2020 oil capacity vs. recommended fill
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by mcbrunnhilde, Jul 23, 2021.
  1. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    612
    The recommended amount of oil for my 2020 Prime is 4.4 quarts when also changing the filter. Is that what should actually go in? With my 2004 Prius, I've always followed the 3.5-quart rule instead of 3.9 to avoid overfill (since it's 3.9 quarts in a bone-dry oil pan).
    Also, I've always gotten my synthetic oil at Costco, but they don't have 0W-16. Is Walmart the next best thing, or is there a better deal someplace else?
    Thanks in advance for the input!!
    Georgina Rudkus likes this.
  2. jerrymildred
    jerrymildred Senior Member
    11,491
    14,100
    Tampa, FL
    Modern oils are so thin that they drain pretty completely. I add about 4.4 quarts when I change my oil and filter. Seems to always come out right on the dipstick. Still, it's a good idea on the first oil change to put in less to start with and then check it in a few minutes, adding more if needed.
    Edit to add that I can't advise on best places to get your oil since we live almost on different planets. ;)
  3. Mendel Leisk
    38,257
    I put in a carefully measured 4.4 qts (actual measure 4.2 liters, same thing), and wait a few days to check it. It’s invariably about 1/8” to 3/16” below the top mark, which is fine by me.
    i think you can use 0W20, no problems. The shift to 0W16 is purely to wring an infinitesimal more mpg? Or 5W20, or 5W30, same story. Have you tried dealership parts dept btw?
    jerrymildred likes this.
  4. privilege
    privilege Active Member
    659
    165
    Birmingham
    you're doing it wrong. instead of measuring what goes in or comes out... you check the dip stick and add until the dipstick says you've succeeded.
    douglasjre likes this.
  5. Mendel Leisk
    38,257
    When I’ve done that, right after an oil change and running the engine a few minutes to distribute the oil to filter, I end up overfilled, when I recheck a few days later.
    privilege likes this.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,125
    2,182
    Taylors, SC
    I am in agreement with you. It is better to underfill between the upper and lower mark on the dipstick. Then again, I check oil level often.
    Too much oil might be splashed into the egr system and cause clogging there and at the intake manifold as well as the PCV valve.
  7. privilege
    659
    165
    Birmingham
    good !
    the important part is that your actually checked.
    that way, when the magic papers (fsm, manual, internet, etc) lists the wrong amount, you have that super reliable dipstick to confirm the fill state.
  8. Pulse07
    Pulse07 Active Member
    273
    137
    East Bay, California
    2020 Prius
    XLE AWD-e
    Who cares, you cant read the oil anyways . Due to the light oil and the crappy dipstick design.
    Wolfman33 likes this.
  9. privilege
    659
    165
    Birmingham
    how do you check your oil level, if you can't see it ?
  10. Pulse07
    273
    137
    2020 Prius
    XLE AWD-e
    Stare at it for 20 minutes , moving it on a different angle, the "paper method".
    jerrymildred and privilege like this.
  11. privilege
    659
    165
    Birmingham
    I changed mine yesterday. I've accepted two thingsas a result of this Prius: 5k mile oil changes & filtered oil (some people think it's synthetic)
    man it's hard to see this watery stuff without a purple laser illuminating it !
  12. Mendel Leisk
    38,257
    After pulling dipstick wait a few minutes. This allows oil drawn up the tube time to drain, and the dipstick will get less oil smear, easier to see true level.
    mcbrunnhilde likes this.
  13. PT Guy
    PT Guy Senior Member
    1,085
    709
    Washington, the state
    Pull the dipstick and lay the lower part on a clean paper towel. That will absorb the oil and show the oily part of the stick.
    I’ve never seen an engine where a slight overfill is a problem.
  14. FuelMiser
    FuelMiser Senior Member
    1,270
    861
    Monument, CO
    I've always put 4.0 qt in my 2016. There's nothing wrong with ending up between the dots. I buy the 5 qt jug at Walmart and pour off one quart into a measuring cup. Then fill with the remaining four qts in the jug, and return the extra 1 qt to the jug for next time. I've never had to top off between 10K oil changes through 40K miles so far.
  15. Colorado Boo
    Colorado Boo Active Member
    307
    201
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Yep I had a hard time finding the OW-16 for my 21 Prius...all three local car parts stores were out but I lucked out and found 5 qts of Mobile 1 at Walmart.
    I'll be sure to stock up on it when I see it on the shelves in the future.
    If you can't find it, we can use OW-20 BUT are supposed to go back to OW-16 on the very next oil change. And we aren't supposed to put OW-16 in a car that says OW-20, it's not designed for it.
    It is hard to see the oil on the dipstick when checking it....I have a little work light I'll bring over, dry off the dipstick, then can see the thin oil when I hold it next to the light.
  16. douglasjre
    douglasjre Senior Member
    1,774
    617
    Orlando, FL
    If you let the car sit overnight and do the oil change on a cold motor in the morning another qt comes down from the valve train. Do the oil change like this without running the engine first. You'll get five quarts out of the engine instead of four. Change the filter and dump in a five-quart jug of mobil one
  17. jerrymildred
    11,491
    14,100
    Tampa, FL
    I agree that you'll get more out of it if you let it sit overnight. But when I change the oil in my Prime, the engine usually hasn't been run in the past several days since most of my driving is EV. Adding 4.4 quarts with a new filter always brings it to the full mark on the dipstick.
  18. pasta4breakfast
    pasta4breakfast Junior Member
    35
    17
    2020 Prius Prime
    I know this is an old thread, but did you ever try filling it with something like 4 quarts instead of the standard 4.4 quarts? 6 months ago, I brought 5 quarts to my mechanic for an oil change and he used about 4.5 quarts. The oil level was still a little below the full line. Yesterday I thought I gave him another 5 quarts, but when I got home I remembered that one of the quarts was the half empty one from the last oil change. He ended up giving me back just a hair under half a quart. After realizing that he likely only filled about 4 quarts, I checked the oil level this morning and it was about half way between the min and the full line, maybe a little less. I'm guessing 4 quarts may still be okay as long as the oil level is regularly checked. If 4 quarts isn't enough, that probably means my mechanic didn't drain as much of the old oil they could have.
  19. douglasjre
    1,774
    617
    Orlando, FL
    If I put it in 4 quarts it doesn't even register on the stick
  20. Mendel Leisk
    38,257
    If you raise just the front end, and raise it high, you maybe get a better drain, comparing to a shop that lifts the whole car, keeping it level? The drain bolt is towards the rear of the oil pan, and I think the interior of that pan is simple, clear of baffles. Say maybe 100 cc more?
