2017 prius prime squeak and creaking noise from rear left side of car
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by philip kim, Aug 7, 2018.
  1. motch6
    motch6 Member
    44
    34
    UTAH
    2020 Prius Prime
    Ya, I wish there was a TSB or someone we can contact at Corporate.
    Same exact sound from me. I took out ALL the plastic in the rear and drove around. Still there! To me it sounds like something either between the battery compartment and chassis or with the PRIME, its the two batter compartments rubbing together some how.
    After reading some other previous posts, i wonder if it has something to do with the Shock absorbers or Springs in the rear.
    Dook likes this.
  2. Dook
    Dook Junior Member
    40
    France
    Hello,
    I removed, as you did, all the plastic in the trunk, and of course the noise still there.
    I recorded the noise with my phone voice recoder :
    Zippyshare.com - Voix 001.m4a
    You can hear the noise at the 7th second
  3. Johnny 5
    Johnny 5 New Member
    San Diego
    2020 Prius Prime
    I have a 2020 Prius Prime XLE and have this same problem. Whatever is causing this issue still hasn't been resolved.
    Storm88000 likes this.
  4. BChoAss
    BChoAss Junior Member
    34
    22
    CA
    2019 Prius Prime
    I also had this annoying issue and I took it into my dealership last year and apparently it annoyed the master tech enough to tackle the issue for couple of days.
    He isolated the noise to the support plate that is spot welded and apparently the plates were rubbing on the body when my Prime was going over the bumps and dips.
    I uploaded and left a link of the repair notes for future reference.
    burrito, PtPri, Dook and 3 others like this.
  5. Dook
    Dook Junior Member
    40
    France
    So you need to remove rear seats ?
    What plate is he talking about ? I can't figue it out ?
    Thanks !
  6. BChoAss
    34
    22
    CA
    2019 Prius Prime
    Sorry man, I wish I could help, but I have no clue since the Toyota master tech tackled this issue. If your car is still under warranty, I would recommend taking in your Prime to your local dealership and have them look up the TSB and have them address the issue.
    Dook likes this.
  7. Dook
    Dook Junior Member
    40
    France
    It's not under warranty anymore. So there is a TSB about it ? I didn't know that...
  8. Mendel Leisk
    41,643
    There was a service bulletin for that, for 4th gen Prius. Maybe Primes are in the same boat?
    Raytheeagle likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    That statement was from three years ago:p.
    But could be the same;).
    I know our 2019 does not have any creaks so far:whistle:.
    But it will eventually(y).
  10. Mendel Leisk
    41,643
    Hey I just needed a springboard, lol.
  11. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Glad I could be your catalyst(y).
