2015 Prius PHV imported Japan - Change Display Language
Discussion in 'Gen 3 Prius Audio and Electronics' started by KiwiTim, Jul 6, 2021.
  1. KiwiTim
    KiwiTim New Member
    New Zealand
    2015 Prius Plug-in
    I have just purchased a 2015 Prius PHV (Japanese Import). The multimedia/navigation system appears to be a DENSO 'Excellent navi NHZD-W62G'. Apparently, it is possible to change the system language from Japanese to English using an SD Card. I would also like to load NZ maps onto it. Has anybody here done this using the 'Excellent navi NHZD-W62G'?
    52,818
    congrats and welcome!
    not sure it can be done, but @dolj might know.
    all the best!(y)
  3. dolj
    dolj Senior Member
    8,637
    4,390
    Wellington, New Zealand
    I have no experience with the Prius PHV model.
    But this right here is one of the reasons I dislike JDMs, particularly Prius where there is so much information communicated by way of the MDF.
  4. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Perhaps you could try writing/emailing to Toyota Japan: I'm sure somebody there can read end write English.
  5. KiwiTim
    KiwiTim New Member
    New Zealand
    2015 Prius Plug-in
    Thanks for responses above. After scouring the web, I think the only practical solution is to replace it with an Android radio/nav.
  6. Amaan
    Amaan New Member
    Australia
    2015 Prius Plug-in
    ----Australia----
    hi Kiwi, I’m in the exact same situation as you and came across your post. Since it’s been 3 years, I assume that you have replaced it with an Android nav, and just wanted to know which Android nav u ended up getting (the specific specs pls so I can get it too :))
