Who needs a truck, the Prius will haul it all!
Discussion in 'Gen 3 Prius Main Forum' started by dorunron, May 20, 2014.
  1. Markee
    Markee Member
    334
    South Florida Broward County
    Thanks
    dorunron likes this.
  2. Joss
    Joss Junior Member
    Melbourne, Australia
    I put a fridge in my Prius c once - did quite well!
  3. Colm
    Colm Member
    Delaware
    A few weeks ago I hauled 8 6x6x8' wet, pressure treated lumber to line my driveway. Also got the hatch closed too. I had one guy come up to me in the parking lot and said "You don't see this everyday, this should be in a TV ad!
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I had a wager with the Home Depot people when I bought the lumber for my deck. I bought all my decking material including 10ft timbers and planks and they said I can pull my truck up and they will help me load it. I told them I was just going to stick it in the back of the Prius and they gave themselves the look of "here is another one of those stupid customers that is going to fail at putting their load in the car". After pulling up they said there was no way, you need a truck for that and they rent them, blah blah blah. I bet them $5 it would fit. I just loaded them 1 at a time and closed the hatch. I got my money and left them stunned. People really don't understand how big the Prius is and how useful it is. In a truck, it would be hanging out of the bed of the truck and exposed to the elements. In the Prius, it is just another passenger.
    AllenZ, Tony D, ewxlt66 and 7 others like this.
  5. priusdonkey
    priusdonkey Member
    211
    51
    Los Angeles, California
    Yah... but my Ford F150 can carry your Prius in the back of the truck. For serious hauling and construction i use my old F150,i have 200,000 miles on the clock. Besides i don't want the Prius to smell like the inside of my truck. I also can't put a 500lb motorcycle in the back with the seats folded down.
    KennyGS likes this.
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    No it cannot carry a Prius in the bed. It could tow with a trailer. Just like I could tow a Prius with my Prius. My Prius doesn't smell at all. Usually a smell is because of moisture of some kind. If the inside is dry and what you are putting inside is dry, no smell. Even when I go skiing I just put the wet skis in the car and the water evaporates away no problem.
    I am sure you could get a motorcycle in the back, but it would have to be tilted so the fluids would not be happy staying put on most models.
    And here is a 4000lb trailer:
    And then there's good old Bob W. towing his plane a few hundred miles:
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    One of the ladies at my church needed to buy cheesecakes from across the state for a fund raiser. Somehow she could only fit 24 in her SUV. I asked for one of the empty boxes to map out how many I could carry in a Prius v. I counted 96. Had they ordered more more would have fit, but it would have impaired outward vision.
    As you see, the load floor is not perfectly level but quite serviceable.
    JTM2955 likes this.
  8. bisco
    51,932
    sounds wonderful! it's funny, i've heard of about half the plants. i guess the rest don't like zone 5!:p
  9. priusdonkey
    priusdonkey Member
    211
    51
    No you can't get a motorcycle into the back of a Prius, if you can please take a photo - i need a good laugh. It is not a work truck, period.
    Nor is my F150 a hybrid... at idle it only gets 25 miles to the gallon.
    I have put 5,000 lbs in the back of the truck accidentally and hauled 2000-3000 lbs boulders. I have also pulled a 24' trailer with a 3 series BMW inside to and from the track.
    I have moved an entire house with the truck and trailer making just a few trips
    I have done Demolition with the truck and gutted houses with the truck and a 14 foot enclosed trailer, moved yards of cement, 3/4" road base with fines from the mine and thousands of pounds of fill dirt at a time...the truck after 11 years smells like a taco truck.
    I also have needed to jam on the brakes hard on a few occasions and had to swerve very hard into an opposing lane when some idiot was riding his bicycle at night, no lights and several feet away from the shoulder on a country road, with a 14' enclosed featherlite trailer attached, with 8' and 12 foot greenhouse rafters inside. The frame on the Ford F150 is a massive and it is a hydroformed frame. I just crawled underneath the truck tonight and replaced the rear shocks with 4600 heavy duty bilstein mono tube gas shocks. Tomorrow i do the front struts.
    The point i am making is every tool has a purpose. I use my prius 97% of the time, it is my DD and i get 55+mpg, the truck gets driven maybe 1,000 miles a year. The motorcycle i sold was no contest for any four wheeled vehicles, for sheer enjoyment and scaring the tar out of myself on a few occasions.
    Furthermore, there will come a day when you need to make an abrupt lane change or swerve the car or jam on the brakes and the Prius won't be up to the task and you will bend the unibody and possibly roll the car. Hopefully, you won't hurt yourself in the process.
