Replacement Center Dash Panel
Discussion in 'Generation 1 Prius Discussion' started by 3prongpaul, Nov 28, 2012.
  1. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    If you remove the Gen1 center dash panel for any reason it will most likely break...it seems the plastic has gotten brittle with age and it can crumble when removed. I've noticed this starting to happen a lot in the last year or so.
    FYI; new replacements can be ordered from the dealer.
    Part number 55405-47030-B0
    Not cheap...dealer List Price is $203.25 online sellers will be cheaper...
  2. bwilson4web
    16,370
    When mine was removed to install a satellite radio, the cheezy plastic inserts broke and had to be 'plastic welded' back on. So I have held off on going there.
    Have you given any thought to some better way to attach the facia?
  3. depriusoto
    depriusoto Member
    113
    17
    Albuquerque, NM
    2002 Prius
    Thanks for this info!
  4. zfenty
    zfenty New Member
    2001 Prius
    learned this today breaks like crazy. lol
    Christian Montero likes this.
  5. bwilson4web
    16,370
    Thanks, I just ordered a replacement from AutoNation, $175 delivered. The original fascia has cracks and the driver-side, vertical louvers were so loose I put a 'paper shim' (Ok, spit wad!) to hold it. The tabs had been 'plastic welded' in the past when we added Satellite radio . . . which we no longer use. The cassette deck no longer takes an adapter so I've been just listening to podcasts with the iPhone in my pocket.
    Obviously this will be a good time to do some repairs and/or replacements. So questions are in order:
    • Can the CD be removed or will I always get an error like the "No CD in player" that shows up now?
    • How many of the audio devices can I remove or will I get error messages each time the car starts?
    • Are removal of any audio devices likely to result in an immobilizer issue?
    • Suggested replacements?
    I am thinking about putting a socket in and running the MFD signals and power to a loop-back connector near the glove box. This would allow me to tinker with the signals and not have to take the fascia off and on. One bad day of soldering and heat shrinking and the access problem is solved. I'll also put in a similar setup for the engine controller, ICE temperature probe.
    Thoughts? Suggestions?
  6. ChapmanF
    18,555
    I shot this video back in August of removing the center panel, but only now got around to editing it for a hosting service. Caveat, the panel in the vid is newer than an original one from 2001-3, so it might still not be this easy, but I wanted to post just in case technique has anything to do with it and maybe some breakages can be avoided.
    (In case the video embed feature in the forum software gives trouble, here's a direct link.)
    -Chap
    #6 ChapmanF, Nov 22, 2014
  7. Hipstor
    Hipstor Junior Member
    Las Vegas, NV
    Hey bwilson4web, couple suggestions.
    If your tape adapter won't work. Try a Bluetooth to FM adapter instead. There are several currently available for less than $20. Here is one example I picked at random.
    I bought mine (different make/model) at Walmart. Works pretty good for playing music and podcasts from my phone.
    If you want to remove the CD player from the Gen 1 Prius. I think you can just pull the player and pass-thru cable from the dash. Then plug the harness that previously plugged into the pass-thru directly into the radio. And the radio shouldn't even care. Unless you press the Disk button on the dash. Haven't actually tried this though.
    I have driven my 2003 Prius with the center dash torn apart. No radio, no CD, no touchscreen, not even any ac/heater controls. No problems with immobilizer.
  8. AlienMartian
    AlienMartian New Member
    Tulsa
    2001 Prius
    I
    11 years since this post and its still not any cheaper!
  9. nimblemotors
    nimblemotors Re Member
    117
    37
    Sacramento
    2002 Prius
    I followed the advice in that video, and removed one of mine without breaking it.
    These cars show up in the picknpull now (gen2 also), and so you can go there to get one (though I see some are also broken..)
    I made a custom one for my daughters car, was lots of work, but looked kinda cool, definitely different.
    Good luck with your gen1. :)
  10. ChapmanF
    18,555
    Pics?
