Featured World's Biggest EV: It's all downhill from here
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Leadfoot J. McCoalroller, Aug 9, 2021.
  1. Leadfoot J. McCoalroller
    8,069
    7,552
    Pennsylvania
    2018 Prius c
    A cement factory in Switzerland is now using the world's largest EV to haul rocks.
    The particulars of the operation mean that the rock and lime need to be hauled down a hill for processing, so they never need to charge the truck. It climbs back up the hill empty using energy drawn from regeneration on the way down.
    Now, it is still a cement factory, and they are notorious for CO2 production so I suppose this is like going through your nuclear bomb collection and proudly stating that no child labor was used to produce it.
    But it's still kind of neat that they built a giant EV that doesn't need to be plugged in.
    PtPri, Richard2005, Trollbait and 2 others like this.
  2. Mendel Leisk
    41,318
    That’s almost perpetual motion, like a water wheel. (y)
    #2 Mendel Leisk, Aug 9, 2021
  3. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I had the same thought. Perpetual motion.
    The water wheel is the closest example. They are filling it with rock that they take to the bottom of the hill. They then empty the truck, and come back empty. Just like a water wheel's buckets are filled at the top and emptied at the bottom.
    One might wonder whether there is even a need for a truck in this case. The same loader that shovels the rock into the truck could just push the rock over the edge.
  4. Mendel Leisk
    41,318
    I’ve heard of downhill-running conveyors, with “motors” which became generators, when the belt was loaded with ore.
  5. Leadfoot J. McCoalroller
    8,069
    7,552
    Pennsylvania
    2018 Prius c
    If there isn't a lateral displacement between the active face they are mining and the crushing/milling equipment below, there will be soon.
    In other words the rocks they started working are no longer there.
  6. ChapmanF
    18,072
    They could also want to have a little more control over the arrival of the rock at the processing equipment.
    fuzzy1 and Mendel Leisk like this.
  7. Mendel Leisk
    41,318
  8. ETC(SS)
    7,134
    I was thinking "government-green"
    I can see the press release now:
    PR person: "Look....over HERE!.A BEV that never has to be charged! We're REALLY GREEN!!....We use regenerative braking from the weight of the rocks to charge the vehicle, which can make it back to the top again using the recovered energy!"
    ZERO Carbon!!
    No Reporter Ever: "How'd you get the rocks into the bed of the truck?"
    PR person: "Look....over THERE!......We triple filter the waste water.....and.....
  9. T1 Terry
    T1 Terry Active Member
    929
    478
    "It's electric powered", all the while leaving off the part where the electric motors are powered by an on board diesel fuelled generator ..... just the same as a locomotive dragging the train down the track.
    The big gold mines over here have diesel/electric dump trucks because the ore has to be dragged up a long winding road up the side of the huge hole they have dug, then they dump the regen energy into big resistor banks on the roof of the truck cab to slow it down when returning empty ....
    Yes, they could put a big battery bank in to store that wasted energy to assist the climb out again, but they get the fuel tax free so it isn't really worth the effort .... they are mining gold, who needs a green image when you mine the worlds base financial currency .....
    T1 Terry
  10. fuzzy1
    10,406
    ... or they could install overhead electric lines, trolley-style, to share the electricity with other loads, such as the trucks going uphill. As @JimboPalmer has described from his time at the Barrick Goldstrike mine in Nevada.
    Get an EV loader. Charge it with:
    "Marking that trip around 20 times a day, Kuhn Schweitz says the eDumper produces 200 kwh of surplus energy every day,"
  11. Trollbait
    12,505
    The cost of the fuel sans tax is enough to invest in batteries or a trolley system. Maybe fuel cells would work out for this use.
  12. T1 Terry
    929
    478
    The road in is moved regularly as they increase the diameter of the hole. Home - The Super Pit check out the video about assembling one of these diggers Blast Videos - The Super Pit Each machine consumes 13,000 ltrs plus (about 3500 us gal every 12 hrs) The 2 Cummins diesels that power it produce over 4,000hp, there are 6 of these working the super pit. The trucks they load into are huge, but they don't look it beside the loader eh :lol:
    T1 Terry