    Tesla also doesn't recommend towing with their vehicles for the same reason. At the end of the day the suspension and brakes aren't up for the task. sure it can do it, but... if you don't have a work vehicle then it is certainly competent enough to handle a light task. But for me I don't need to wreck my Prius cosmetically or mechanically through intentional or otherwise abuse. Theres been many a time when i have scratched my truck or dented my truck or someone pushed a shopping cart into my truck etc.
    the point of all this is "why bring a boy to do a man's job"
    KennyGS likes this.
  10. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    On of the things I won't carry in the Prius is cow manure. Thats' where the open bed of the pickup truck comes in handy.
    DBCassidy
    HybridBull likes this.
  11. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Interesting comments on this string. Looks like I started a "firestorm".
    bisco | PriusChat had asked me to post some pictures when it is finished. It is just about there. I have to add some calbrachoa to the border but the only thing available this late in the season was some big pots of purple/violet colored ones and then the big bed will be done. I wanted the dark blue colored ones. Those colors are very similar to the color of the strain of Salvia known as "Black and Blue". They were beautiful. Calbrachoa actually looks like little miniature tulips. They attract hummingbirds. Those little fellas visit us every year. One actually came through late last fall, hung around all winter with the bitter cold and freezes, and then migrated back north when Spring sprung. If I would have known six (6) weeks ago I would be doing this bed I would have bought the starter plants then. They were readily available at the nursery. The starter plants are all gone now, and what few plants of this species that are found at the local nurseries are either mature plants or big pots and hanging baskets of them. I found one (1) starter and a few big pots. I bought two (2) big pots and am going to split the plants up and then transplant them into the bed for the final effect.
    Anyway, here are some pics for you guys and gals. Wife did two beds, the big one is mine. Need to add the border on mine and then it will be done. Also have solar lights in various colors that come on at dusk and burn for a while...
    If you like this post, take a look at this page I posted on facebook. It shows the pictures in all their glory.
    Ron Carlson | Facebook
    The picture below actually shows our Prius parked in the driveway. It is also linked to "PriusChat" and "Toyota Prius".
    Ron Carlson - New Flower Beds In Front Yard. | Facebook
    Ron
    DSC01607.JPG DSC01609.JPG DSC01610.JPG DSC01611.JPG DSC01612.JPG DSC01613.JPG DSC01614.JPG DSC01615.JPG DSC01616.JPG
  12. dbcassidy
    1,581
    290
    The Prius continues to impress me to this very day on what it can be used for. I think of is like a Swiss army knife.
    DBCassidy
  13. priusdonkey
    priusdonkey Member
    211
    51
    i agree. the Prius is extraordinary in many ways. I took it car camping about a month ago. Set up a tent at night and ran the car with the lights on... after one hour it showed that i used $0.26 of gas. My truck would have swallowed $20 of petrol... No joke...
    Today i returned a 65" LED TV set. Wanted to carry it with the Prius, but in the box it was half the size of the car...
    Next week i am giving a friend a 10' x 4' x 3' chicken tractor (coop) no way it will fit in the Prius. Plus two RIR chickens and "Mini Rooster" = 3. I don't think you want to put some smelly chickens in your Prius? carrying livestock is were a draw the line. One chicken okay, 2 chickens perhaps. 10 pullets - NOPE.
    Definitely agree that the prius is phenomenal at hauling light stuff. I don't think i would load it up with more than 400lbs. in the rear. So carrying more than 5 bags of 60lb. Quickrete (cement) i start thinking truck... more than 7 bags. TRUCK.
    I did carry a bail of bermuda grass it was big but the Prius swallowed it up. When i got back there was hay all over the back and floor. It didn't cover the inside, but i needed to spend 40 minutes cleaning and vacuuming the interior. The truck is throw-and-go.
    KennyGS and dorunron like this.
  14. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  15. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    The last pic here really looks like it is being weighted down too much. I thought the Prius has zero tow rating? Does this effect your warranty from Toyota?
  16. Gas Mizer
    Gas Mizer Member
    153
    49
    Redding, California
    2018 Prius
    I feel so bad for your transmissions....
    stephensprius likes this.
  17. stephensprius
    670
    226
    I agree gas mizer; it cannot be good for that cvt.
  18. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    The Prius may be good for lighter duty stuff. =)
  19. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    And they say the Prius is useless......ha
  20. dbcassidy
    1,581
    290
    Maybe the Prius can tow a F150?
    DBCassidy
