2009 ABS Pump part number 44510-47050 v. 44510-47051. Interchangeable?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kyle G, Jul 21, 2021.
Tags:
  1. Kyle G
    Kyle G New Member
    Tampa
    Are 2009 Prius ABS pump part numbers 44510-47050 and 44510-47051 Interchangeable? I pulled mine today and the part number is -47051 and not the -47050 I see listed everywhere. They look exactly the same.
  2. Too Many Prii
    Too Many Prii Junior Member
    25
    The Lone Star State
    Did you ever learn more?
  3. Kyle G
    Kyle G New Member
    Tampa
    yes, they are interchangeable. I installed and it worked great.
  4. dolj
    dolj Senior Member
    8,495
    4,313
    Wellington, New Zealand
    The -47051 is the updated part so would be better to try for that if you can, but as you say the -47050 part is more plentiful.
    @Too Many Prii, for your 2008 model apparently the part number is as below"
    Toyota 44500-47140 –– ACTUATOR Assembly, Brake
    2005-2009 Toyota Prius
    Part Description
    Part Name Code –– 44510
    Replaced By –– 44500-47141
    Manufacturer –– Toyota
    #4 dolj, Aug 17, 2021
    Kasra likes this.
  5. Gabe F
    Gabe F New Member
    Nashville, TN
    Spoke with the dealer today. The original part number was superseded by the later part number.
    There was a recall in April of 2016 - Jan of 2018 for the original part number, and has been completely discontinued.
    MSRP as of now according to toyota web site is $1769.47 and comes with the whole abs assembly including the Resistor.
    The caveat is that right on their site it says dealer has the right to set the price to whatever they want to.
