Oil change really needed with little use?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by stevepea, Jun 20, 2021.
  1. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Another thought here is send in an oil sample for testing after about 13 or 14 months and see what they say
  2. Salamander_King
    Salamander_King Senior Member
    11,016
    8,948
    New England
    Wouldn't that cost more than changing oil and filter DIY?:ROFLMAO:
  3. DukeofPrime
    DukeofPrime Member
    107
    77
    US
    Everyone always talks about the wear caused by short trips. However, with the computer turning a hybrid's engine on and off even on longer drives, does this reasoning still apply? My thinking is the engine must be designed to deal with these short cycles so maybe this convention wisdom no longer applies?
    It reminds me of the people worried about the additional wear caused by stop/start systems. A properly engineered solution should account for this use case(more robust starter, methods to keep oil pressure up, etc). Granted, not every auto is properly engineered, but over time I would expect the kinks to be worked out.
    I still don't think I'd go over a year, but it still makes me wonder...
  4. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    I used to change our 17 Prius yearly, didn't even get 5,000 miles a year. But then a master Toyota technician told us that if we intend to keep the Toyota for 10+ years (and we do), every 6-months was better, no matter how many miles is on her. (I change the oil myself so very cheap but our dealership often has oil change discounts...something like 3 for $99, so that's not bad at all.) Doing the change myself usually runs less then $30 so only $60 a year...well worth it knowing the oil is always clean in there.
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    A MASTER Technician......OOOOO I'm impressed.
    NOT.
    I think the "Master" engineers that designed the car probably are better qualified.
    Just maybe.
  6. privilege
    privilege Active Member
    659
    169
    Birmingham
    once it's up to temperature, it's happy to turn in and off.
    it's turning it on (cold) and running it hard without fully earning the
  7. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    I’ve looked at dozens of oil analysis reports, and the time in service makes almost no difference to the oil’s suitability for continued service. (Going far afield here, the 30 wt crankcase oil in a very large Diesel engine where the crankcase is sealed away from the combustion spaces may have a service life of 20+ years.). I have full confidence in the recommended oil change intervals of 10k miles for the Prime and also the 7,500 interval for my Mazda. I do wish Toyota had given us more to go on…engine-only miles, or engine hours, or cumulative gasoline consumption, any of which would be a good indicator.
  8. Mendel Leisk
    41,344
    They could borrow from Honda: their maintenance minder is definitely smarter. Honda doesn’t disclose exactly how it works, but it seems to be monitoring several factors, and accordingly varies maintenance intervals. Gives you percent count down, and when due displays a code that you can look up in the manual; see precisely what’s involved in the service.
    m8547 likes this.
  9. BiomedO1
    3,514
    1,823
    SacTown, Ca
    Certain models of Honda, GM, and Dodge/Chrysler uses some sort of matrix based on ECU inputs to determine oil change intervals.I don't know if there was a time component to those maintenance counters; since I usually trip them quarterly, in those old service vehicles I used to have. If I was doing service calls, mostly in the mountain regions, it would trip around 3k to 4.5K miles. If I spent most of my time on the "flats" or in the valley, I'd get close to 7500 mile before tripping the maintenance lamp. We are talking about the old 3K to 5K mile OEM service intervals on old dino oil, none of those fancy synthetic stuff...
    IMHO; I consider oil changes as cheap insurance against major engine repairs.
  10. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    Yes, one suggestion I've given Toyota is about their settings on the maintenance system which is only for a preset mileage (5,000).
    My daughter's Mazda CX-5 has settings where you can have either mileage or time and it also let's you choose the mileage, 5,000 or 10,000. Very smart.
  11. Mendel Leisk
    41,344
    My 2 cents: any of the dumb counters are a waste of tech and dash space; just keep an eye on the calendar and odometer. And keep a log.
  12. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    I once did an oil change on my Odyssey that was 18 month old Mobil 1, probably 6000 miles. Sent a sample to Blackstone with the question about age vs miles. They told me my sample was fine, still plenty of useable life in it, and that 2 years would be fine if the mileage doesn't pile up.
    I think more important is that the ICE gets fired up and used fairly often and that you don't let the gas go bad.
    MTN likes this.
  13. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
    Yep, I've had an Excel spreadsheet for years that helps keep track of EVERYTHING. No more wondering how old my batteries are or when I last had a brake job. I also keep notes in there for future jobs (example: Make sure I have my extra long Allen hex bit sockets and 12mm swivel socket whenever taking out an air intake manifold.) Saves a ton of time.
  14. BiomedO1
    3,514
    1,823
    SacTown, Ca
    I use a half sheet spiral notebook and shove a pen in the spiral wire. It lives in the glove box of the car. I also note part numbers, torque specs., and any useful/important info.; on the inside front and back covers of the notebook. ie. control sequence to put my GMC transfer case into neutral for towing.
    This has worked well over the years and enhances the cars' resale value - purchaser knows when and what was done to the car and what needs to be done.
    I've toyed with the idea of putting all this information on a spreadsheet, dropping it into the cloud and accessing it on my cell phone - but I don't have the time or inclination to do it. Besides, if it ain't broke, why fix it.:rolleyes:
    Colorado Boo, Raytheeagle and bat4255 like this.
  15. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Plus, no battery to charge or go dead. :)
    BiomedO1 likes this.
  16. Mendel Leisk
    41,344
    A simple text format file will do, “.txt” extension, in windows system, for a maintenance log. Entries like this:
    2021_09_14
    92500 km
    Oil and filter change
  17. aleyoop
    aleyoop Junior Member
    39
    socal
    Nothing major will happen if you don't but its cheap insurance....If you actually look at the cost of owning a car, an oil change is inconsequential...
    I would do it at least once a year.....
    Salamander_King likes this.
  18. Salamander_King
    11,016
    8,948
    New England
    Just took my 21 PP for the first oil change at 9,259miles on the car and just past 1 year of ownership. It was free using Toyota Care. I will do the same again next year. If I still have a car after three years. Then, I will start DIY oil change once a year or every ~10K miles as specified in the manual. BTW, my EV ratio is currently 63%. That means the engine has run only 3,425miles before the first oil change.
    don_chuwish and mmmodem like this.
