P0113 & P0102 code after clean up oil down throttle body
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tekken, May 30, 2021.
  1. Tekken
    Tekken Member
    259
    77
    Los Angeles, California
    Hello
    After remove the air filler and rest of part to vacuum up the oil down of throttle body approx 2 teaspoon every 3-4months and everything are place back in normal. A check engine light ON and Torque scanned with P0113 & P0102 code.
    So, I disconnect and reconnect the Mass flow senor and check everything are connected correctly. Clear the fault on ECU and Check Engine light off and running fine. Every time I run the Torque scan code again the code P0113 and P0102, but NO Check Engine light. Please advise. thanks
    P0113 (Intake Air Temperature circuit hight input
    P0102 (Mass or Volume Air flow cicuit low input
    Oil down of throttle body even with Oil catch installed excessive oil down in the throttle body with acceleration.
    #1 Tekken, May 30, 2021
  2. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
    Shooting from the hip: if the MIL (aka Check Engine Light) isn't coming on, these are not current codes then right?. (Or so intermittent that they aren't ever happening twice in row, since it's a 2-trip detection for at least the P0102.)
    I forget at the moment how it looks on Torque but you can tell the difference between current, pending, and "permanent" codes. They ought to self-clear after enough trips that meet the confirmation conditions. The repair manual will have deets on what those confirmation conditions are.
  3. alltherightpills
    alltherightpills Junior Member
    26
    42
    St. Louis, MO
    Can confirm. I forgot to plug in the MAF after some maintenance…got the same codes and they stuck around even after the CEL went off. Don’t know if it’s mileage driven or a certain number of on/off cycles, but the codes went away after a day.
    wheezyglider likes this.
  4. Jenny2010Prius
    Jenny2010Prius Junior Member
    37
    Calgary
    2024 Prius Prime
    SE
    Facing the same issue here right now. Have you solved the issue, Tekken?
  5. ChapmanF
    18,486
    Those two codes (both resulting from having that sensor unplugged) stick around as 'permanent' codes until the car actually sees the necessary driving conditions to confirm they've been fixed. I had a permanent P0102 for a year because my COVID lockdown driving never met the conditions to clear it. Finally got rid of it once Elektroingenieur kindly looked up the right confirmation driving pattern for it.
  6. Jenny2010Prius
    37
    Calgary
    2024 Prius Prime
    SE
    Got rid of the code by disconnecting the MAF, blowing the sensor & connector with compressed air, and re-connecting it back.
    Rebound likes this.
  7. ChapmanF
    18,486
    Jenny, did you have a check-engine light before?
