons I dislike JDMs, particularly Prius where there is so much information communicated by way of the MDF.
  4. NewHybridOwner
    NewHybridOwner Active Member
    607
    282
    W. Michigan
    Perhaps you could try writing/emailing to Toyota Japan: I'm sure somebody there can read end write English.
  5. KiwiTim
    KiwiTim New Member
    New Zealand
    2015 Prius Plug-in
    Thanks for responses above. After scouring the web, I think the only practical solution is to replace it with an Android radio/nav.
